Auto dipping passenger mirror on reverse...
Kestrel
Active Member
It's my birthday
Is there any way to disable the feature from within the car?
I've tried all the settings to no avail.
Many thanks.
Mike.
Daggerit
Many thanks.
Mike.
If you don't have the wing mirror selector on the L setting then I don't think it activates when you select reverse?
zippster
just have the wing mirror switch set to the middle location .. (or right just not left!)
RAF_S7
Well-Known Member
Gold Supporter
You can "adjust" it while in reverse, so that its in exactly the same position as when its not in reverse :racer:
Daggerit
Thanks chaps.
The answer then is a resounding `No`.
Correct. Don't know why you'd need to if it doesn't actually do anything in the middle setting?
zippster
Thanks chaps.
Are you saying that you have tried the suggestions and it doesn't work ;(
Daggerit
Haha, just leave the mirror adjustment switch permanently in the middle?
Or as someone suggested you could just adjust the dipped position to the same as your normal position and it would never move regardless?
