in this episode we will be replacing the fuel pressure regulator which is a nice simple job to do we will be installing a 4bar one instead of the standard 3bar which may help when we tune the car more power and I ordered it when I was having cold start problems so why not fit it as we have it Symptoms of a Bad Fuel Pressure Regulator Your engine can start to stumble or sputter when this part is starting to go bad. This will happen when the vehicle is running. When you start your car, it is possible for the vehicle to stall out shortly after. Rough running can also happen as a result of a faulty fuel pressure regulator.
