[Audi S5 2009 V8 4.2l] Front subframe adjustment
AudiS5 Jun 24, 2018
  1. AudiS5
    AudiS5 New Member
    9
    Hello
    How to adjust the front subframe?
    Do I have to lift the enginee?
    Wysłane z mojego SM-G950F przy użyciu Tapatalka
  2. Avatar
    Google AdSense Advertisement
  3. irowpod
    irowpod Member
    82
    10
    No you don't.There are mainly 16mm bolts and don't hold the engine nor gearbox. Within the subframe sits the steering rack.
    Easy job,doesn't take too long with a power tool.
  4. AudiS5
    AudiS5 New Member
    9
    Are talking about the B8?
    In B7 the subframe is easy to be moved but when I tried to I was not able to move it even 1mm...
  5. irowpod
    irowpod Member
    82
    10
    I mean B8 subframe, is that what you were asking about?
  6. AudiS5
    AudiS5 New Member
    9
    Yup, I am talking about the B8.
    So now I am confuzed.... Tried to move the subframe and nothing!
  7. irowpod
    irowpod Member
    82
    10
    Hope this helps.
    Old subframe I took up, it has 12 main bolts to take off.
  8. irowpod
    irowpod Member
    82
    10
    [​IMG][​IMG]
    You also obviously need to take off the lower wish bone or loosen it for dome slack.
    By the way, why do you need to move it?
    If its not warped nor bent, its easier to get a proper laser realignment than fiddle with the subframe.
    With a power tool its not a long job though.
    Regards
  9. AudiS5
    AudiS5 New Member
    9
    I have googled the subframe that looks like mine.
    I remember to untighten 8 bolts only (marked).
    Is it the same subframe? Can you mark all the bolts?[​IMG]
  10. irowpod
    irowpod Member
    82
    10
    The B8 subframe is the same for the cars, only difference is where you mount the engine mounts when putting it back on an A4/A5.
    Unscrew all 12 bolts to make it move . I took pictures and make them for you.
    Best go back and release the 12.
  11. AudiS5
    AudiS5 New Member
    9
    I hope I did it (spent around 5h under the car...).
    I will check it out and let you know the result on Monday :)
    irowpod likes this.
