Audi S3 8V US Style Indicators Enabling and Disabling Via MMI?
Zeb Aug 18, 2018
  1. Zeb
    Zeb S3 OF
    Hi there fellow members...
    I have a query to ask if anyone can help me out. So basically i have put the us style lights and they are working but i would like to enable a menu which allows me to turn it of or on at anytime. There is a video on YouTube demonstrating this where the person turns it of via the mmi menu. If anyone can help me out by telling me how i can actually enable and disable the us style lights via the mmi. I will link the video below so you get a better understanding of what i mean.
    Thank You
    Kinds Regards Zeb
  2. Avatar
    Google AdSense Advertisement
  3. RJ-8V
    RJ-8V Active Member Team Daytona Audi A3 S-line owners group
    589
    149
    43
    Will come back tomorrow on it. You have to change some adaptions. Will post it tomorrow.
    A3 8V Facelift Limousine
  4. Zeb
    Zeb S3 OF
    Thank You for that i will be waiting.
  5. RJ-8V
    589
    149
    43
    Make sure you have a backup. To log your adaptions with vcds during a session, do the following.
    Start an Autoscan, let it run, save it but don't close it! Open de modules from the gateway list on the right colum (dubble click on a module to open it). Then do whatever changes/adaptions you want and it will automatically save it in your logfile.
    Ok now the coding. This works for the A3 with xenon headlights, but still you need to check everything. Use the latest original vcds version and use the searchbox for the adaptions. For Leuchte 0 BLK VL, i use the searchterm "BLK VL"
    Module 09 > Coding > Byte 06 > Bit 7 activate
    Module 09 > Security access: 31347 > Adaptions>
    -Innenlicht Leuchtenkonfiguration-Ambiente_Applikationsleisten_in_Instrumententafel" > installed
    -Innenlicht Leuchtenkonfiguration-Ambientemenue mit globalem aus" > Active
    -Leuchte 0 BLK VL B36-Lichtfunktion A 0" > "Ambientelicht 1"
    -Leuchte 0 BLK VL B36-Dimmwert AB 0" > fill the value in of how bright the US lights max should be...mostly 30%, so fill in 30
    -Leuchte 0 BLK VL B36-Lichtfunktion C 0" > "Handbremse ist angezogen"
    -Leuchte 0 BLK VL B36-Lichtfunktion D 0" > "Innenlicht"
    -Leuchte 0 BLK VL B36-Dimmwert CD 0" > "0"
    -Leuchte 0 BLK VL B36-Dimming Direction CD 0" > "minimize"
    -Leuchte 0 BLK VL B36-Lichtfunktion F 0" > "Blinken links Hellphase"
    -Leuchte 0 BLK VL B36-Dimmwert EF 0" > "100"
    -Leuchte 0 BLK VL B36-Dimming Direction EF 0" > "maximize"
    -Leuchte 0 BLK VL B36-Lichtfunktion H 0" > "Blinken links Dunkelphase"
    -Leuchte 0 BLK VL B36-Dimmwert GH 0" > "0"
    -Leuchte 0 BLK VL B36-Dimming Direction GH 0" > "minimize"
    -Leuchte1BLK VRB20-Lichtfunktion A 0" > "Ambientelicht 1"
    -Leuchte1BLK VRB20-Dimmwert AB 0" > fill the value in of how bright the US lights max should be...mostly 30%, so fill in 30
    -Leuchte1BLK VRB20-Lichtfunktion C 0" > "Handbremse ist angezogen"
    -Leuchte1BLK VRB20-Lichtfunktion D 0" > "Innenlicht"
    -Leuchte1BLK VRB20-Dimmwert CD 0" > "0"
    -Leuchte1BLK VRB20-Dimming Direction CD 0" > "minimize"
    -Leuchte1BLK VRB20-Lichtfunktion F 1" > "Blinken links Hellphase"
    -Leuchte1BLK VRB20-Dimmwert EF 1" > "100"
    -Leuchte1BLK VRB20-Dimming Direction EF 1" > "maximize"
    -Leuchte1BLK VRB20-Lichtfunktion H 1" > "Blinken links Dunkelphase"
    -Leuchte1BLK VRB20-Dimmwert GH 1" > "0"
    -Leuchte1BLK VRB20-Dimming Direction GH 1" > "minimize"
  6. Zeb
    Zeb S3 OF
    Hi pal, I can’t see to find the menu i have followed all the instructions as showed but i can’t find the menu in the car systems settings. Thank You
  7. RJ-8V
    589
    149
    43
    Reset your mmi. It should be under ambiance lighting. Do you have footwell lights?
  8. Zeb
    Zeb S3 OF
    Hi have done the rest and can’t seem to find it in background lighting what is it i am looking for? Also i do have footwell lights
  9. RJ-8V
    589
    149
    43
    It should be just like in the clip you shared
  10. Zeb
    Zeb S3 OF
    This is what my menu looks like...
  11. RJ-8V
    589
    149
    43
    Try to lower "door" and check what happens.
    But are your US lights active now?
  12. Avatar
  13. Zeb
    Zeb S3 OF
    Hi my indicators are not working at all and I lowered the door light and it was just changing the door lights. So is there a solution for this. Thanks
  14. RJ-8V
    589
    149
    43
    Do you have xenon or led? Just change everything back. Like i said, check everything. I applied this 3 times on a PFL with xenon
  15. Zeb
    Zeb S3 OF
    I have changed everything back to normal and these are xeon headlights and its a 2015 model audi s3 8v. Im not sure what has actually gone wrong as far as i am aware i have done everything according to your instructions.
  16. RJ-8V
    589
    149
    43
    I will check later for other codings. As you may have noticed, it is not an easy one. It varies from car to car.
  17. Zeb
    Zeb S3 OF
    That’s fine pal. Its an audi S3 8v 2015 so if you can check for that and get back to me on it. Thank you
