I had a brief mis-fire on startup this morning, so I booked in to the dealer for coolant loss.
The service manager said that they had seen a few coolant loss cases now, but no action or fix yet.
Also booked in for a couple of other un-related faults (Pre-Sense, ACC)
interesting topic guys....my wife borrowed mine recently while i was away and on landing she called me to say she was "broken down" (it had done about 1,000 km's)....the radiator warning light and message was telling her to stop...so she got some help from some locals who threw in some water then waited and waited and finally had to get a tow to the audi garage. i went to pick it up and they had no explanation other than the coolant had gone below the level of the sensor....when i asked why they said maybe it hadn't been filled up properly before giving it to me. i still don't buy this and now i have read this thread even less so....i am monitoring also when cold....and heading to the salesperson on the weekend to get a better explanation....
OK
Turns out there is a TPI for S3's losing coolant
(or on the TPI, it's titled air getting into the system)
Procedure is to fill to correct level at MAX then pressure test to find out where it's leaking.
If no pressure drop detected, no warranty process, return car to customer and ask them to monitor.
Here's the interesting bit:
The MAX level is not the top line, but about 1cm higher than the top line.
Both the tech and I were surprised at the illustration in the TPI
I can only guess that this is Audi AG's attempt at a higher level, to eliminate possibility of air getting in, or air locks.
I recall some posts about forum members complaining that the dealer was overfilling the coolant - perhaps not !
I've said that as long as my dealer or Audi UK keep me supplied with G13 coolant, I'l accept the situation and monitor.
Mine miss fires when ever I sit in a lot of traffic for a long time this is the second time she's going in to audi now but when it misfires I get EPC light and engine management come up any ideas thanks
Sorry if this is a stupid question.. but I've noticed on a cold start that when I move off the car stutters and judders between gear changes. Is this misfiring ? I ask because I also have the coolant loss problem which will be investigated when the car is serviced next week !!
not sure of anything to be honest....been trying to find the TPI which I understand refers to "air in the system" so changing the water pump seemed illogical anyway but it has changed the way my car starts up now so no complaints there....but it baffles me why there is no fix to this problem@PanamaS3, are you sure it´s just that piece in the water pump, i also have changed it last year and still have the consumption problem.
The last time i filled it was one month ago, and filled it to the plastic mark of the water pump (over the MAX), and yesterday i saw it between the MAX and MIN. Maybe i will try to change it again with the guarantee.
Thanks veeeight, it's a pretty crap club eh! Hoping I dont join the cold start 1st to 2nd gear lurching club next.Welcome to the club
Depressing, isn't it.
There are more coolant loss related threads in the FAQ, if you haven't already found them:
http://www.audi-sport.net/xf/thread...-on-the-8v-chassis.198794/page-2#post-2287022
I haven't had anymore problems (touch wood) since my last post....but I did top it up a little bit with water the other day just for good measure.Updating: second water pump changed last week. Leaking detected in a certain piece of the water pump. At least the warranty was applied without complaining (i have the DTUK FSR). Expecting to return to dealer just for the next service and not to refill it again.
Yes you can have a new carUPDATE also.
The leaking continues with the 2nd pump, i haven´t bring it to the dealer because i´m waiting the check light to pop up.
Can i get a new car? haha
UPDATE:
Came back from 3 week holiday and checked my coolant tank. Totally empty.
Took it to Audi for fill up and they gave me a full bottle of G13 to monitor/top up..
Don't forget to dilute the G13 !
As always v8....a veritable bottomless pit of useful practical advice.... I think its 50/50 anyway G13/distilled water....cheers!Depends which climate and country you are in, the ratios are on the reverse of the peelable label!
Do you think it could be due to cylinder head expansion as my dealer here suspects?Mine is still disappearing like Lord Lucan.
Dealer has no idea where it is going.
