Hello,
I'm currently on the standard S3 suspension and height which is 12mm lower than the A3, I'm planning on dropping 25mm later this year with the H&R springs (I'll remove the rear arch screws). I've got a set of TD 1.2 alloys on which are 5x112/18''/8J/ET45 running Michelin PS4's 225/40/18.
The front looks spot on sitting perfectly flush, however the rears are still not sitting wide enough for my liking so I'm opting for either 12mm or 8mm spacers (as I'm wanting to drop by 25mm and alloys are 8J not 7.5 like most people on 12mm it seems).
Longer bolts might be required apparently, therefore please can someone confirm what I require regarding:
Thanks.
- Bolt Type Radius/Tapered
- Thread Size 25/28/35/41/55mm
Thanks.
