Sounds like it could possibly be a fuel injector issue. Get them out the car and sent to R-Tech who will test and clean them and if needed they can repair them.
Any fault codes? Quite possibly fuel pressure issues. You need to check for fault codes and look at real time measurements Running the engine lean is not good and should be avoided. If you have to drive the car take it easy .
Did you replace the plugs ? and what condition are they in this can tell you alot and possibly locate what cylinder has an issue I would be covering basics first
Haven’t checked my DV as I didn’t know these have faults. I read the car with vagcom laptopHave you checked your DV for tears as these can fail even on stock boost?
Strange that you're not getting any fault codes - did you check with vcds or a generic fault code reader?
Replace the spark plugs, coil packs,Have you checked your DV for tears as these can fail even on stock boost?
What are you checking the codes with as ideally you need vcds and not a generic hand-held reader.I plugged into the car and not getting any faults
Im using vcds to read the car, I had the car put on a rolling road last week the car is running 333BHP and 363FT LBS but the only hardware the car has is a oversized induction kitWhat are you checking the codes with as ideally you need vcds and not a generic hand-held reader.
