  2. Dismiss Notice
Audi S3 (57' Plate/BHZ Engine) - Clutch kit
scotty dugg Oct 27, 2016
  1. scotty dugg
    scotty dugg Active Member Silver Supporter Audi S3 quattro
    223
    59
    Hi all,
    Clutch on my S3 needs replaced, along with my turbo, sourced a turbo but need to get a clutch kit sorted out.
    Had intended going Sachs uprated organic, but with everything else being done, financially it's not viable.
    So where's the best place to get standard clutch kit? and is it possible to fit a facelift clutch as I'm told they last longer?
    Cheers all,
    Scott
  2. Avatar
    snack-media
    Advertisement
  3. dg-1984
    dg-1984 Active Member Team Daytona Sportback S-line owners group Audi A3 Manual
    473
    89
    I know it's alot £560 for sachs clutch kit with no DM flywheel and £800-850 with DM flywheel but if planning to go stage 1 or above will be needed.
    And don't want to have to pay the labour twice if do want to upgrade later.
    Just need to search website and see what deals are running, euro car parts will do it and they are also on ebay and cheaper on there sometimes. If you have a garage you use can ask them to price it up so the full thing is warrantied.
    scotty dugg likes this.
  4. scotty dugg
    223
    59
    Cheers mate, yeah £860 for the sachs unit all in, going to price standard against it and see if there is much of a saving. In all honesty I don't see myself going past Stage 1 if that.
    I'll check out euro car parts, hopefully they've another end of month 20% off!
  5. scotty dugg
    223
    59
    CLUTCH PLATE
    FLYWHEEL
    FLYWHEEL BOLTS
    CLUTCH SLAVE CYLINDER
    £639.46 for all of those parts, but I'd need a new release bearing and may as well change the master cylinder (or whatever it's called) all at the same time.
    30% off some of those parts.
    What else would I need? Hoping all those parts are correct.
  6. smurfworth
    smurfworth Well-Known Member Audi S3
    2,031
    569
  7. scotty dugg
    223
    59
    smurfworth likes this.
  8. smurfworth
    2,031
    569
    Use code CP15LESS for £15 off final price too
  9. dg-1984
    473
    89
  10. dg-1984
    473
    89
    Wondering if you can just do multiple orders and use the code each time and save even more..
  11. smurfworth
    2,031
    569
    Don't see why not
  12. Avatar
    snack-media
    Advertisement
  13. scotty dugg
    223
    59
    Cheers guys, even better prices, saved me a small fortune!
    smurfworth and dg-1984 like this.
  14. dg-1984
    473
    89
    I don't know if you had the friction plate on your list..
    I actually saw amazon had the Sachs friction plate and pressure plate, don't know if they still have them.
    Here is the part number I have:
    Organic plate 881864 999502
    Pressure plate 883082 001394
    Slave cylinder 3182 600197
    DM flywheel 415033110
  15. scotty dugg
    223
    59
    Cheer mate, checked the flywheel out, will hopefully be able to order parts tomorrow. Cars booked in for the work next week.
    dg-1984 likes this.
  16. dg-1984
    473
    89
    So you going upgraded route then?
    How much you been quoted for the fitting?
    Still need to get mine done.
  17. scotty dugg
    223
    59
    For now just going the standard route, been quoted £290.00 all in if I supply all the parts. Which is ridiculously cheap! £800.00 was the next cheapest.
    Once I get a list of parts out together I'll post it up.
