Hi I’ve been told if it was the actuator it would be in limp mode no engine management light it’s just boosting so late where is the pressure control valve thanksHave you checked the pressure control valve and lines that go to the turbo actuator ?
Ok thanks bud I will check first thing in the morning and let u know much appreciated.Take the cover off and it’s on the right hand side of the engine where the timing chain is at the top.
It’s got a multi plug and vacuum lines coming off it.
Check it and all the vac lines are intact / connected properly.
Scanned it today no faults at all what so ever it’s just puzzling as it has a full scorpion exhaust with no cat it’s got a airtec intercooler so must have been remapped as when a cars cat has been removed in order to remove the engine management light u have to get it remapped and I don’t know who the previous owner is as it was purchased through a auction site it does boost but really late and can get full potential as too many cameras and the roads which can be used u seem to run out of road before it starts boosting it thus makes sense thanksNeeds a scan with VCDS too.
Had a look this morning all look intact palOk thanks bud I will check first thing in the morning and let u know much appreciated.
View attachment 258917I’ve took this pic just now can u see the metal pipe where my finger is does that connecti to sontjing or supposed to be like that
What attaches to this a rubber pipe or plastic cheers budThere’s your issue. There’s no vacuum line on it.
Ok let me see if I can solve this problem
There’s no pipe at all completely missing from the turbo
I’ve just rung my friend he might have the part for me he’s just checking see how I get onOh dear. Recent purchase then ? If so I’d be on the blower to whoever you bought it off.
Scandalous to sell a car in that condition, Christ no wonder it’s not boosting.
Do u know what this pipe is called pleaseYou are missing this…..
It was purchased through a auction so have no contact details for the previous owner cheersMight have the part?! Speak to the person you bought it from as others have said. Should not have sold it in that state.
TX.
Hi is this off the latest rs3 shape or the one before cheersYou are missing this…..
Hi is this off the latest rs3 shape or the one before cheers and does it have any sort of clips to hold it in place thanks
And what
And what
It’s fixed to the turbo elbow by a small bracket and screw.
