Audi Q3 climate control
Ironborn
English...not so good
Bristol
Come a cross this video, looks tasty. If it's not 100 % compatible, how badly could it mess up my heating?
I have this in my 07 except the heated seats, then i just fart ;)
Reactions: Ironborn
It's the same no heated seats, also my wheel is on the correct side ;)
It was standard in the car, not retrofitted
lol this guy, not sure if your trolling me or not lol. How can a Audi Q3 climate control, come standard on a A3
My climate control is identical to the one you have posted the video off, only difference is i don't have heated seats, so don't have them buttons.
It isn't though. The knobs are different - no chrome on yours, the buttons are marked differently (yours says econ, the Q3 one says AC) I suspect the colour of the temp display's different too.
OP - I think later A3s (2010/11) may have this panel - maybe someone can confirm?
Ok, point taken, identical apart from them few differences lol
Ok cool cheers, I liked the white display it would match the white dis perfectly.
I've done this and it's working almost perfect except one foult code:
It can not be cleared :(
Address 08: Auto HVAC Labels: None
Control Module Part Number: 8U0 820 043 B HW: 8U0 820 043 B
Component and/or Version: E87 Klimavoll 0050
Software Coding:
Work Shop Code: WSC 00000 000 00000
VCID: 306B14F3D8E3
Fault Codes have been Erased
1 Fault Found:
00457 - Control Module for Network (J519)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 194
Mileage: 256394 km
Time Indication: 0
Date: 2014.12.21
Time: 10:37:39
Freeze Frame:
ON
Software Coding:
VCID: 306B14F3D8E3
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 194
Mileage: 256394 km
Time Indication: 0
Date: 2014.12.21
Time: 10:37:39
Freeze Frame:
ON
what year is your car?
My car is MY2010 2.0TDI CR CFFB
Before it looked like this:
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 BM HW: 8P0 820 043 BM
Component: KlimavollautomatH09 0150
Revision: 000064 Serial number: 8P0820043BM
Shop #: WSC 00000 000 00000
VCID: 78FBECD37013
No fault code found.
How about your central electronics, part number, sw, hw, etc.?
Maybe mine doesn’t recognize newer climate control unit from Q3?
My central electrics control module is pre-BCM but in a MY2009 8P3.
Code:
Address 09: Cent. Elect.  Labels: 8P0-907-279-30-H.lbl
  Part No SW: 8P0 907 279 N  HW: 8P0 907 279 N
  Component: Bordnetz-SG  H54 2801
  Revision: 00H54000  Serial number: 00000009360286
  Coding: 95A823A1B4141380EF00001C0000000000094C056401800B006800000000
  Shop #: WSC 00899 210 89553
  VCID: 489B20EE3B73D761E7B-801D
  Subsystem 1 - Part No: 8P2 955 119 F  Labels: 1KX-955-119.CLB
  Component: Wischer AU350  H10 0040
  Coding: 00056595
  Shop #: WSC 00899
Climate info
Code:
  Part No SW: 8U0 820 043 B  HW: 8U0 820 043 B
  Component: E87  Klimavoll  0050
  Revision: 00H03000  Serial number: 8U0820043B
  VCID: 306B680EA3E37FA1DFB-8065
I guess, there’s no solution for that :( or maybe there's but I don't get it.
I did same screenshots of measuring blocks, and everything seems to be right. Maybe there is an adaptation or basic settings that can be adjusted. What do you think?
1 2 3 4 5 6 7 8
i'll check mine but update your vcds to the latest version
I can not update vcds cause I have old interface cable.
I replaced leds from red to white and put also white filter in it. But after that LCD has white text with blue backlight. Looks like thisImages
LCD in Audi A3 has dark blue colour while Q3 has dark brown (almost black).
Software Coding:
VCID: 306B14F3D8E3
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 194
Mileage: 256394 km
Time Indication: 0
Date: 2014.12.21
Time: 10:37:39
Freeze Frame:
ON
Hi, sorry to bring this thread up again but was wondering if you ever found a fix for this fault code. I have fitted a Q3 climate and seem to get the exact same fault code but no way of clearing it with VCDS. Other than that it functions perfectly.
that error is saying that it cannot talk to the main central electrics module. Its not a VCDS coding thing, its a wiring thing.
In order to resolve the error i would guess that you need to wire in a pin from the back of the climate control to the CEM but which pin i haven't a clue as if it was an A3 requirement then it would already have the pin there.
Seems to be something that the Q3 needs and so its asking for it. As you said its working perfectly, i would just ignore it.
Reactions: landrover1
Unfortunately not, there is no fix for that. I checked wiring in ELSA and it seems to have exact the same pin connection on both A3 and Q3. I think that’s CEM issue, and firmware itself which doesn’t have codding for newer CCM comes from Q3.
308
101K
720
