  2. Dismiss Notice
Audi instrumental cluster fault no immo/key not detecting batter drain and not remote locking.
SlickZk May 1, 2020
  1. SlickZk
    SlickZk New Member
    9
    Please can someone help alarms going of hazards battery drain, no lights on the numbers on instrument cluster no signal indications working on the dash, key not syncing using method. Lights on the climate control on after switching car off causing it to drain the battery. I think I hurt the cluster I accidently for a second connected to negative before the positive can this be possible?
  2. Avatar
    snack-media
    Advertisement
  3. pauldazzle
    pauldazzle Well-Known Member
    1,323
    116
    Yes you probably ****** the cluster, & the Central Convenience Module. Diagnostic with VCDS/Vagcom should reveal the issues.
    SlickZk likes this.
  4. SlickZk
    SlickZk New Member
    9
    Yes I am getting fault codes 01317 j285 and 00474. It was interment before. I think the ccm is OK because the lights are working no funny business in the interior lights or windows. What do I do. Just solder the cluster maybe?
  5. NHN
    31,467
    2,258
    What exactly did you do?
    SlickZk likes this.
  6. SlickZk
    SlickZk New Member
    9
    Before it was interment the signal indications on the dash weren't lighting up. The signals are fine on the outside. Now they are fully gone along with the key not working and the climate control unit lights staying on. I keep getting codes in the dashboard and ccm setting on a xtool 401. I don't know if it's the ccm or the cluster itself. I know I had a bad battery kept using jump cables until the new battery installed and now fully gone. Thanks for replying
  7. NHN
    31,467
    2,258
    As I asked, what exactly did you do, as in with the cables as you've not really been specific, what did you connect wrong.
    SlickZk likes this.
  8. SlickZk
    SlickZk New Member
    9
    Sorry mate so I connected the black terminal for a split second first then realised and took it off straight away. yes it sparked. Then connected the right way, started the car was fine. Until the night realised the climate light is on and it's draining battery. Along with the car alarm.so I left it unlocked. the next day battery was dead I had to jump start. New battery BTW. Then from there the same problem as mentioned. I have to keep disconnecting the battery so it doesn't die. And to pull the red cable in the trunk to release the fuel cap lol.
  9. SlickZk
    SlickZk New Member
    9
    Problems: key not syncing. changed batteries,Can't use remote. The cluster lights and signals not Lighting, only the needles and time/mileage are Lit. The heater/climate control unit lights on after switching car off. Alarms going off. With hazards until its unlocked. Everything else is fine.
  10. SlickZk
    SlickZk New Member
    9
    Any information on this? Will appreciate it I don't want to get robbed by dealer ship if I can fix myself lol
