Evening,
I have a early B8; it was a Audi Press car so has every option going at the time. one of which is the Audi hill-hold assist. Now Its great and very useful exprecially in traffic however the early cars from research do not hold onto the fact its turned on and loose the setting when you turn the car off. It seems ridiculous you have to press the button under the handbrake to arm it each time I start the car.
Now from VCDS I've managed to code it to default on drive select to individual; has anyone found a solution to this hill hold issue? (another oversight from and it did not remember what it was last set at only fault to auto for ADS).
Im aware the behaviour was changed in later years to remember in memory if you have the hold assist on until you disarm it. Can anything be forced on VCDS or is it a hardware change that can't be done without changing a module.
Mark.
Mark.
