Rear ones heat up with a hair drier then use dental floss to cut through the glue then use auto Glym tar remover to remove any left over adhesive.
Front ones use a couple of flat screw drivers to carefully prise them out. There are 8 securing clips which are quite brittle, 3 of them broke when I did mine but I was replacing the badge anyway
My rear oooo's pulled of by gently prising it off, it was hot though! Front with screw drivers and some old rag. I broke a couple of clips as well but was also replacing it.
