  2. Dismiss Notice
Audi B8 LED reverse lights
t8ups May 26, 2017
  1. t8ups
    t8ups Site Sponsor Site Sponsor VCDS Map User
    2,175
    944
    Here is a new type of reverse light that I have in now for those that have the OEM halogens.
    They are LED and will be plug and play without the need for coding.
    http://emtuning.co.uk/product/emt-10c/
    Discount code summer15 for discount until Monday night. - 15% off.
    will work on PRE FL and FL cars.
    ruairi83 and V6_Man like this.
  2. Avatar
    snack-media
    Advertisement
  3. DeanoC
    DeanoC Well-Known Member VCDS Map User
    840
    838
    93
    Much different to the ones i have mate?
  4. t8ups
    2,175
    944
    They are more powerful than the Cree3 ones Dean so a good upgrade even on that. Will work on your C7 too.
    Trups
  5. DeanoC
    840
    838
    93
    Nice. Can i keep that coding change i had to do to with these?
  6. Gazwould
    Gazwould Well-Known Member
    7,292
    2,983
    I thought cree were more powerful than smd , as the link is for smd sidelights .
    Legoland aesthetics won't look well in the clearer less fussy lenses .
  7. t8ups
    2,175
    944
    yes, you wont need to revert back.
  8. t8ups
    2,175
    944
    Times are moving bud..
    ruairi83 likes this.
  9. V6_Man
    V6_Man Moderator Staff Member Moderator Team Glacier Supercharged TFSI Owners Group Team V6 VCDS Map User Team Scuba Audi S4 quattro Audi A3 Black Edition
    6,910
    13,947
    Hey @t8ups , believe these are the same as the ones I got the other day :cry:
  10. jdp1962
    jdp1962 Grumpy Old Man TFSI Owners Group Team V6 Gold Supporter Team Tornado Audi S4 quattro Black Edition S tronic
    9,575
    4,200
  11. ruairi83
    ruairi83 Well-Known Member Team Sepang quattro Audi A4 Black Edition
    1,808
    601
  12. Avatar
    snack-media
    Advertisement
  13. t8ups
    2,175
    944
    They are.
    Maybe be a good time to finish up the rest or get the b7 kit you wanted :)
    V6_Man likes this.
  14. t8ups
    2,175
    944
    Reverse ones, can be used as sidelight on cars also, I'm working on getting the site amended.
    jdp1962 likes this.
  15. Gazwould
    7,292
    2,983
    Lumens ?
    t8ups likes this.
  16. holmefield
    holmefield Active Member
    635
    79
    Would these work on a 2013 facelift Audi A5?
  17. t8ups
    2,175
    944
    As reverse lights yes
  18. t8ups
    2,175
    944
    Not had a chance to test them but the once i have recomended in this post are 3 times brighter than the oem halogen.
    You wanting them for sidelights?
  19. marv
    marv Member
    280
    Do you need to do any coding or these have blockers built in to them
  20. holmefield
    635
    79
    Hi thanks for replying so even thou on the link it says sidelights these work fine as reverse lights in my A5?
    These are the ones the link takes me to...EMT 10+C
    If yes i'll order some today...cheers
  21. Gazwould
    7,292
    2,983
  22. DeanoC
    840
    838
    93
    Reverse and sidelights are the same colour and fit so they work for both
  23. Zafi
    Zafi Well-Known Member
    1,299
    331
    Yeah, but reversing lights are designed to illuminate the way when reversing, sidelights are for non dazzling parking use.
    I have tried a few LED/SMD/CREE so called bright white bulbs and they are all no use for seeing what's behind the car when it's dark.
    If technology has moved on and these are better than the standard filament bulbs in a B8.5 at showing what's behind the car when it's dark I will take a pair.
  24. DeanoC
    840
    838
    93
    I have the previous gen ones from trups and they are noticeably better on the rear view camera.[​IMG][​IMG]
    t8ups likes this.
  25. t8ups
    2,175
    944
    Reverse lights are designed to warn others that your reversing, its a signal, on old cars they where not made to illuminate the way for reversing. The Audi's have a very small reflector and lens/opening, you could put a LED with 25 LEDs in there, it will look like a blob of light and actually perform no better than one with 5 leds.
    The ones I have are done so they sit better in the holder and sit where the filament needs to be to use the OE optics. when you get a bulb that has 20 LEDs only 3 of the 10 may catch the reflector.
    I don't have a B8 to do output shots on but my C6 uses these so il bring some home later and get some fitted to it and do before and afters.
    Trups
    ruairi83 and Carlos85 like this.
  26. Zafi
    1,299
    331
    I'll stick to left foot braking to illuminate my reversing then, the brake lights are way brighter than the reverse lights.
  27. Gazwould
    7,292
    2,983
    If the B8 has a small lense and opening wouldn't a bulb with also a projector at the front be better ?
  28. t8ups
    2,175
    944
    I find this helps more than reverse lights lol. The NEw cars like Mercs and even the newer Audis come with LED lights, but the optics are designed for this purpose with more functionality in mind.
    I don't think it will make too much difference, if you utilise the reflectors in there in the right way it should be more than enough, lighting a LED up with a projector lens is brighter out the car, once fitted you can expect upto 10-15% loss of the focus through the plastic lens.
  29. t8ups
    2,175
    944
    Here are the pictures I took.
    Pics taken on IPhone 6, no filters/no exposure drops or flash.
    Before
    After-
    And fitted in the lens, they don't look like a Lego Tower at all Gaz youll be glad to know :D
    So MY review and I am not been biased, they worked better than I was expecting, I am always open minded but was not expecting that outcome, and better yet they have worked Error free on the C6 so was even happier lol.
    JG51 AUD and V6_Man like this.
  30. V6_Man
    6,910
    13,947
    Cheers @t8ups and taking the time to explaining it to all. Its a beast you've got
    Not sure why people start discussing things not worth discussing. We are talking about whether or not spending under £20 for lights is sensible but won't think about £2k on remapping - strange world. In the end if it doesn't work, well, it doesn't work.
    t8ups likes this.
  31. Gazwould
    7,292
    2,983
    Good result , like I said earlier the lego asthetics might not look good in a clearer lense .
    I've got coming today the ones I linked , it's for a non VAG with clearer reverse lenses .
  32. Gazwould
    7,292
    2,983
    Happy .
