Audi B5 1.8se
tony birch Feb 16, 2019
  1. tony birch
    tony birch New Member
    Hi wondering if you guys could help ,looking to buy a S4 milltek rear exhaust box and fit it to my 1.8se avant 2000.
    its off a saloon S4
    question will it fit on the hangers I will get the pipe work behind sorted to go into my original system .
    Thanks tony
  2. Avatar
    Google AdSense Advertisement
  3. Rfmacaskill
    Rfmacaskill Member
    130
    I had a custom exhaust made for my B5 TQS saloon which I then transferred to my S4 Avant...so yes it should be a straight swap over.
  4. tony birch
    Ok thanks ,the worry I have is the Quattro to fwd ,your was Quattro to Quattro. Floorplan boot spare wheel well .Its only £80 so might just buy it and see.
  5. Rfmacaskill
    Rfmacaskill Member
    130
    Good point...I’d imagine the Quattro tunnel is a good bit wider to accommodate both the driveshaft and exhaust.
    Good luck!
  6. Avant1
    Avant1 V6 Grunt
    59
    The fuel tanks are different too
  7. aragorn
    18,738
    901
    Quattro exhaust is completely different to a FWD car.
    The FWD exhuast loops up over the rear axle, and has its mid silencer on the drivers side.
    The quattro exhaust goes under the subframe and has its mid silencer on the passenger side.
    Even the backbox itself sits much further rearwards on a quattro car. Its all just completely different.
