Bring it to me Daniel, i can do it for you... You might need the bracket + fitting kit from dealer, the bushes are made of aluminium so they corrode badly which means they break on removal...
Don't know the part numbers but you can go to local dealer, they should be able to print the diagram for you then if you post a picture of it i would advise you which one to get...
hi mate found this online through a forum, am beginning to suspect due to corrosion most of the bolts might have given way as its seems to be a common problem, but then again am happy to have a second opinion from you ,so i might pass by and you can have a look sees what you make of it.
