Audi a8l 3.0tdi j17 location
Jpderv Jun 23, 2018
  1. Jpderv
    Jpderv New Member
    9
    Hi folks looking some help few weeks ago my a8 stopped and would not start checked pipes going into the high pressure pump and there was no fuel in them so suspected in tank pumps.
    If I supply power to the 2 pumps in the tank the car will run and drive about happily.
    After some digging about on the internet I found out that it's a j17 relay that supplies the pumps with power I tried looking everywhere and for the life of me I cannot find this relay.
    Does anyone know where it's located because I checked under the ECU kick panel on drivers side RHD checked in the boot can't find it anywhere.
    Interestingly when scanned with vcds there was only a few glow plug faults that's it really.
    I'm puzzled it's such a nice car to drive I know all I would have to do is run a switched positive to the pumps and it would run but I'd quite like to get it figured out.
    Thanks in advance.
  2. Avatar
    Google AdSense Advertisement
  3. Stokka
    Stokka Active Member
    101
    42
  4. Jpderv
    Jpderv New Member
    9
  5. Stokka
    101
    42
    It's worth a look mate, I imagine all the fuse and relay positions to be more or less the same
  6. Jpderv
    Jpderv New Member
    9
    I fell a bit silly now I was expecting to see J17 written on the relay but there just numbers I have found that on some a8s it's a 208 relay and on others it's 372 relay so with that information I should have a better chance of finding it now.
    Thanks for the info buddy
  7. desertstorm
    desertstorm Moderator Staff Member Moderator VCDS Map User TDi Audi A4 Audi Avant Owner Group quattro
    7,012
    3,401
    What year is the car ?, apart from the relay it will be fused and there are probably several fuse boxes spread around the car.
  8. Jpderv
    Jpderv New Member
    9
    It's 2006 Audi A8 3.0 TDI I have checked 3 fuse box locations but so far none of them appear to have anything related to the fuel punp having said that if my fuse finding is anything like my relay finding I may have to give it a once over again lol.
  9. desertstorm
    7,012
    3,401
    Looking at the wiring diagram there is a 20A fuse located in right rear boot area.
    The relay is also located in the boot area if your engine is an ASB or BVJ it's the relay marked 3 .
    Fuse box located in area marked 7/8/9
  10. Jpderv
    Jpderv New Member
    9
    Pretty clear instructions there thanks buddy I'm bound to get to the bottom of the problem now will be sure to keep you guys updated.
  11. Jpderv
    Jpderv New Member
    9
    Bit of a depressing update sweated my nutts off in 35c temperatures and still can't find the relay removed glove compartment nothing in there removed panel underneath steering wheel unrelated relays in there pic included also checked in the boot I did find a 40a fuse but that was fine also in related relays I'm at a lose
  12. Avatar
  13. Jpderv
    Jpderv New Member
    9
    This is the RHS below steering wheel
  14. Jpderv
    Jpderv New Member
    9
    This is the trunk below the glove compartment
  15. desertstorm
    7,012
    3,401
  16. Jpderv
    Jpderv New Member
    9
    Nope I already checked in this locations and the relay I am looking for isn't there the problem is everyone keeps giving me information for 4.2 gas a8 mine is diesel 3.0
  17. desertstorm
    7,012
    3,401
    The information I got from Elsawin is for an ASB or BVJ which are the 3.0 TDI and 4.2 TDI models. Yours should be an ASB. There isn't going to be any great difference in the fuel systems for a 3.0 TDI and 4.2 TDI engine.
