cwhi4285
Audi A6 C5 2.5 TDI V6
- Joined
- Aug 31, 2014
- Messages
- 21
- Reaction score
- 4
Hi Guys,
I'm proud to join this forum.
I have recently acquired a C5 A6 2.5 TDI V6 with a multitronic box.
Bodywork not perfect, but I plan to sort that in time.
I have a problem when I switch to tiptronic mode, it does engage and switches to the "1234..." on the HUD. However, I can't shift up but I can shift down. In gear 1 from standstill it just revvs to the max RPM and doesn't change up, why I change back to "D" to avoid engine damage.
After painstaking research, I have managed to establish that the probable cause is due to a missing magnet! Apparently, if this magnet falls out the system doesn't sense an upshift. I know this is not a problem with the gearbox itself, as I can engage all other gears and D with no judders whatsoever. So I ordered a special magnet from the USA, I need to open up the gearbox cover and install it.
Is this what the probable cause is? Are there any others sensors or things I'm missing?
Also Audi quote that the gearbox oil is "sealed for life", my car is quite high mileage but still functioning perfectly. I'm going to change the oil anyway as I thing Audi are "full of crap" on that, is this the right thing to do?
Also, I took it to the Audi garage for a "check up" and they quoted my ridiculous prices (cam belt GBP 1300) when I can get it done for 500. In particular, they told me that my break pipes were ruptured which could be a problem under heavy braking. I took it to my trusted garage and he inspected and showed me that the pipes were fine!
Has anyone else been lied to in this way by Audi?
Finally, I'm keen on car meets. I used to have a Passat and went to one of their gatherings which was brilliant. Obviously, this would be UK gatherings!
Any feedback/comments on the above would be great, I will be keeping my A6 for some time.
Cheers!
Cheers!
