  2. Dismiss Notice
Audi A6 3.0 S tronic problem
Jonathan Cross Jan 12, 2020
  1. Jonathan Cross
    Jonathan Cross Registered User
    14
    I have noticed for the past 4 months an oil smell when sitting in traffic in D with my foot on the brake however if i shift it into N it seems to stop. It happened maybe once every 2 weeks. I've had it at my normal mechanic and an audi specialist and neither could find any problem or leaks and the oil levels are all perfect. As off 2 weeks ago I've noticed it more often however the car also shuttered for about 2 seconds when taking off from a stand still and there was a kind if rattling noise. Its fine it a couple of times since. I've had it back out at my mechanic and again everything is fine and no signs of a leak. He even plugged the gearbox in with no fault codes showing. The only thing he can think off is the clutches going in the gearbox but that's only an educated guess at this point. Does anyone have any idea before I take it to the audi specialist and he bends me over.
  2. Avatar
    snack-media
    Advertisement
  3. RJ-8V
    RJ-8V Registered User
    749
    184
    43
    update the gearbox and do a calibration
  4. Jonathan Cross
    14
    Whata the odds that this could be a fix? If it's a slime chance I'd rather get shot of the car than keep throwing money at it
  5. RJ-8V
    749
    184
    43
    50% chance. Audi releases a lot of updates for the gearboxes. I update them a couple of times a week :)
  6. Jonathan Cross
    14
    Is this possible to do at home? My mate did say he did the calibration after the gearbox was serviced 10k miles ago I'm assuming he would have done the update to
  7. RJ-8V
    749
    184
    43
    If you have Vcp or odis engineering then you can update it yourself. Do you your current software version of your gearbox? Should start with 4G and then a number. You can check it with Vcds, vcp or obd11
    NHN likes this.
  8. Jonathan Cross
    14
    I can get that for you in the morning. Thanks for the help hopefully it's not as serious as I'm thinking but it's not looking great
  9. NHN
    31,831
    2,350
    As above, a gearbox calibration is advisable, if update is available then dealer will calibrate as part of.
  10. Jonathan Cross
    14
    Sorry folks havnt had a chance to plug the car in today will hopefully get at that after dinner but I was talking to my local audi specialist about doing the update and calibrate and he says he can do it be he is very against doing it as he says it's not a good idea to do so if there is an issue with the gearbox. I personally think he is talking rubbish and just wants to stroke me out of money when it might not be needed but what's your take on this
  11. RJ-8V
    749
    184
    43
    If you have no major errors in your gearbox then it's rubbish talk :)
  12. Avatar
    snack-media
    Advertisement
  13. Jonathan Cross
    14
    Other than the oil smell and the shuttering when taking off from the standstill which has happened 4 times in the past 6 weeks both these things seem to happen after the car have been driven for 30mins or more. Not sure if this is something major or not
  14. RJ-8V
    749
    184
    43
    I meant software errors in the gearbox software.
  15. Jonathan Cross
    14
    Somehow I'm going to have to talk him into doing it even tho he is completely against it for some reason
  16. RJ-8V
    749
    184
    43
    Did you manage to get your current software version and number?
  17. Jonathan Cross
    14
    I had a 5 minute look but didn't come up with anything I have one of them obdeleven pro jobs that connect to your phone and couldn't work out how to get the software version
  18. RJ-8V
    749
    184
    43
    Open the Gearbox module and then Information
  19. Jonathan Cross
    14
    4G1927156B
    Software version 0001
  20. RJ-8V
    749
    184
    43
    The latest version for that number is version 006. What's yours?
    Do you also have your Engine softwareversion? Because it is advisable that the engine software must also be updated when updating the gearbox.
  21. Jonathan Cross
    14
    Dont have the engine off hand now but I'm 0001 for the gearbox so I'm well out by the looks of it
  22. Jonathan Cross
    14
    Engine software number is 4G0907401f version 0004
    No doubt the MMI is in need of updating to along with maps and such. It just seems very hard to find anyone around me willing to do it
  23. RJ-8V
    749
    184
    43
    Latest engine software is 007. Both gearbox and engine has to be updated to the last version. Then check if the problem is gone or not.
  24. QUIGGS2001
    QUIGGS2001 Registered User
    64
    21
    This has intrigued me. I wasn't even aware there was software updates for gearboxes.
  25. RJ-8V
    749
    184
    43
    Oh there are many software updates for almost all components.
  26. Jonathan Cross
    14
    So had the update and calibration Carrie's out yesterday with no luck. The car will lurk forward from a standstill sometimes and when it get warm the odd time it will shudder pretty bad taking off. Looks like I'm in for a massive bill to try and sort a car that's been serviced regularly with only 80k miles
  27. mickyh7
    mickyh7 Guest
    80 k ?
    My Gearbox only had 37 k on it when the Mechtronics box spat the dummy out, and a speacalist quoted £4k to fix it.
    God knows what Audi would have said.
    Got it done for £1400 in the end from a Gearbox place.
    Good luck with yours.
  28. Jonathan Cross
    14
    Such a shame. Love the car and the gearbox is fantastic when it's working right. Dont see myself hanging on to it mich longer with the amount if reports of this happening
  29. Jonathan Cross
    14
    Update on the car. Today it brought up the gearbox malfunction you can continue driving and only goes into 2nd and 4th now. No manual mode and even after turning it off and leaving it go for an hour it pop back up 10 secs after turning car on
  30. mickyh7
    mickyh7 Guest
    Sounds like the Mechronics box. Its fixable. See my earlier post. Recon unit fitted and programmed £1400 ish with 12 month warranty.
