AUDI A6 2008 WIPER ISSUE?
RAY_SMITH
I've recently bought a 58 plate Audi A6 2.0TDi SE Auto DSG, lovely car, however... The wipers work when the key is in the ignition and the electrics are turned on but, the minute the engine starts the wipers slow down and then stop completey.. Can anyone shed some light on this for me please prior to me going to an auto electricain or Audi direct and hemoraging a fortune!!!
Many Thanks
Ray
RoyC
If recently purchased, it should still have some warranty on it.
Take it back to the place where you got it from.
RAY_SMITH
i'm a trader, i bought it as a buy to order for someone, it will have a warranty on it soon, but i can't go burning warranties on cars that are due to be delivered!!!
RoyC
Does anything show up on a VCDS scan ?
RAY_SMITH
control module for wiper
004 - no signal/communication - intermittent
freeze frame
fault status: 00100100
fault priorty: 1
fault frequency: 13
reset counter: 1
Johny2202
Hi, the most popular defect is that wiper arm axle gets stuck. Switch on wiper change position in MMI then switch off ignition and try to move wiper arm with hand it must move very easy if it moves with resistance then it is stuck. To solve this you must change wiper mechanism or stymie it and clean axles with sandpaper and then grease it.
RoyC
freeze frame
fault priorty: 1
fault frequency: 13
reset counter: 1
Does it give a part number on the rest of the scan ?
RoyC
Number 41 is the wiper controle
25%
#NumberDescriptionQty.
list of uses; control unit
1control unit for access and; start authorisation; see illustration:; 909-00
2control unit for tyre pressure; control; see illustration:; 907-50
3engine control unit; see illustration:; 906-00; petr. engine
3engine control unit; see illustration:; 906-05; diesel eng.
4control unit for automatic; headlight range control; see illustration:; 941-25
5onboard supply control unit; see illustration:; control unit 2; 907-00
7cd changers; see illustration:; 035-38
7connection for external; audio sources; see illustration:; 035-38
7chip card reader for road; toll system; see illustration:; 035-57
8interface box with software; see illustration:; 'MMI'; 919-10
9control unit for special veh.; see illustration:; 907-20
10display and control unit; for multimedia interface 'mmi'; see illustration:; 919-00
10sender and receiver unit; for road toll system; see illustration:; 035-57
11door control unit; see illustration:; right front; 959-10
12control unit for movement; sensor; see illustration:; 951-40
13control unit for memory seat; and backrest adjustment; (passenger side); see illustration:; front; 959-20
14door control unit; see illustration:; right rear; 959-10
16control unit for parking aid; see illustration:; 919-20
17control unit for trailer; detection; see illustration:; 945-50
17control unit for; reversing camera system; see illustration:; 907-40
17interface control unit; for vehicle location system; see illustration:; 907-31
17amplifiers; for vehicles with cellphone; preparation; see illustration:; 035-55
18control unit with software for; electromechanical parking; brake -epb-; see illustration:; 615-60; PR-1KD
18control unit with software for; electromechanical parking; brake -epb-; see illustration:; 615-65; PR-1KW
19central control unit for; convenience system; see illustration:; 907-00
20control unit for battery; monitoring; see illustration:; 915-00
21receiver for radio-wave clock; see illustration:; 920-00
22amplifier for sound system; see illustration:; 035-43
23navigation unit with soft; ware; see illustration:; 035-07
24tv-receiver (tuner) with; software; see illustration:; analogue; 035-07
24tv-receiver (tuner) with; software; see illustration:; digital; 035-45
24amplifier for sound system; see illustration:; 035-40; PR-8YQ,8AJ,; 8DN,8DP+8RY
24amplifier for sound system; see illustration:; 035-41; PR-8D2,8DY,; 8DS+8RY
25control and receiver unit with; software for car radio; see illustration:; 035-43
25control unit for digital; radio reception; see illustration:; 035-45
25radio unit; see illustration:; 035-40; PR-8YQ,8AJ,; 8DN,8DP
25radio unit; see illustration:; 035-41; PR-8D2,8DY,; 8DS
26voice module with software; see illustration:; 035-43
26receiver unit for; tv reception; see illustration:; 035-40; PR-QU1,QV9
26receiver unit for; tv reception; see illustration:; 035-41; PR-QV2
27control unit for auxiliary; heater; see illustration:; 819-70
27Acontrol unit for fuel; pump; see illustration:; 919-30; frt.-wh.dr.+; PR-A8S
27Acontrol unit for fuel; pump; see illustration:; 919-32; frt.-wh.dr.+; PR-A8U
27Acontrol unit for fuel; pump; see illustration:; 919-35; quattro
28door control unit; see illustration:; left rear; 959-10
29control unit for memory seat; and backrest adjustment; (drivers side); see illustration:; front; 959-20
30control unit for airbag; see illustration:; 959-30
30interface box; for vehicles with preparation; for telephone; see illustration:; 035-57; "J.."
31door control unit; see illustration:; left front; 959-10
32control unit for telephone; see illustration:; 035-50
33interface box; see illustration:; 'HANDY'; 035-56
34electronic module for steering; column combination switch; see illustration:; 'SMLS'; 953-50
35control unit; control unit for electronic; steering column lock; see illustration:; 419-50
35control unit for vehicle; authorisation system; see illustration:; 419-50
36onboard supply control unit; see illustration:; control unit 1; 907-00
37relay plate and relays; see illustration:; 937-00
37relay plate and relays; water box; see illustration:; 937-20
38abs unit with control unit; see illustration:; 614-10
39control unit; auxiliary heater; see illustration:; 819-70
40combi-instrument; see illustration:; 920-00
41wiper motor with control unit; see illustration:; 955-00
42ignition/starter switch; see illustration:; 909-00
43display and control panel with; cu for electronically; controlled air-conditioning; see illustration:; front; 820-00; PR-9AK
43display and control panel with; cu for electronically; controlled air-conditioning; see illustration:; front; 820-10; PR-9AQ
44control unit for 6-speed; automatic gearbox; see illustration:; 325-80
44control unit for automatic; transmission - infin. variable; see illustration:; 927-50
45diagnosis interface for; data bus (gateway); see illustration:; 907-00
45control unit for infor-; mation electronics; see illustration:; 035-00; PR-8YQ,8AJ,; 8DP
45control unit for infor-; mation electronics; see illustration:; 035-05; PR-8DY,8DZ
46control unit for; distance regulation; see illustration:; 907-05
47control unit for adaptive; suspension; see illustration:; 616-30
48control unit for; opening garage door; see illustration:; 907-05
RAY_SMITH
Ive spoke to audi and theyve given me a part number. Ive managed to source a wiper motor used for £109, and a friend said he can fit it for £50. i hope this will solve the problem, as the wipers dont move that easy by hand
many thanks
ill keep you posted
