Audi A4 - new car delivery checklist
numec
Hi all,
I will be getting the A4 delivered first week September and just wondering if you can share some checklists to remind/notify the dealer?
The plan is to get the car delivered to me so probably has to notify anything to the dealer beforehand. Things like, ensure the car is set to 18k/2 year service cycle or myaudi registration (do I need dealer help on this?) or anything else.
This will be my first Audi experience, coming from Range Rover Velar and my other car is MK5 GTI :blush:
Thanks in advance.
liveseytowers
What model are you getting? Not sure if the new one's come with the door stickers but if it does you could ask them to apply them.
If the car is being delivered make sure you have the Audi connect code which is on a plastic strip. They can be attached to the key fob or mine was tucked into the wallet with the manual. I had to call to find out where mine was as it wasn't obvious.
numec
Cheers for the info.
It will be just the mere S Line 40 TFSI S-Tronic with very few extras :racer:
I guess I'm too late to join the bandwagon then.
Soot1e
Look on the inside of the front cover of the owners handbook to ensure the dealer has stuck the cars data sticker in there. This gives you chassis and engine numbers plus engine code and codes for the equipment fitted to your vehicle.
cuke2u
That will be in the boot as well, under the floor...
psychopomp1
Ask them to ensure tyres are inflated to the correct pressures (as shown on side door sticker) and not to the transportation pressures, which are usually around 50 PSI :crying: Keep an eye out for this :)
numec
Thanks all for the inputs.
Quick questions:
1) Can I check the car's specs from the VIN/Chassis number?
2) If not, how is the quickest way to check that they are the Nappa Leather as specced without using the specs code mentioned?
cuke2u
VIN numbers won't show the options you've chosen, only thinks like model, engine, transmission, colour, where built etc. Your best bet is the option sticker in the boot.
Plus this http://vag-codes.info/vag-option-codes where you can look up the codes...
cuke2u
You do know that pictures are obligatory
numec
Not the best but here she is :)
numec
I feel like getting the obdeleven just to enable the needle sweep (mine is non VC) and the taillight DRL on.
numec
No stickers came with it unfortunately
