Audi A4 B8 Engine Management Light
Neil Wilkinson
So driving into work this morning and the engine stuttered/juddered and the engine management light was flashing.
I’ve had this issue a few years ago and turned out to be a faulty coil pack, so hoping if it doesn’t sort itself out it’s the same again as it’s a relatively easy and cheap fix (hopefully)
Does anyone have any thoughts on the above? Guessing Audi’s go through coil packs for some reason??
countwilliam
I got a cheap Bluetooth code reader from amazon, might help you investigate your issue, as well as unlock some other functions before heading to the garage?
Carista Bluetooth OBD2 Adapter...
Neil Wilkinson
Ok so I ran a scan tonight and got the following code under engine 05646, I reset it (maybe I shouldn’t have?)
Below is a screenshot of the ecu afterwards
ECU info obtained with Carista 383099 for iOS:
CAN network gateway
Part #: 8T0907468R
Coding: 00CF07 (hex)
Component: GW-BEM 5CAN
[No fault codes]
Ignition authorization
Part #: 8K0907064DP
Coding: 033100 (hex)
Component: BCM2 1.1
[No fault codes]
Central electronics
Part #: 8K0907063N
Coding: 2600D0914034AF210401000000001D0D439D030804010141000000 (hex)
Component: BCM1 1.0
Fault codes:
03207 Charisma Switch Module
Body/convenience system
Part #: 8K0907064DP
Coding: 011F0622003904400030013680000000 (hex)
Component: BCM2 1.1
[No fault codes]
Driver's door
Part #: 8K0959793J
Coding: 011002204C01410001 (hex)
Component: TSG FA
[No fault codes]
Front passenger's door
Part #: 8K0959792J
Component: TSG BF
[No fault codes]
Rear left door
Part #: 8K0959795C
Coding: 010002204001210001 (hex)
Component: TSG HL
[No fault codes]
Rear right door
Part #: 8K0959795C
Component: TSG HR
[No fault codes]
Heater & air conditioning
Part #: 8T2820043AF
Coding: 642C0000 (hex)
Component: KLIMA 3 ZONEN
Fault codes:
01207 Control Module for Auxiliary Heater (J364)
Steering wheel
Part #: 8K0953568F
Coding: 000016 (hex)
Component: Lenks.Modul
[No fault codes]
Instrument cluster
Part #: 8K0920980L
Coding: 2F05080002002600010400 (hex)
Component: KOMBIINSTR.
[No fault codes]
Parking brake
Part #: 8K0907801H
Coding: [none]
Component: EPB Audi B8
[No fault codes]
ABS
Part #: 8K0907379AK
Coding: 060504 (hex)
Component: ESP8 front
[No fault codes]
Steering angle
[ECU not present]
Parking/steering assist
Part #: 8K0919475H
Coding: 100203 (hex)
Component: PARKHILFE 4K
[No fault codes]
Airbags
Part #: 8K0959655G
Coding: 30363435363030303030554A3052384B3053 (hex)
Component: AirbagVW-AU10
[No fault codes]
Engine
Part #: 8K2907115L
Coding: 0104000C18470160 (hex)
Component: 2.0l R4/4V TF
[No fault codes]
Headlight aiming
Part #: 8K5907357A
Coding: 4 (decimal)
Component: Dynamische LWR
[No fault codes]
Media player
Part #: 8T0035785A
Coding: 020202 (hex)
Component: SG ext.Player
[No fault codes]
Radio
Part #: 8T2035186P
Coding: 040200820101CD00875B070800 (hex)
Component: Concert3
[No fault codes]
Telephone
Part #: 8T0862335D
Coding: 10320 (decimal)
Component: FSE_256x BT
[No fault codes]
Sound system
Part #: 8T0035223AH
Coding: 0203010101 (hex)
Component: DSP STD
Fault codes:
01044 Control Module Incorrectly Coded
Obtained with Carista 383099 for iOS.
Download app: https://itunes.apple.com/app/id954363569
Facebook: https://www.facebook.com/caristaapp
