  2. Dismiss Notice
Audi A4 B8 Door Warning Light and Puddle Light retro fit
pns2007 Feb 12, 2010
  1. cbeadle2508
    cbeadle2508 Registered User
    90
    35
    they do look good, you can't grumble about that price for the pair either. Bargain! ;) have you seen the sweeping LED door sills/scuff plates as well? something I thought about but haven't seen the right good quality ones to have a go with yet. Not sure if that might be taking it a bit too far as well.
  2. Avatar
    snack-media
    Advertisement
  3. AndreBerty
    AndreBerty Registered User
    110
    24
    I was thinking about it too but I think it will be too much cause I want to install inside foot light but can’t find a good tutorial.
  4. AndreBerty
    110
    24
    I think it will be to much, especially cause I plan to install inside foot lights but can’t seam to find a good tutorial about it.
  5. cbeadle2508
    90
    35
    I did the footwell lights front and rear, I did mine with the red reflector cover though so as the glow matches the OEM red interior ambient lights. can't think which guide I used now though. didn't take long to do them all and is quite straight forward though.
  6. cbeadle2508
    90
    35
    Marius_A4 likes this.
  7. AndreBerty
    110
    24
    That looks great buddy, I’m looking into fitting red as well. Just need to find that tutorial
  8. Marius_A4
    Marius_A4 Registered User
  9. 6hetyix6
    6hetyix6 Registered User
    Hi Andrei,
    I'm very new to this forum but would like to grab the opportunity to ask for your help to get these mods done. Would you able to get done the whole job or just the coding ?
    I have an Audi A4 SLine Black Edition B8.5 2.0 TDI 2012.
    Many thanks in advance.
    Attila
    Tapatalkkal küldve az én SM-G965F eszközömről
  10. 6hetyix6
    Hi Andrei,
    Attila
  11. AndreBerty
    110
    24
    Hi Attila,
    I can do the all thing, fit the lights and coding, but you need to buy the lights kit and the logo lights you want (different logos out there) and also depends where you live in case you want me to come over.
    Cheers,
    Andrei
  12. Avatar
    snack-media
    Advertisement
  13. 6hetyix6
    Hi Andrei,
    Thats sound great, I though I will drive down to you as I may not have the tools the job required. Do you think we can talk privately so we can talk about cost and agree where and when the job will be carried out.
    Attila
  14. cbeadle2508
    90
    35
    The footwell lights and door warning/puddle lights were ordered as a made up loom from @RobinA3. I did the install myself and was able to enable the footwell lights with Carista App, the door warning/puddle lights needed coding with VCDS though. Both installs were pretty straight forward and Robin supplies the required pin terminations for the control modules, so you can’t go wrong.
    Be careful removing the door cards as the clips can be a pain and brake easily. With the footwell lights, the control module is tucked right up above the pedals and is a little awkward/uncomfortable to get to, the cutouts for the lights should already all be there so it’s a case of clipping the unit in and feeding the wiring loom under the floor lining and behind the dashboards.
    RobinA3 likes this.
  15. cbeadle2508
    90
    35
  16. AndreBerty
    110
    24
    Did you got my message?
  17. 6hetyix6
    Hi Adnrei,
    Yes, I have received your message, I will give you a call today.
  18. AndreBerty
    110
    24
    OK.
  19. briceportier
    briceportier Registered User
    186
    66
    Just swapped mine for the red (LED) ones...
    They actually look way better![​IMG]
    Sent from my SM-G965F using Tapatalk
    Marius_A4 and cbeadle2508 like this.
  20. Marius_A4
    Looks great man nice work,can reduce intensity from mmi i think is too brightness.Anyway i like it.
  21. briceportier
    186
    66
    The intensity increases when you open the door then dims to about half of what you see on the pic.
    But yes, these are very bright indeed (10 LEDs if I remember correctly)...
  22. HavanaClub
    HavanaClub Registered User
    Hi guys. I'm after a bit of help if possible.
    I got a warning and puddle light kit from Ali Express however, somehow over the weekend I've managed to lose 1 of the wiring looms. No idea how or where it is.
    Does anyone know anyone who supplies them? I've msgs a guy on here t8ups I think, found his Facebook page and ring him with the number on the, no answer. I've also msgs him on Facebook and so far it's only showing as sent and not delivered.
    Is anyone able to help with a wiring loom please? My other option is to order another kit from Ali Express but if I can get away without doing that then all well and good.
    Rick
  23. cbeadle2508
    90
    35
    @RobinA3 should be able to help you out. He did my full set of wiring looms for me. Really helpful guy and good quality workmanship.
  24. HavanaClub
    Thanks for your reply mate. I've managed to get sorted and I've got a new loom on its way.
    Just another snag to overcome now tho and I'll be sorted
    cbeadle2508 likes this.
  25. micky981
    micky981 Registered User
    Hi first post forgive me im getting some puddle lights and door warning lights but he live a few miles away 170 miles so coding is going to be a bit of a problem garage down the road does vag coding but he needs the correct codes for my car i have a audi a4 sline 2010 b8 if someone could help ie put some pics up or details where i can get the coding to enable them to work thanks in advance new to all this please help
  26. Paul battams
    Paul battams Active Member VCDS Map User
    250
    68
    Get to this page go into chassis and it brings up all doors in right hand side 42/52/62/72
  27. Paul battams
    250
    68
    Go into the door you want to code press 07 coding
  28. Paul battams
    250
    68
    This will get you to screen on left go to long coding helper this will bring up the screen on the right use cursor arrows to get to second box that will then give you a list and just turn on what you want use arrows to get back to start press escape that puts code into box then hit apply code and ok that should be 1 door coded that’s how I’ve just done mine all work a treat
    Good luck
  29. Paul battams
    250
    68
    And voila you should have them on
  30. Paul battams
    250
    68
    Just a quick note I had doors open a while and voltage dropped it wouldn’t let me install the codes make sure battery is well charged I did mine running to make sure it had plenty in the battery
    micky981 likes this.
  31. AudiG12KPM
    AudiG12KPM Registered User
    35
    Hello I know this is an old thread, I'm only reading 8v on pin 16, 3, 8 I want door lights so when I open the door they light up can you help
  32. AudiG12KPM
    35
