  2. Dismiss Notice
AUDI A4 B7 Convertible Window Regulator broke?!
shaz May 5, 2018
  1. shaz
    shaz Registered User
    170
    hi Guys.
    My window regulator has decided to give way on my B7 cab - drivers side front.
    Iv had a look online ie GSF, eurocarparts, Ebay but there doesn’t seem to be any aftermarket parts available
    Has anyone ever bought a drivers side front regulator for a B7 cab or is it a dealer part only?
    If so how much is it from TPS...?
    Thanks in advance.
  2. Avatar
    snack-media
    Advertisement
  3. martin1984
    martin1984 Registered User
    2,152
    2,476
  4. Sibmets
    Sibmets Registered User
    89
    17
    There are a ton of aftermarket manufacturers for B6/B7 sedan front window regulators, shouldn't be any different for cabriolet. I replaced both front ones on my B7 and on my brothers B6 with yet another supplier (don't recall the name).
    Sent from my E5823 using Tapatalk
  5. shaz
    170
    Hey guys. I was looking for a complete regulator not just a repair kit because I’d struggle to fit a repair kit.
    I’d rather buy the whole regulator with metal frame in order to bolt on easier.
  6. shaz
    170
    Surely the saloon and convertibles will be different as the door is bigger...?
  7. Sibmets
    89
    17
    I'm not implying that they are the same, just that as sedan and avant have a choice in aftermarket parts regarding the regulator, I presumed that cabriolet wouldn't be left out.
    I checked now to be sure and this is the list of manufacturers that make window regulators for a4 b7 carbriolet: VAICO, JOHNS, TOPRAN, MEYLE, METZGER.
  8. shaz
    170
    Thanks il have a look if any of these are suppliers in the Uk
  9. maxwan
    maxwan Registered User
    32
    Just done mine if you need any advice , only changed the cable . Thanks
    Sent from my HTC One_M8 using Tapatalk
  10. zen_200
    zen_200 Registered User
    As maxwan said above. I also did mine a few weeks ago and just replaced the cable. Its was a pain and took 2 of us to get the cable onto the wheel.
    I still have a slight issue, that i think must be to do with my fitting of the window. It make noises and pinging. I think i need to loosen things off a bit and adjust the window.
    I would advise that its a 2 man job.
    Good luck
  11. Sibmets
    89
    17
    A lot easier if you get a kit which comes like an original - with those metal rails where window comes down.
  12. Avatar
    snack-media
    Advertisement
  13. zen_200
    I did look for one, but could only find the replacement cable.
    Its different from the saloon so seems hard to find maybe ?
