  2. Dismiss Notice
Audi A4 B7 Bi-Xenon High beams not working
Ri_Shock Aug 27, 2018
  1. Ri_Shock
    Ri_Shock New Member
    Hello to all, I need some help...
    ... since a couple of days ago, high beams on my 2007. Audi A4 B7 doesn't work anymore.
    The low beams, DRLs, blinkers, fog lights and everything else works fine, but high beams do not switch on.
    Even "flash to pass" (when the lever is pulled towards the steering wheel does not function).
    I have scanned with VAG-COM and there are no faults detected.
    Also, when I check channel 16 - measuring blocks, I have "High beam" field and "Signal light" field which is always showing "Not Oper." when I push or pull the lever on the steering wheel.
    Does anybody have an electrical connection diagram of the "blinkers lever" i could test the voltage on the lever and try to detect where the problem is coming from?
    Any ideas about it would be highly appreciated.
    Leo
  2. Avatar
    snack-media
    Advertisement
  3. Ri_Shock
    Ri_Shock New Member
    Any ideas?
  4. Audiuser16
    Audiuser16 New Member
    Did you check with another bulb. My high beam failed on my old car yet the bulbs looked In good condition. Replaced with new ones and it worked.
  5. Ri_Shock
    Ri_Shock New Member
    Hello,
    I did not check with another bulbs simply because they both stopped working in the same time and also i do not get the blue high beam light on the instrument cluster.
    In the meantime, i have ordered from ebay new blinker stalk. It arrived yesterday. Just need some spare time so i could try to replace it.
    Sent from my iPhone using Tapatalk Pro
  6. Ri_Shock
    Ri_Shock New Member
    Just a notification.
    Today i have replaced the blinkers stalk with the one bought on ebay (used one) and my high beams are working again as normal.
    So, the problem was in the stalk itself.
