Audi A3 - wont start on first crank but will on second - P3053 00 [039] - 50 Short VCDS error
zore
Hi, I was wondering if someone could help shed some light on this issue which I am having with my car.
Car: Audi A3 2012 automatic, 2.0L TDI engine (140 ps)
Problem: Car does not start on first crank but will do on the second crank. This issue started occurring randomly and has been doing this for the last 2-3 months. Video showing this https://vid.me/Lyh9
I connected the car up to VCDS today and got the following error message
1 Fault Found:
5462 - Starter Control; Returned Message
P3053 00 [039] - 50 Short to Ground
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 153503 km
Date: 2016.08.12
Time: 00:20:04
Engine speed: 147.50 /min
Normed load value: 100.0 %
Vehicle speed: 255 km/h
Coolant temperature: 17 °C
Intake air temperature: 20 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 9.040 V
Unlearning counter according OBD: 40
Engine control module reset status-Bit 0: 00000000
Engine control module reset status-Bit 8: 00000000
Limitation: torque: 0.0 Nm
Limitation: accelerator pedal: 99.8 Nm
Cruise Control System (CCS): status-Bit 0: 00000111
Accelerator pedal travel: 0.00 %
Engine torque: 185.8 Nm
Generator: load signal: 0.02 %
Readiness: 0 0 0 0 1
What do you think could be causing the issue? Any suggestions as to possible fixes. I have had a look around on the net and my research suggests I may need to replace the starter motor relay. But I cannot find a wiring diagram for this. I would appreciate any help on this. Thanks in advance
Sound like the control circuit is, as per fault, shorting to ground. First port of call would be to check terminal 50 wiring.
If you PM reg and VIN I'll pull wiring diagram and can advise on specific testing (some basic test equipment required).
I can not PM you, its saying I am spamming you? I will speak with Admin and let you know, Thanks
