Audi A3 retrofit powerfold mirrors
Ash4753
Hi there just wanted some help regarding coding for powerfold mirrors on Audi A3 8V as I’ve had these fitted now need the coding as i want them to display on mmi and work from the key fob unlock/foldout and lock/foldin would appreciate if anyone has the long coding for this retrofit many thanks
AlS3BE
On the a3 it only unfolds with ignition on not key/remote.
There’s a big post on here with all the coding. Depend on year or modules you have the coding can be different.
dannyboy1985
Below is the coding for mmi and fold. As above only unfolds once the key in is.
◦ 09 - Cent. Elect
  • Security Access 31347
  • Adaptations
  • (24)-Access control 2-Funk Spiegelanklappung Modus = by look command via remote control key
  • (26)-Access control 2-Menuesteuerung Funk Spiegel anklappen = Active
  • (27)-Access control 2-Menuesteuerung Komfortbedienung einstellbar = Adjustable
Ash4753
Hi thanks for the reply guys Audi A3 8v 2017 just wanted to know where do i get the long coding from as it’s all zeros in the long coding also regarding the mirrors folding only with ignition i have see them fold with the key fob on YouTube which is on the A3 8V retrofitted by Audi retrofits
DJAlix
VAG Car Coding™ Limited
Site Sponsor
Gold Supporter
VAG Can Professional
ODIS (Offboard Diagnostic System)
Newer platform vehicles which have up to date BCM's will have long coding masked by 0's. Totally normal. The coding for folding mirrors is all in BCM adaptations.
Standard behaviour for folding mirrors is to fold on lock and unfold on ignition accessory position (1st click). You have reconfigured them to only fold on long press of the key for by changing:
  • Access control 2-Funk Spiegelanklappung Modus = by look command via remote control key
AlS3BE
In the newer modules it’s not under access control 2 but under spiegelverstellung. At least that’s where I found mine.
DJAlix
Site Sponsor
Gold Supporter
Indeed. You have to use some "smarts" when retrofitting. If you cannot find what you are looking for then "breakdown" the words / channel names within the search box until you locate what you are looking for. Remember, VW group does not share any information with Ross-Tech. Everything within our cars is labelled in German and Ross-Tech use label files in order to translate these for us where possible, and the labels are subject to change between versions.
AlS3BE
Google translate works like a dream if your German is a bit lacking like me.
Vcds has been great but I think on newer model they are struggling to keep up with new labels. Still pretty good though.
