  2. Dismiss Notice
Audi A3 Front Sensor Retrofit
Callum Jarvis Jun 7, 2018
  1. JohnM100
    JohnM100 Registered User Gold Supporter VCDS Map User
    1,496
    739
    If you are going for the 12 sensors then sounds like you are also adding side assist / blind spot warning?
    The bumper pic in post #76 has a side assist sensor.
  2. Avatar
    snack-media
    Advertisement
  3. d3vilstarz
    d3vilstarz Registered User
    61
    default sensors in the car : 4 x Rear Sensors
    added 2 x rear side
    Front 6
    total to add on 8 sensors inclusive of front grill
    i might go on adding side assist at the later stage but for now will be doing PLA
    on the #76 side sensor is just fitted , but seems to be the wrong sizing , as i understand that this size should be located at the front side bumper instead of the rear
  4. swuw231
    swuw231 Registered User
    For PLA you will need to add 8 PDC sensors: 4 into the front bumper (red) and 1 into each corner of the front and rear bumpers (yellow):
    The ones at the bumper corners have a different mount size with a color matching bracket.
    Regarding wiring, a while back I compiled this table; it list the connections to the PDC module (5Q0 919 298 for PLA):
    But I only did a 8k pdc retrofit, I believe some people in this forum did retrofit the PLA 12k pdc.
    Thanks!
    d3vilstarz likes this.
  5. d3vilstarz
    61
    Thanks Mate ! Appreciated, your diagram is quite clear ! guess for PLA 12k pdc , i need to find some other post :)
  6. martinlop
    martinlop Active Member VCDS Map User
    104
    39
    had the same concern at the time I had retrofitted mine with 12K... look for the spare parts, and had the chance to find the correct ones out there...
    hope this helps.
  7. d3vilstarz
    61
    i bought from aliexpress , but they does not provide instruction , only example connection cable colour , my paint workshop has fix the wrong sensors instead of front , he went to fix at the rear bumper :(
    2 x REAR ABS sensors to replace
    5qa 919 298d to replace current
    this is what i know so far , will sort out the wiring which is front and which is rear tomorrow
  8. d3vilstarz
    61
    i done up my PLA 12k on my audi A3 8v 2015
    i do notice that after fitting , the rear buzzer that i used to have , is disable ? and now is only the front buzzer which seems to be softer comparing to the rear when engaging reverse
    when driving about 10km i do hear the front sensors beeping , but on my mmi screen it does not appear , any coding i need to enable on 5f?
  9. swuw231
    Are you able to set the rear volume via MMI? maybe its very low or turned off. Regarding coding this is what I needed for the 5F adaptation channel:
    • IDE04307-ENG117710-Vehicle function list BAP-parking_assist_0x0A → activated
    • IDE04307-ENG117711-Vehicle function list BAP-parking_assist_0x0A_msg_bus → Terminal 15
    • IDE04300-ENG117496-Vehicle menu operation-menu_display_pdc → activated
    • IDE04300-ENG117498-Vehicle menu operation-menu_display_pdc_over_threshold_high → activated
    • IDE03581-ENG117685-Vehicle function list CAN-PDC_audio_lowering → Available
    • IDE03581-ENG117686-Vehicle function list CAN-PDC_audio_lowering_msg_bus → Comfort data bus
    This will enable the parking functions and config thru MMI, for the OPS display you need to toggle this bit in the Park/Assist module long coding:
    • Byte 2 > Bit 0 (Optical Parking System OPS active)
    Cheers!
  10. d3vilstarz
    61
    Are you able to set the rear volume via MMI? maybe its very low or turned off. , in my mmi , i set to the loudest but only can hear the new buzzer that i fitted
    for mine 2015 , i did an upgrade on my mmi - now is mib2 instead of the old model - is the coding the same ?
    front sensors cant be enable while driving ? or is there an way that we code it to enable
    thanks mate !
  11. swuw231
    Yes, Im able to change the freq and volume for front and rear speaker individually via the MMI menu; I would suggest you to check the connections of the rear buzzer at the 26pin wiring loom from the PDC module, and test the output of the speaker:
    For MIB2 coding should be the same, front sensors should come up by engaging reverse, pressing the PDC button or whenever there is an object nearby but only if "Automatic Parking Aid Acitivation" is enabled:
    I believe there is a "Mute Function active" bit at the parking module (byte 1 > bit 0), but I dont believe this might be causing your rear buzzer issue.
  12. Avatar
    snack-media
    Advertisement
  13. d3vilstarz
    61
    i test on the test function , both sound coming from the front instead
    i did check on my coding , seems to be the same as yours on 5F , i do notice when speed is more than 10km , i cant activate the sensors when in "Drive" mode
  14. d3vilstarz
    61
    VCDS log as below
    Wednesday,09,September,2020,10:13:35:63906
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 20.4.2.0 (x64) HEX-NET CB: 0.4513.4
    Data version: 20200730 DS317.0
    www.Ross-Tech.com
    VIN: License Plate: AFTEROPS
    Mileage: Repair Order:
    Chassis Type: 8V-AU37 (5Q0)
    Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 55 5F 65 6C BB BC
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: Malfunction 0010
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: Malfunction 0010
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: Malfunction 0010
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: Malfunction 0010
    19-CAN Gateway -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    55-Headlight Range -- Status: OK 0000
    5F-Information Electr. -- Status: Malfunction 0010
    65-Tire Pressure -- Status: OK 0000
    6C-Back-up Cam. -- Status: OK 0000
    BB-Door Rear Drv -- Status: OK 0000
    BC-Door Rear Pass -- Status: OK 0000
    Address 01: Engine (J623-CZCA) Labels:. 04E-907-309-V1.clb
    Part No SW: 04E 906 027 HB HW: 04E 907 309 BH
    Component: R4 1.4l TFS H25 4418
    Revision: R7H25---
    Coding: 02250032232401082000
    Shop #: WSC 29277 002 1048576
    ASAM Dataset: EV_ECM14TFS01104E906027HB 001006
    ROD: EV_ECM14TFS01104E906027HB.rod
    VCID: 6B96CFE6827C52DED6-803E
    CAN Converter 01:
    No fault code found.
    Readiness: 0000 0000
    Address 02: Auto Trans (J743) Labels: 0CW-927-769.clb
    Part No SW: 0CW 300 049 J HW: 0AM 927 769 E
    Component: GSG DQ200G2_M H05 0905
    Revision: 00005006 Serial number: CU501605137744
    Coding: 0014
    Shop #: WSC 17734 418 534600
    ASAM Dataset: EV_TCMDQ200021 001001
    ROD: EV_TCMDQ200021_VW31.rod
    VCID: 44C4445ACF627DA677-8010
    Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
    Part No SW: 5Q0 614 517 BJ HW: 5Q0 614 517 AG
    Component: ESC H62 0636
    Revision: 00000000 Serial number: 61466000003170
    Coding: 13F18AA22421126F897F0E0441CC29C851244891708294730221500A060802
    Shop #: WSC 00046 000 00000
    ASAM Dataset: EV_Brake1UDSContiMK100IPB 035019
    ROD: EV_Brake1UDSContiMK100IPB_035_VW37.rod
    VCID: 7AB8FAA2FD26FB565D-802E
    1 Fault Found:
    8307 - Databus
    U1122 00 [009] - Implausible Message
    [FCAN: PLA_Status_PLA_ESP signal is invalid]
    Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 3
    Fault Frequency: 13
    Reset counter: 57
    Date: 2020.09.08
    Time: 13:29:59
    Address 08: Auto HVAC (E87) Labels:| 8V0-820-043.clb
    Part No SW: 8V0 820 043 C HW: 8V0 820 043 C
    Component: AC Automat H14 0060
    Revision: 20028000 Serial number: 00000000942368
    Coding: 03100004110000001000000000001400
    ASAM Dataset: EV_AirCondiFrontVaAU37X 008020
    ROD: EV_AirCondiFrontVaAU37X.rod
    VCID: 3228128265D6C316D5-8066
    Relative humidity sensor in fresh air intake duct:
    Subsystem 1 - Part No SW: 4H0 907 658 HW: 4H0 907 658
    Component: AQ_Hum_Sensor H03 0005
    Serial number: A8584C2800PAG0MUFU01
    1 Fault Found:
    328964 - Motor for Front Air Distribution Flap
    B1091 71 [008] - Actuator stuck
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 96
    Mileage: 41775 km
    Date: 2020.09.08
    Time: 15:54:13
    Voltage terminal 30: 14.0 V
    Interior temperature: 31.0 °C
    Outside air temperature: 36 °C
    Front air distribution flap: actual value: 0
    Front air distribution flap: actual value: 100.0 %
    Front air distribution flap: specified value: 95
    Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
    Part No SW: 5Q0 937 084 CL HW: 5Q0 937 084 AN
    Component: BCM MQBAB H H24 0175
    Serial number: 01061614400337
    Coding: 07041A42C24122F543804004001807A80000000000000000000000000000
    ASAM Dataset: EV_BCMMQB 015001
    ROD: EV_BCMBOSCH_015.rod
    VCID: 0444845A8FE2BDA637-8050
    Control Unit For Wiper Motor:
    Subsystem 1 - Part No SW: 8V2 955 119 C HW: 8V2 955 119 A Labels: 5QX-955-119-V1.CLB
    Component: WWS371 160503 043 0585
    Serial number: 160517071625
    Coding: 0A47F7
    Rain Light Recognition Sensor:
    Subsystem 2 - Part No SW: 8U0 955 559 C HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
    Component: G397_RLFS H06 0004
    Serial number: 61860977
    Coding: 00006C
    Light switch:
    Subsystem 3 - Part No SW: 8V0 941 531 AD HW: 8V0 941 531 AD
    Component: E1 - LDS MQB H05 0032
    Serial number: 04 03 2016 00001534
    1 Fault Found:
    197644 - Control Circuit for Fuel Tank Flap
    B1263 01 [009] - Electrical Failure
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 2
    Reset counter: 56
    Date: 2000.00.00
    Time: 00:00:00
    Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-298.clb
    Part No SW: 5QA 919 298 D HW: 5QA 919 298 A
    Component: PLA 3.0 12KH07 0050
    Serial number: 000308417318353
    Coding: 0270061051
    ASAM Dataset: EV_EPHVA2CAU3700000 009041
    ROD: EV_EPHVA2CAU3700000_009_AU37.rod
    VCID: 51EA7D0E0010980ECC-8004
    Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
    Part No SW: 5Q0 959 655 AB HW: 5Q0 959 655 AB
    Component: AirbagVW20 015 0388
    Serial number: 003MMR1T9NJQ
    Coding: 98CCC000000000005C54000000C800000065
    Shop #: WSC 06385 790 00016
    ASAM Dataset: EV_AirbaVW20SMEVW37X 002130
    ROD: EV_AirbaVW20SMEVW37X_VW48.rod
    VCID: 004C884A9BFAA18613-8054
    Side Sensor Driver Front:
    Subsystem 1 - Part No SW: ----------- HW: 480 002 105 16
    Component: SideSensor_Df 001 0887
    Serial number: 35767000000E3430BB1W
    Coding: 2D2D2D
    Side Sensor Passenger Front:
    Subsystem 2 - Part No SW: ----------- HW: 480 002 105 16
    Component: SideSensor_Pf 001 0887
    Serial number: 3586700000082430BB1Q
    Coding: 2D2D2D
    Side Sensor Driver Rear:
    Subsystem 3 - Part No SW: ----------- HW: 480 401 805 16
    Component: SideSensor_Dr 001 6149
    Serial number: 3516502BB2076342425-
    Coding: 2D2D2D
    Side Sensor Passenger Rear:
    Subsystem 4 - Part No SW: ----------- HW: 480 401 805 16
    Component: SideSensor_Pr 001 6149
    Serial number: 3526502AF20763449052
    Coding: 2D2D2D
    Front Sensor Driver:
    Subsystem 5 - Part No SW: ----------- HW: 480 401 105 16
    Component: FrontSensor_D 001 6149
    Serial number: 3556502992057291C365
    Coding: 2D2D2D
    2 Faults Found:
    9442816 - Front Passenger's Airbag Disabled Indicator Lamp
    B1016 00 [137] - -
    MIL ON - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 41769 km
    Date: 2020.09.08
    Time: 13:30:00
    10487296 - Control Module Does Not Match Vehicle
    B2006 00 [137] - -
    [ECU does not fit to vehicle configuration]
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Mileage: 41769 km
    Date: 2020.09.08
    Time: 13:30:00
    Address 16: Steering wheel (J527) Labels:| 5Q0-953-549.clb
    Part No SW: 5Q0 953 549 E HW: 5Q0 953 549 E
    Component: Lenks. Modul 003 0140
    Revision: -------- Serial number: 11061804680124
    Coding: A018
    Shop #: WSC 27213 003 1048576
    ASAM Dataset: EV_SMLSKLOMQB 020002
    ROD: EV_SMLSKLOMQB_019_AU37.rod
    VCID: 3E3036B2A18E177621-806A
    Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
    Part No SW: 8V0 920 871 R HW: 8V0 920 871 R
    Component: KOMBI H03 6423
    Coding: 67AD19882A9008080101EE001000000000000000
    Shop #: WSC 00046 123 12345
    ASAM Dataset: EV_DashBoardVDDMQBAB 009051
    ROD: EV_DashBoardVDDMQBAB_009_VW37.rod
    VCID: 4BD66F66E23CB2DEB6-801E
    2 Faults Found:
    13636608 - Control Module Incorrectly Coded
    U1014 00 [009] - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 10
    Reset counter: 57
    Mileage: 41769 km
    Date: 2020.09.08
    Time: 13:32:55
    16776980 - Databus
    U1121 00 [009] - Missing Message
    [PLA_Status_01 keine Kommunikation]
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 57
    Mileage: 41787 km
    Date: 2020.09.09
    Time: 09:31:15
    Address 19: CAN Gateway (J533) Labels:| 5Q0-907-530-V1.clb
    Part No SW: 5Q0 907 530 AJ HW: 5Q0 907 530 M
    Component: GW MQB High 212 2246
    Revision: -------- Serial number: 25051610800074
    Coding: 030100043F0857005B000248180B00000001010000000000000000000000
    ASAM Dataset: EV_GatewConti 013020
    ROD: EV_GatewConti_013.rod
    VCID: 79BAE5AEF820F04E54-802C
    Alternator:
    Multi Function Steering Wheel Control Module:
    Subsystem 2 - Part No SW: 8S0 951 523 C HW: 8S0 951 523 C
    Component: J453 MFL H07 0002
    Serial number: 20170719083548 00758
    Battery Monitoring Control Module:
    Subsystem 3 - Part No SW: 5Q0 915 181 H HW: 5Q0 915 181 H
    Component: J367-BDMConti H02 1011
    Serial number: 74185704001605211169
    1 Fault Found:
    8531970 - Quiescent Current
    U1406 00 [008] - Too High
    [Ruhestrom oberer Grenzwert überschritten]
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 96
    Mileage: 41787 km
    Date: 2020.09.09
    Time: 00:15:01
    Supply voltage: Terminal 30: 12.5 V
    Terminal 15: OFF
    Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
    Part No SW: 5Q0 959 593 E HW: 5Q0 959 593 B
    Component: TSG FS 020 0041
    Serial number: 110516EE90176A
    Coding: 001E0B205C01040000001002
    ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
    ROD: EV_DCUDriveSideEWMAXCONT.rod
    VCID: 43C64746CA6C7A9E4E-8016
    Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
    Part No SW: 5Q0 909 144 AB HW: 5Q0 909 144 AA
    Component: EPS_MQB_ZFLS 130 1082
    Coding: 830F0000
    ASAM Dataset: EV_SteerAssisMQB 015157
    ROD: EV_SteerAssisMQB_015.rod
    VCID: 74A4D49ADF428D2607-8020
    Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
    Part No SW: 5Q0 959 592 E HW: 5Q0 959 592 B
    Component: TSG BFS 020 0041
    Serial number: 080516EE406587
    Coding: 001C03205E01040000001002
    ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
    ROD: EV_DCUPasseSideEWMAXCONT.rod
    VCID: 42C84242D576739645-8016
    Address 55: Headlight Range (J431) Labels:| 5Q0-907-357.clb
    Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
    Component: LWR-ECU 005 0080
    Revision: -------- Serial number: --------------
    Coding: 019E000001000000
    ASAM Dataset: EV_HeadlRegulVWLWRMQB 001110
    ROD: EV_HeadlRegulVWLWRMQB.rod
    VCID: 75A2E99ED438942E30-8020
    Address 5F: Information Electr. (J794) Labels:* Redir Fail!
    Part No SW: 8V1 035 035 C HW: 8V1 035 035 C
    Component: MU-P-LND-EU 055 1326
    Serial number: A698K0JS029728
    Coding: 01730107FF0A000011110001000A00106F0027C601700100FE
    ASAM Dataset: EV_MUHig4CGen2HBAS 001001
    ROD: EV_MUHig4CGen2HBAS_VW37.rod
    Data medium:
    Subsystem 1 - Part No SW: V03 959 803 BG HW: -----------
    Component: ROW 2020/2021 --- 0088
    Serial number: --------------------
    Display unit 1 for multimedia system:
    Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
    Component: DU High H49 0014
    Serial number: AUZ8Z9H1Y07S81
    Multimedia Operating Unit:
    Subsystem 3 - Part No SW: 8V0 919 614 BL HW: 8V0 919 614 BL
    Component: ControlUnit_H H85 0855
    Serial number: ALJAL129061600010793
    Compact Disc Database:
    Subsystem 4 - Part No SW: V03 959 800 EG HW: -----------
    Component: Gracenote2 --- 1017
    2 Faults Found:
    3073 - Cellular Antenna
    B1053 13 [009] - Open Circuit
    [GSM/UMTS aerial - open circuit]
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 55
    Mileage: 41769 km
    Date: 2020.09.08
    Time: 13:32:04
    Voltage terminal 30: 12.5 V
    3084 - GSM antenna 2
    B1533 13 [009] - Open Circuit
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 55
    Mileage: 41769 km
    Date: 2020.09.08
    Time: 13:32:04
    Address 65: Tire Pressure (J502) Labels: None
    Part No SW: 4M0 907 273 B HW: 4M0 907 273 B
    Component: RDKHUFAU736 H04 0010
    Serial number: 40000000005092
    ASAM Dataset: EV_RDKHUFAU736 002007
    ROD: EV_RDKHUFAU736.rod
    VCID: 2F2E1BF676E4EEFEBA-807A
    Address 6C: Back-up Cam. (J772) Labels:| 5Q0-980-556.clb
    Part No SW: 5Q0 980 556 B HW: 5Q0 980 556 B
    Component: RVC Compact H12 0231
    Coding: 0273010100002003400040
    ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 006009
    ROD: EV_CamSysRVRVCPANAMQBAB.rod
    VCID: 393A25AEB8A0304E14-806C
    Address BB: Door Rear Drv (J388) Labels:* None
    Part No SW: 5Q0 959 395 E HW: 5Q0 959 395 B
    Component: TSG HFS 020 0041
    Serial number: 300416EDT03117
    Coding: 000C03204001040000001002
    ASAM Dataset: EV_DCURearDriveMINKLO 006003
    ROD: EV_DCURearDriveMAXCONT.rod
    Address BC: Door Rear Pass (J389) Labels:* None
    Component: TSG HBFS 020 0041
    Serial number: 300416EDT03114
    ASAM Dataset: EV_DCURearPasseMINKLO 006003
    ROD: EV_DCURearPasseMAXCONT.rod
    End----------(Elapsed Time: 01:26, VBatt start/end: 12.3V/12.3V)-----------
  15. swuw231
    Yeah, PDC sensors won't come on if speed is higher than set on "switch off speed" setting:
    If both "park assist speaker" and "rear park assist speaker" output to your front speaker, there might be something wrong with your connections, as they should output one or the other.
    PDC sensors won't come on if speed is higher than the value set on "switch off speed" setting (on channel 10 adaptations), I believe the threshold can be set up to 20km/h or so:
    • IDE03782-Switch-off speed for parking assist,10 km/h,1
    Thanks!
  16. d3vilstarz
    61
    i notice this happen when i first remove the ABS tyre sensors , did you code in "maneuver brake" ?
  17. swuw231
    I dont believe I have (remember I did 8K sensors not 12K). Also you might be missing some coding as 12K PLA sensors do require to code some extra stuff at brake, steering, engine instrument channels (thus some of the errors of your full scan), I did also notice that your 10 channel long code seems odd, it might be different from a 8k module but I think that as you have rear view camera your byte 2 coding should look different.
  18. d3vilstarz
    61
    yap 12k need to code some staff in ABS , i cant recall this option , if not wrong bit4-5 is stated rear view camera not installed or some other options , guess need to check on some topic posted in this forum or others , not sure someone did encounter
    thanks mate :)
  19. m rol
    m rol Registered User
    211
    26
    First: do you have pla 2.0 or 3.0?
    Pla 2.0:
    ABS
    Byte 27 bit 1 needs to be checked..
    Instruments 17
    Byte 5 bit 4 checked
    Pla 3.0:
    ABS
    Byte 24 , bit 6 needs to be checked.
    Instruments 17
    Byte 13 bit 1 checked.
