Hi, guys. I've recently changed my battery in my 2012 A3 TDi Black Edition S/S (so needs an AGM battery) from the current Varta 68ah battery to a 70ah Varta Silver dynamic, AGM, E39, etc. The original battery had been in there since manufacture & i was experiencing sluggish starts so i changed it. I know the EXACT specs aren't the same but they are close. I read about various methods to code the battery & with my car having the separate 061 Battery Reg. module i used the Long Adaptation option to change what i could, the screen shot shows that i could change the size, from 68ah to 70ah, the vendor,Varta, same as original so no need to change & finally the serial number which i changed the last digit from O to P. Can someone with a little bit more knowledge than me look over my screenshots to see if the values are correct. What i don't understand is the Battery available only showing 54ah when its a 70ah battery. I had been on a 1 hours drive with nothing on, lights, sound system, heater to give the battery a good charge yet it only went form 52ah to 54ah. Is this correct? Also, in the battery history data there's a reading of 8 & 9 for the energy balance & for the energy capacity (throughput) but in the label for energy balance it says (10000 - start from new) does this mean it should start at 10000 & slowly decrease because my previous battery's 2 values for these were 9500 each?? I know there's a lot of photos & i apologise for the length of this post but i have this nagging feeling in the pit of my stomach that the vehicles energy management system still thinks it's charging an older, worn out battery so i'm not getting the full 70ah capacity hence why it took an hour of driving to get the available charge to go from 52ah to 54ah, also there's no entry in the Battery ageing section of history data for the new battery as the last entry is for the 18th Feb (old battery)yet the new battery was installed on the 26th Feb. Finally, in the MVB 017, Battery Identification it says Inactive in green. I've always taken this as green = OK, but shouldn't there be something showing in this box other than a green INACTIVE? Thanks in advance for any help.
View attachment 216303 View attachment 216304 View attachment 216305 View attachment 216306 View attachment 216307
Below is the full battery history data.
Friday,26,February,2021,21:22:17:24359
VCDS Version: Release 20.12.0 (x64)
Address 61: Battery Regul.
Control Module Part Number: 7N0 907 534
Component and/or Version: Batt.regelung H43 1623
Software Coding: F30F185A
Work Shop Code: WSC 06314
VCID: 71E9F954A8F63D0CFD-FFFE
History Data
Record 1/16: No-load voltage underranging
2021-02-25-18:26*00.4*01*00000***
2021-02-24-18:12*02.0*01**
2021-02-23-14:28*01.7*01**
2021-02-22-14:28*24.0*01**
2021-02-20-06:07*09.0*01**
2021-02-19-00:54*05.7*01**
2021-02-17-14:46*02.6*01**
2020-04-03-17:17*00.0*01*00000***
2000-01-01-00:00*00.0*00**
2000-01-01-00:00*00.0*00*00000***
Record 2/16: No-load current overranging
2015-03-19-13:06*0004*027*-01.91*0-1-1-0-0-0*0*01*00007**
2015-03-19-10:06*0003*034*-01.91*0-1-1-0-0-0*0*01**
2000-01-01-00:00*0000*000*+00.00*0-0-0-0-0-0*0*00**
Record 3/16: Shut-off stage history
2000-01-01-00:00*0*0*000*000*+00.00*0-0-0-0-0-0*0*0*00.0*00.0**
Record 4/16: Battery change history
2021-02-26-00:21*02*070--------*VAO*220417H0IP*00008*00007*0000*0000*0000**
2012-04-24-11:27*01*068--------*VAO*220417H0IO*09747*09312*0000*0000*0000**
2000-01-01-00:00*00*-----------*---*----------*00000*00000*0000*0000*0000**
Record 5/16: Energy-critical vehicle states
2021-02-26-00:21*-00.01*-07.90*-07.85*12.38*100*02*+00.0*00000*00000*117190*0-0-0-0-0-0*0*00.0*00.0*000.0*00*00*01**
2000-01-01-00:00*+00.00*+00.00*+00.00*00.00*000*00*+00.0*00000*00000*000000*0-0-0-0-0-0*0*00.0*00.0*000.0*00*00*00**
Record 6/16: Energy balances (last 10 trips)
2021-02-26-16:57*056*+17*+003.4*00.92**
2021-02-26-00:50*051*+15*+000.6*00.12**
2021-02-26-00:36*051*+14*+002.9*00.18**
2021-02-25-20:56*029*+14*+001.4*00.42**
2021-02-25-20:48*023*+13*+000.1*00.03**
2021-02-25-19:10*023*+09*+004.0*00.66**
2021-02-24-18:54*031*+17*+001.6*00.56**
2021-02-24-18:46*024*+15*+000.1*00.05**
2021-02-24-18:23*025*+14*+000.6*00.11**
2021-02-24-16:57*026*+10*+000.8*00.28**
Record 7/16: Energy balances (last 10 standing times)
2021-02-26-00:57*050*-001.2*000.2*00.1*00.1**
2021-02-26-00:47*051*-000.4*000.0*00.0*00.0**
2021-02-25-21:22*045*-002.1*000.2*00.2*00.2**
2021-02-25-20:50*024*-000.1*000.0*00.0*00.0**
2021-02-25-19:50*023*-000.2*000.9*00.0*00.0**
2021-02-24-19:29*016*-004.6*023.1*00.0*00.0**
2021-02-24-18:50*024*-000.1*000.0*00.0*00.0**
2021-02-24-18:30*024*-000.2*000.2*00.0*00.0**
2021-02-24-17:13*024*-000.9*001.1*00.0*00.0**
2021-02-23-18:26*023*-001.0*022.4*00.0*00.0**
Record 8/16: Battery manipulation (e.g. charging)
2018-07-30-13:13*2*00*00*00*00*2000-01-01-00:00*01**
2018-05-14-20:54*2*01*63*00*00*2000-01-01-00:00*01**
2018-05-14-19:43*2*01*62*00*00*2000-01-01-00:00*01**
2018-05-13-17:03*2*01*61*00*00*2000-01-01-00:00*01**
2018-05-13-16:30*2*01*60*00*00*2000-01-01-00:00*01**
Record 9/16: Battery aging
2021-02-18-06:04*051*061*068*019*09287*12.40*+09*01**
2021-01-31-21:51*053*060*075*025*09237*12.50*+12*01**
2021-01-17-21:37*052*062*068*016*09194*12.40*+02*01**
2021-01-03-15:03*051*063*069*016*09156*12.40*-01*01**
2020-12-18-15:59*050*064*089*030*09106*12.60*+09*01**
2020-12-04-15:35*053*064*065*016*09058*12.30*+01*01**
2020-11-21-05:37*052*064*075*025*09011*12.50*+14*01**
2020-11-06-18:39*053*064*073*024*08967*12.40*+15*01**
2020-10-22-17:50*053*066*081*031*08912*12.50*+18*01**
2020-10-08-17:30*052*068*078*025*08866*12.50*+10*01**
2020-09-24-20:32*052*066*091*036*08822*12.70*+31*01**
2020-09-10-18:06*053*068*070*026*08774*12.40*+20*01**
Record 10/16: Dynamic energy management
2000-01-01-00:00*0*000.0*0*000.0*00.00**
Record 11/16: Recuperation
2021-02-26-17:04*000*000*000*047*1352*055*00.3*02.7*091*052*093*056*01*00001*00001*00000*00002*01211**
2021-02-26-00:54*000*000*000*002*0053*007*00.0*00.2*090*051*090*051*01**
2014-01-22-21:26*000*000*000*017*0091*025*00.0*00.4*093*048*093*049*01**
2014-01-20-17:22*000*000*005*007*0191*055*00.1*00.7*096*048*096*048*02**
2014-01-20-15:22*000*000*001*037*0489*053*00.0*00.8*094*046*096*048*01**
Record 12/16: Start-Stop
2021-02-13-05:46*1-0-0-0-0-0-0-0**
2021-02-13-05:46*0-0-1-0-0-0-0-0**
2021-02-13-05:46*0-0-0-0-1-0-0-0**
2021-02-13-05:46*0-0-0-0-0-0-0-1**
2021-01-25-17:11*1-0-0-0-0-0-0-0**
00000*00000*00000*00000*00000*00000*00000*00000**
2000-01-01-00:00*0-0-0-0-0-0-0-0**
2021-02-25-19:10*1*061*016*+08*07*-025*+28.69*11.5*0**
2021-02-24-16:57*1*075*023*+10*06*-025*-29.46*11.8*0**
2021-02-23-18:09*1*073*020*+11*06*-025*+25.74*11.5*1**
2021-02-22-16:05*1*069*019*+06*07*-025*-08.09*12.2*0**
2021-02-22-15:59*1*069*019*+06*07*-025*-25.28*11.5*0**
00000*00000*00000**
Record 13/16: Sporadic alternator faults
2000-01-01-00:00*0-0-0-0-0*000.0*00000**
2000-01-01-00:00*0-0-0-0-0*000.0**
Record 16/16: Vehicle energy balance
117225**
01466*07206*03135*00006*00000**
12407*00283*00033*00007**
54144*01208*00304*00084**
02235*03236*01337*04152**
05328*04582*01050**
16691*00686*00276*00115**
05246*00100*00007**
05171*00101*00008**
00045*00000*00000**
00276*00188*00151*00105*00093*00066*00087*00078*00038*00056**
History Data
00000*00000*00000**
117225**
05328*04582*01050**
05246*00100*00007**
05171*00101*00008**
00045*00000*00000**
