Sunday,06,January,2019,16:03:28:00007
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 18.9.0.2 (x64)
Data version: 20180927 DS296.0
www.Ross-Tech.com
Dealer/Shop Name: 12345/123/12345
VIN: WAUZZZ8V7J1084411 License Plate:
Chassis Type 8V-AU37 (3Q0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 20 22 2B 42 44 4B 52 5F 6C
A9 BB BC
VIN: WAUZZZ8V7J1084411 Mileage: 14485km-9000miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
20-High Beam Assist. -- Status: OK 0000
22-AWD -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
4B-Multifunc. Module -- Status: INTERFACE NOT COMPATIBLE
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
6C-Back-up Cam. -- Status: Malfunction 0010
A9-Struct. Borne Sound -- Status: OK 0000
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
Address 01: Engine (J623-DJHA) Labels:. 06K-907-425-V1.clb
Part No SW: 8V0 906 259 J HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0003
Revision: --H13---
Coding: 0A2500122426010B3004
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_ECM20TFS0208V0906259J 001005
ROD: EV_ECM20TFS0208V0906259J_AU37.rod
VCID: 479DED1DFEADF37254-8012
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans (J743) Labels:. 0BH-927-711.clb
Part No SW: 0GC 300 012 A HW: 0GC 927 711 G
Component: GSG DQ381 H06 1402
Revision: 00H06V07
Coding: 0014
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_TCMDQ381061 001
ROD: EV_TCMDQ381061.rod
VCID: 2149538530C9ED42FA-8074
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 8V0 614 517 E HW: 8V0 614 517 C
Component: ESC H25 0625
Revision: 00000000 Serial number: 61208000001146
Coding: 319C6B8D54A113AD8B950B654192698CD62AC8D1D082967702415074820812
ASAM Dataset: EV_Brake1UDSContiMK100IPB 070001
ROD: EV_Brake1UDSContiMK100IPB_035_VW41.rod
VCID: 3B7581EDB265A792C0-806E
Address 05: Acc/Start Auth. (J518) Labels:| 5Q0-959-435.clb
Part No SW: 5Q0 959 435 C HW: 5Q0 959 435
Component: VWKESSYMQB 021 0803
Revision: 00021000 Serial number: 0480903269
Coding: 030C0C
ASAM Dataset: EV_KessyHellaMQBAB 002020
ROD: EV_KessyHellaMQBAB_002.rod
VCID: 3C7782F1B76BA0AAC9-8068
Address 08: Auto HVAC (E87) Labels:| 8V0-820-043.clb
Part No SW: 8V0 820 043 AE HW: 8V0 820 043 AE
Component: AC Automat H03 0150
Revision: 20003000 Serial number: 00000001561989
Coding: 03000004000000011000000000001100
ASAM Dataset: EV_AirCondiFrontVaAU37X 008025
ROD: EV_AirCondiFrontVaAU37X.rod
VCID: 75E157D5D4C131E2F6-8020
Relative humidity sensor in fresh air intake duct:
Subsystem 1 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B
Component: AQ_Hum_Sensor H02 0007
Serial number: 4D21DA2900PAG0MUFU03
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 5Q0 937 084 DJ HW: 5Q0 937 084 CG
Component: BCM MQBAB M++ H36 0253
Serial number: 00001814301750
Coding: 000000000000000000000000000000000000000000000000000000000000
ASAM Dataset: EV_BCMMQB 018001
ROD: EV_BCMBOSCH_018.rod
VCID: 0305390D8A151F52C8-8056
Control Unit For Wiper Motor:
Subsystem 1 - Part No SW: 8V1 955 119 C HW: 8V1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS371 180421 043 0585
Serial number: 180515220505
Coding: 0A47F7
Rain Light Recognition Sensor:
Subsystem 2 - Part No SW: 81A 955 547 A HW: 81A 955 547
Component: G397_RLFS H06 0002
Serial number: 21383551X81A955547A0
Coding: 00006C
Light switch:
Subsystem 3 - Part No SW: 8V0 941 531 AR HW: 8V0 941 531 AR
Component: E1 - LDS MQB H06 0032
Serial number: 09 03 2018 00000770
Sensor For Anti Theft Alarm System:
Subsystem 4 - Part No SW: 8V0 951 177 HW: 5Q0 951 172
Component: Sensor, DWA 005 0316
Serial number: 000000000ZY1808705LJ
Alarm horn:
Subsystem 5 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Component: Sirene, DWA 005 0314
Serial number: 00000000000030009982
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-294.clb
Part No SW: 5QA 919 294 E HW: 5QA 919 294
Component: PDC 8 KanalH07 0443
Serial number: 000308418018107
Coding: 0470151011
ASAM Dataset: EV_EPHVA18AU3700000 009035
ROD: EV_EPHVA18AU3700000_009_VW37.rod
VCID: 4E93D83911D7223A17-801A
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 5Q0 959 655 BJ HW: 5Q0 959 655 BJ
Component: AirbagVW21 006 0339
Serial number: 003VWR47PGY7
Coding: 98CCC0000C0000005C5400CA0048000000C5
ASAM Dataset: EV_AirbaVW20SMEVW37X 002160
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 09192B25A839450282-805C
Side Sensor Driver Front:
Subsystem 1 - Part No SW: ----------- HW: 480 002 705 18
Component: SideSensor_Df 001 0887
Serial number: 357000000002CB7D8D2/
Coding: 2D2D2D
Side Sensor Passenger Front:
Subsystem 2 - Part No SW: ----------- HW: 480 002 705 18
Component: SideSensor_Pf 001 0887
Serial number: 358000000000DB7D8D2/
Coding: 2D2D2D
Side Sensor Driver Rear:
Subsystem 3 - Part No SW: ----------- HW: 480 402 305 18
Component: SideSensor_Dr 004 6149
Serial number: 3510001182AE89C1F53C
Coding: 2D2D2D
Side Sensor Passenger Rear:
Subsystem 4 - Part No SW: ----------- HW: 480 402 305 18
Component: SideSensor_Pr 004 6149
Serial number: 3520001182AE89C35186
Coding: 2D2D2D
Front Sensor Driver:
Subsystem 5 - Part No SW: ----------- HW: 480 402 604 18
Component: FrontSensor_D 001 6149
Serial number: 3550002C9252D86572CC
Coding: 2D2D2D
Pedestrian Protection Driver:
Subsystem 6 - Part No SW: ----------- HW: 480 400 905 18
Component: PedP_Sensor_D 000 6149
Serial number: 2280001C929D67831322
Coding: 2D2D2D
Pedestrian Protection Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 400 905 18
Component: PedP_Sensor_P 000 6149
Serial number: 2290001C129E65D3873B
Coding: 2D2D2D
Pedestrian Protection Driver 2:
Subsystem 8 - Part No SW: ----------- HW: 480 000 405 18
Component: PedPSensor_D2 001 0887
Serial number: I0M00000000CAB211D26
Coding: 2D2D2D
Pedestrian Protection Passenger 2:
Subsystem 9 - Part No SW: ----------- HW: 480 000 405 18
Component: PedPSensor_P2 001 0887
Serial number: I0N00000000BAB211D26
Coding: 2D2D2D
Address 16: Steering wheel (J527) Labels:| 5Q0-953-549.clb
Part No SW: 8V0 953 521 KK HW: 5Q0 953 549 E
Component: Lenks. Modul 003 0140
Revision: -------- Serial number: 21051804220578
Coding: 2018
ASAM Dataset: EV_SMLSKLOMQB 020002
ROD: EV_SMLSKLOMQB_020_AU37.rod
VCID: 0D111F35DC515922AE-8058
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 8V0 920 873 S HW: 8V0 920 873 S
Component: KOMBI H01 0311
Coding: 07AD181A2B8000080701AC001000000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009060
ROD: EV_DashBoardVDDMQBAB_009_VW37.rod
Address 19: CAN Gateway (J533) Labels:| 3Q0-907-530-V1.clb
Part No SW: 3Q0 907 530 L HW: 3Q0 907 530 C
Component: GW MQB High 518 5323
Serial number: 16051810802059
Coding: 030100043F085A005B00826A3C0B00000001010000000000000000000000
ASAM Dataset: EV_GatewNF 013023
ROD: EV_GatewNF_VW37.rod
VCID: 387F9EE183538C8A2D-806C
Alternator:
Multi Function Steering Wheel Control Module:
Subsystem 2 - Part No SW: 81A 951 523 A HW: 81A 951 523 A
Component: J453 MFL H04 0004
Serial number: 20180417203839 21882
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 J HW: 5Q0 915 181 J
Component: J367-BDMConti H03 1050
Serial number: 75886001911804040323
6 Faults Found:
131692 - No Communications with Undefined Control Module
U1126 00 [008] - -
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 174
Mileage: 13887 km
Date: 2018.12.29
Time: 00:14:05
Supply voltage: Terminal 30: 11.7 V
Terminal 15: On
131699 - Control unit for information electronics 1
U1054 00 [008] - No Communication
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 190
Mileage: 14485 km
Date: 2019.01.06
Time: 10:04:28
Supply voltage: Terminal 30: 11.8 V
Terminal 15: OFF
66052 - Infotainment CAN Bus (SAE Bus E)
U0065 00 [008] - Performance
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 190
Mileage: 13887 km
Date: 2018.12.28
Time: 22:18:04
Terminal 15: On
66565 - Diagnostic Databus
U1202 00 [008] - Malfunction
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 174
Mileage: 13887 km
Date: 2018.12.29
Time: 11:12:44
Supply voltage: Terminal 30: 12.7 V
Terminal 15: On
66304 - Databus
U1124 00 [008] - Additional Installations Detected
Freeze Frame:
Fault Priority: 2
Fault Frequency: 17
Reset counter: 190
Mileage: 13887 km
Date: 2018.12.28
Time: 23:32:47
Supply voltage: Terminal 30: 11.1 V
Terminal 15: On
8526361 - LV Energy Management
B1802 F1 [008] - Warning Triggered
Freeze Frame:
Fault Priority: 4
Fault Frequency: 6
Reset counter: 174
Mileage: 13887 km
Date: 2018.12.28
Time: 23:29:24
Terminal 15: On
Address 20: High Beam Assist. (J844) Labels:* None
Part No SW: 81A 857 511 G HW: 81A 857 511 A
Component: FLA H10 0008
Revision: AA001001
Coding: 0404000700000000000000
ASAM Dataset: EV_HighBeamAssisMXBAU33X 001003
ROD: EV_HighBeamAssisMXBAU33X.rod
VCID: 2C57B2B1470B302A59-8078
Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0CQ 907 554 K HW: 0CQ 525 130
Component: Haldex4Motion H52 7762
Serial number: HA1-00024.04.18
Coding: 0001
ASAM Dataset: EV_AllWheelContrHA1VW37X 002015
ROD: EV_AllWheelContrHA1VW37X.rod
VCID: 4D91DF351CD119226E-8018
Address 2B: Steer. Col. Lock (J764) Labels:* 5Q0-905-861.clb
Part No SW: 5Q0 905 861 A HW: 5Q0 905 861 A
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 18000170017002
Coding: 5D00000000000000
ASAM Dataset: EV_ELVMarquMQB 004111
ROD: EV_ELVMarquMQB.rod
VCID: 3467AAD19F3B68EA01-8060
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q0 959 593 E HW: 5Q0 959 593 B
Component: TSG FS 020 0041
Serial number: 280418EDR26955
Coding: 001C9A204000040000001002
ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT.rod
VCID: 4385F90DCA95DF5288-8016
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 3Q0 909 144 L HW: 3Q0 909 144 L
Component: EPS_MQB_ZFLS 507 5081
Coding: 811F0000
ASAM Dataset: EV_SteerAssisMQB 015157
ROD: EV_SteerAssisMQB_015.rod
Address 4B: Multifunc. Module
Interface not compatible.
Please upgrade to a current Ross-Tech interface.
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q0 959 592 E HW: 5Q0 959 592 B
Component: TSG BFS 020 0041
Serial number: 300418EDU05594
Coding: 001C92204000040000001002
ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT.rod
VCID: 428BFC09D58FD65A83-8016
Address 5F: Information Electr. (J794) Labels:* Redir Fail!
Part No SW: 81A 035 183 E HW: 81A 035 183
Component: MU-HS-N-EU 050 0213
Serial number:
Coding: 01735100FF0A000011110001000A00002F002BC401F001000E
ASAM Dataset: EV_MUHigScl6C3DELP 001011
ROD: EV_MUHigScl6C3DELP_AU37.rod
VCID: 2345598D2AD5FF52E8-8076
Display unit 1 for multimedia system:
Subsystem 1 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0014
Serial number: AUZ8Z9J1Y0AV6C
Multimedia Operating Unit:
Subsystem 2 - Part No SW: 8V0 919 614 BF HW: 8V0 919 614 BF
Component: ControlUnit_B H50 0103
Serial number: ALJAL114031800050725
3 Faults Found:
1562 - Microphone 1
B129B 11 [008] - Short to Ground
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 190
Mileage: 13887 km
Date: 2018.12.28
Time: 23:30:41
Voltage terminal 30: 11.1 V
6922 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 190
Mileage: 14485 km
Date: 2019.01.06
Time: 08:15:13
Voltage terminal 30: 11.9 V
7178 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 190
Mileage: 14485 km
Date: 2019.01.06
Time: 08:15:16
BAP-BAP_Function_ID: 02
Address 6C: Back-up Cam. (J772) Labels:| 5Q0-980-556.clb
Part No SW: 5Q0 980 556 B HW: 4M0 980 556
Component: RVC Compact H08 0231
Coding: 02335401A2002001000040
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 006009
ROD: EV_CamSysRVRVCPANAMQBAB_006_VW37.rod
VCID: 39799BE5B8599582D2-806C
1 Fault Found:
10489856 - No Basic Setting
B2010 00 [009] - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 150
Mileage: 14485 km
Date: 2019.01.06
Time: 15:57:36
passive
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 8V0 907 159 A HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0001
Serial number: 180413201176
ASAM Dataset: EV_SoundActuaGen2AU64X 003010
ROD: EV_SoundActuaGen2AU64X.rod
VCID: 3E7388F9A177B2BAE7-806A
Address BB: Door Rear Drv (J388) Labels:* None
Part No SW: 5Q0 959 595 E HW: 5Q0 959 595 B
Component: TSG HFS 020 0041
Serial number: 240418EDN05508
Coding: 000C92204000040000001002
ASAM Dataset: EV_DCURearDriveMAXKLO 006003
ROD: EV_DCURearDriveMAXCONT.rod
VCID: 4581E715C4A1E162A6-8010
Address BC: Door Rear Pass (J389) Labels:* None
Component: TSG HBFS 020 0041
Serial number: 240418EDN05423
ASAM Dataset: EV_DCURearPasseMAXKLO 006003
ROD: EV_DCURearPasseMAXCONT.rod
End-------------------------(Elapsed Time: 04:44)--------------------------
