I think my earth point was iffy... I'd already tested it for continuity, but I've moved it now and we have lift off
Now I have another problem... haha!
When coding the 6C module, it must be new / have been reset as it's all zeros currently.
If I fill out the appropriate boxes in the long coding helper, my code is 027300012201000300.
When I click 'Do It!', it asks me...
VCDS: Re-Code Invalid
This appears to be an uninitialized control module;
valid WSC/Importer/Equipment data may be required.
Click [Yes] for VCDS to use default values of 12345/123/12345.
Click [No] for VCDS to try the values currently in the module.
Click [Cancel] to go back and manually edit the values.
Yes No Cancel
I've tried 'Yes' and 'No', it still fails with the same error...
VCDS
Coding rejected
Error 31: Request out of range
OK
