  2. Dismiss Notice
Audi A3 8V Reverse Camera (High) DIY Retrofit guide!!
amit87 Apr 12, 2016
  1. Blair Parker
    Blair Parker Registered User
    10
    Did they fix or replace the cables? I fixed mine and the camera still won’t turn on. I have some other things to check though.
  2. Avatar
    snack-media
    Advertisement
  3. SPIKE_S3
    SPIKE_S3 Vorsprung durch Technik
    2,057
    2,202
    Just checking the correct part number from anyone that has installed the FL camera complete with built in module is: 8V0827566B?
  4. swuw231
    swuw231 Registered User
    Yes, thats the one, I did that retrofit not long ago (FL camera into a PFL A3 saloon).
    SPIKE_S3 likes this.
  5. Zahir hussain
    Zahir hussain Registered User
    32
    Is there any ground earth points near the fuse box on a right hand drive car?
  6. DJAlix
    DJAlix VAG Car Coding™ Limited Site Sponsor Gold Supporter VCDS Map User VAG Can Professional ODIS (Offboard Diagnostic System)
    6,293
    4,806
    Under the carpet, outside edge of the vehicles floor
    A7Paul likes this.
  7. Sorinfrantzu
    Sorinfrantzu Registered User
    23
    Hello, can you told me the solution for solve this ? I have the same issue after flash my original camera
  8. SPIKE_S3
    2,057
    2,202
    @DJAlix could you kindly advise if the correct part number for the FL camera complete with built in module is: 8V0827566B? Looking at fitting into my MY18 S3. Thanks
  9. DJAlix
    6,293
    4,806
    5Q0 980 556 B :)
  10. SPIKE_S3
    2,057
    2,202
    @DJAlix Is that just the camera part? Do you not need to buy the handle complete with the camera built in? Sorry for my lack of knowledge!
  11. DJAlix
    6,293
    4,806
    Which is what that is...
  12. Avatar
    snack-media
    Advertisement
  13. dantdi
    dantdi ...
    552
    14
    DjAlix can you supply the FL camera complete with built in module and loom with coding prep?
  14. DJAlix
    6,293
    4,806
    I can indeed. If interested please send me a PM.
  15. ME CODING
    ME CODING Registered User
    57
    Hi i did the all the fittings and coding but keep getting a no signal LVDS. any help?
  16. DJAlix
    6,293
    4,806
    Try posting an unedited auto scan so we can see what’s going on
  17. ME CODING
    57
    Hi Alix here is my auto scan. thank you
  18. DJAlix
    6,293
    4,806
    9591827 - Video Signal Line
    B125C 13 [009] - Open Circuit
    Could be one of the following:
    -Video Cable is not connected
    -Video Cable has a broken connection
    -Video Cable Connection is reversed
    Reverse White / Clear and Black wires on the Blue MMI connector Block. If this does not work then test your video cable continuity.
  19. SPIKE_S3
    2,057
    2,202
    @DJAlix is there a good earthing point in the boot of a Sportback that you can use?
  20. DJAlix
    6,293
    4,806
  21. SPIKE_S3
    2,057
    2,202
    DJAlix likes this.
  22. ME CODING
    57
    hi i checked the connection it was loose but the video input was set to LVDS i changed it to FBAS. no there is no error and not even a blank screen showing either. :(. il post a new auto scan
  23. DJAlix
    6,293
    4,806
    So it looks like you have resolved your physical issues, now you need to revisit your coding.
  24. ME CODING
    57
    is it pramatizating or just coding. i have been over the coded over and over and it cant see anything. driving me mental now. do you a list of codes for me to try plz.
  25. DJAlix
    6,293
    4,806
    If you Camera was not parameterised then you would have a “no end of line coding” error however your camera could be incorrectly parameterised but then I would expect to see a dataset error.
    I would suggest you go over the guide at the start of thread again as all the needed coding is there.
  26. ME CODING
    57
    ok will do that and report back, thank you @DJAlix
  27. ME CODING
    57
    HI @DJAlix i have done an Autoscan today i seen a error on module-19. it still allows me to go into back up camera so it is communicating i think?
    Sunday,17,May,2020,13:46:05:60976
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 20.4.0.1 (x64) HEX-V2 CB: 0.4508.4
    Data version: 20200331 DS317.0
    www.Ross-Tech.com
    17/05/2020
    Chassis Type: 8V-AU37 (3Q0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 2B 42 44 47 52 55 5F 6C BB
    BC
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    2B-Steer. Col. Lock -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    55-Headlight Range -- Status: OK 0000
    5F-Information Electr. -- Status: Malfunction 0010
    6C-Back-up Cam. -- Status: OK 0000
    BB-Door Rear Drv -- Status: OK 0000
    BC-Door Rear Pass -- Status: OK 0000
    Address 01: Engine (J623-CRBC) Labels:. 04L-907-309-V1.clb
    Part No SW: 04L 906 021 DT HW: 04L 907 309 D
    Component: R4 2,0L EDC X22 5520
    Revision: 83X22---
    Coding: 021D0012032501083000
    Shop #: WSC 06314 790 00021
    ASAM Dataset: EV_ECM20TDI01104L906021DT 002004
    ROD: EV_ECM20TDI01104L906021DT_002.rod
    VCID: 7AAC091C1C51BADB1D6-802E
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 02: Auto Trans (J743) Labels: 0D9-927-770.clb
    Part No SW: 0D9 300 040 A HW: 02E 927 770 AN
    Component: DQ250-6F MQB H52 3613
    Revision: 05652103 Serial number: TFK01212130636
    Coding: 0014
    Shop #: WSC 00028 028 00310
    ASAM Dataset: EV_TCMDQ250021 001001
    ROD: EV_TCMDQ250021.rod
    VCID: 15763AA0150F75A3904-8040
    11 Faults Found:
    21153 - Gear 1
    P072C 00 [002] - Not Selectable
    Intermittent - Not Confirmed - Tested Since Memory Clear
    21154 - Gear 2
    P072D 00 [002] - Not Selectable
    21155 - Gear 3
    P072E 00 [002] - Not Selectable
    21156 - Gear 4
    P072F 00 [002] - Not Selectable
    21157 - Gear 5
    P073A 00 [002] - Not Selectable
    21158 - Gear 6
    P073B 00 [002] - Not Selectable
    21159 - Gear R
    P072B 00 [002] - Not Selectable
    10731 - Valve 3 in Transmission Part 1
    P174A 00 [002] - Electrical malfunction
    10732 - Valve 3 in Transmission Part 2
    P174E 00 [002] - Electrical malfunction
    21207 - Pressure Control Solenoid 3
    P0797 00 [002] - Stuck ON
    10906 - Cooling Oil Valve
    P179D 00 [002] - Electrical Malfunction
    Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
    Part No SW: 5Q0 907 379 AA HW: 5Q0 907 379 G
    Component: ESC H31 0457
    Revision: 00000000 Serial number: 61323000000604
    Coding: 12F18AA224200A6E037F060241CA2948512450C0608294F3026100788508
    Shop #: WSC 27496 003 104857
    ASAM Dataset: EV_Brake1UDSContiMK100IPB 033001
    ROD: EV_Brake1UDSContiMK100IPB_033.rod
    VCID: 7BA20C18136B83D3060-802E
    Address 05: Acc/Start Auth. (J518) Labels:| 5Q0-959-435.clb
    Part No SW: 5Q0 959 435 A HW: 5Q0 959 435
    Component: VWKESSYMQB 021 0604
    Revision: 00021000 Serial number: 0207224423
    Coding: 030C0C
    Shop #: WSC 12345 123 12345
    ASAM Dataset: EV_KessyHellaMQBAB 002011
    ROD: EV_KessyHellaMQBAB_002.rod
    VCID: 3A2CC91C5CD17ADB5D6-806E
    Address 08: Auto HVAC (E87) Labels:| 8V0-820-043.clb
    Part No SW: 8V0 820 043 D HW: 8V0 820 043 D
    Component: AC Automat H13 0060
    Revision: 20027000 Serial number: 00000000620277
    Coding: 03100114002000011000000000001100
    ASAM Dataset: EV_AirCondiFrontVaAU37X 008020
    ROD: EV_AirCondiFrontVaAU37X.rod
    VCID: 3332E4387BBB8B939E0-8066
    Relative humidity sensor in fresh air intake duct:
    Subsystem 1 - Part No SW: 4H0 907 658 HW: 4H0 907 658
    Component: AQ_Hum_Sensor H03 0003
    Serial number: DB480CA6000000000001
    Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
    Part No SW: 5Q0 937 084 AA HW: 5Q0 937 084 AA
    Component: BCM MQBAB H H14 0112
    Serial number: 00011313501857
    Coding: 07111A42C2C122FD07844004B3140728083A000000000000000000000000
    ASAM Dataset: EV_BCMCONTI 011001
    ROD: EV_BCMBOSCH_011.rod
    VCID: 77AA10282F43A7B3628-8022
    Control Unit For Wiper Motor:
    Subsystem 1 - Part No SW: 8V2 955 119 A HW: 8V2 955 119 Labels: 5QX-955-119-V1.CLB
    Component: WWS370 130509 041 0580
    Serial number: 130510235859
    Coding: 0AC7F7
    Rain Light Recognition Sensor:
    Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
    Component: G397_RLFS H06 0002
    Serial number: 21318029
    Coding: 03006C
    Light switch:
    Subsystem 3 - Part No SW: 8V0 941 531 L HW: 8V0 941 531 L
    Component: E1 - LDS MQB H05 0032
    Serial number: 01 04 2013 00000599
    Sensor For Anti Theft Alarm System:
    Subsystem 4 - Part No SW: 8V0 951 177 HW: 5Q0 951 172
    Component: Sensor, DWA 005 0313
    Serial number: 000000000ZY1311427SE
    Alarm horn:
    Subsystem 5 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
    Component: Sirene, DWA 004 0311
    Serial number: 00000000000056755419
    Sun Roof:
    Subsystem 6 - Part No SW: 8V3 959 591 HW: 8V3 959 591
    Component: J245 PS73.009 H02 0007
    Serial number: WOO21753350
    Coding: 901E00
    Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-283.clb
    Part No SW: 5Q0 919 283 B HW: 5Q0 919 283
    Component: PARKHILFE 4K H09 0033
    Revision: -------- Serial number: 60831313901784
    Coding: 0001150011
    ASAM Dataset: EV_EPHVA14AU3700000 002018
    ROD: EV_EPHVA14AU3700000_002_VW37.rod
    VCID: 3828D31462DD68CBAB2-806C
    Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
    Part No SW: 5Q0 959 655 N HW: 5Q0 959 655 N
    Component: AirbagVW20 011 0361
    Serial number: 003M2R01LV1M
    Coding: 98FCC0000C0000005C5400CA00C800000065
    ASAM Dataset: EV_AirbaVW20SMEVW37X 002126
    ROD: EV_AirbaVW20SMEVW37X_VW48.rod
    VCID: 4BC29CD8034BF353F60-801E
    Side Sensor Driver Front:
    Subsystem 1 - Part No SW: ----------- HW: 480 001 005 13
    Component: SideSensor_Df 001 0887
    Serial number: 35767000000A08904D0T
    Coding: 2D2D2D
    Side Sensor Passenger Front:
    Subsystem 2 - Part No SW: ----------- HW: 480 001 005 13
    Component: SideSensor_Pf 001 0887
    Serial number: 35867000000CF7904D03
    Coding: 2D2D2D
    Side Sensor Driver Rear:
    Subsystem 3 - Part No SW: ----------- HW: 480 402 504 13
    Component: SideSensor_Dr 001 6149
    Serial number: 3516502B51050652021H
    Coding: 2D2D2D
    Side Sensor Passenger Rear:
    Subsystem 4 - Part No SW: ----------- HW: 480 401 704 13
    Component: SideSensor_Pr 001 6149
    Serial number: 3526502BF0FBDE3303C.
    Coding: 2D2D2D
    Front Sensor Driver:
    Subsystem 5 - Part No SW: ----------- HW: 480 401 503 13
    Component: FrontSensor_D 001 6149
    Serial number: 35565029B0FAE89452A.
    Coding: 2D2D2D
    Pedestrian Protection Driver:
    Subsystem 6 - Part No SW: ----------- HW: 480 400 605 13
    Component: PedP_Sensor_D 001 6149
    Serial number: 2286502C51050652027R
    Coding: 2D2D2D
    Pedestrian Protection Passenger:
    Subsystem 7 - Part No SW: ----------- HW: 480 400 605 13
    Component: PedP_Sensor_P 001 6149
    Serial number: 2296502C51050653F0C4
    Coding: 2D2D2D
    Pedestrian Protection Center:
    Subsystem 8 - Part No SW: ----------- HW: 480 400 605 13
    Component: PedP_Sensor_C 001 6149
    Serial number: 2306502C91050654419V
    Coding: 2D2D2D
    Address 16: Steering wheel (J527) Labels:| 5Q0-953-549.clb
    Part No SW: 8V0 953 521 P HW: 5Q0 953 549
    Component: Lenks. Modul 007 0070
    Revision: -------- Serial number: 14051308490504
    Coding: A418
    ASAM Dataset: EV_SMLSKLOMQB 009001
    ROD: EV_SMLSKLOMQB_009_AU37.rod
    VCID: 47CAA0E81F231733D28-8012
    Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI2
    Part No SW: 8V0 920 790 A HW: 8V0 920 790 A
    Component: FBenRDW H16 0066
    Coding: 24FD09522BA026000111FE001C80011000000000
    Shop #: WSC 11357 011 00200
    ASAM Dataset: EV_DashBoardFPKAU37X 001027
    ROD: EV_DashBoardFPKAU37X.rod
    Address 19: CAN Gateway (J533) Labels:| 3Q0-907-530-V1.clb
    Part No SW: 3Q0 907 530 L HW: 3Q0 907 530 C
    Component: GW MQB High 518 5323
    Serial number: 30111710802799
    Coding: 030100040B0873005B00FF481C0B00000001000000000000000000000000
    Shop #: WSC 01357 011 00200
    ASAM Dataset: EV_GatewNF 013023
    ROD: EV_GatewNF_AU37.rod
    Alternator:
    Multi Function Steering Wheel Control Module:
    Subsystem 2 - Part No SW: 8W0 951 523 F HW: 8W0 951 523 F
    Component: J453 MFL H04 0002
    Serial number: 20170424194840 22142
    Battery Monitoring Control Module:
    Subsystem 3 - Part No SW: 5Q0 915 181 D HW: 5Q0 915 181 D
    Component: J367-BDM H08 0192
    Serial number: 00000000004051357328
    1 Fault Found:
    131689 - Rear View Camera System Control Module
    U104C 00 [008] - No communication
    [Timeout Knoten 0x69 / 6C - Steuergerät für Rückfahrkamerasystem]
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 23
    Reset counter: 4
    Mileage: 35250 km
    Date: 2020.05.16
    Time: 15:15:03
    Supply voltage: Terminal 30: 12.6 V
    Terminal 15: OFF
    Address 2B: Steer. Col. Lock (J764) Labels:* 5Q0-905-861.clb
    Part No SW: 5Q0 905 861 HW: 5Q0 905 861
    Component: ELV-MQBA H06 0010
    Revision: 00000000 Serial number: 13000084091001
    Coding: 0900000000000000
    ASAM Dataset: EV_ELVMarquMQB 003008
    ROD: EV_ELVMarquMQB_003.rod
    VCID: 73B224383B3BCB935E0-8026
    Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
    Part No SW: 5Q0 959 593 E HW: 5Q0 959 593 B
    Component: TSG FS 020 0041
    Serial number: 140815DHE13329
    Coding: 005F92205C01040000001002
    ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
    ROD: EV_DCUDriveSideEWMAXCONT.rod
    VCID: 43D2B4F82B1B3B130E0-8016
    Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
    Part No SW: 5Q0 909 144 L HW: 5Q0 909 144 L
    Component: EPS_MQB_ZFLS 119 1021
    Coding: 81
    ASAM Dataset: EV_SteerAssisMQB 008022
    ROD: EV_SteerAssisMQB_008.rod
    VCID: 3D26C2004DFF4DE3784-8068
    Address 47: Sound System (J525) Labels:* None
    Part No SW: 8V0 035 465 A HW: 8V0 035 465
    Component: MIBAMP1ALPINE H11 0370
    Serial number: AUZ8ZAD090098JE
    Coding: 01030300AAAA2AAA01
    ASAM Dataset: EV_AMPMst16C1ALPI 004024
    ROD: EV_AMPMst16C1ALPI_004_AU37.rod
    VCID: 3634DD2C68C99EBBB9E-8062
    Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
    Part No SW: 5Q0 959 592 A HW: 5Q0 959 592
    Component: TSG BFS 012 0006
    Serial number: 03051301100606
    Coding: 005796205401040000001002
    ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
    ROD: EV_DCUPasseSideEWMAXCONT.rod
    VCID: 3E24C50C40F956FB61E-806A
    Address 55: Headlight Range (J431) Labels:| 5Q0-907-357.clb
    Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
    Component: LWR-ECU 005 0070
    Revision: -------- Serial number: --------------
    Coding: 019E000001000000
    ASAM Dataset: EV_HeadlRegulVWLWRMQB 001110
    ROD: EV_HeadlRegulVWLWRMQB.rod
    VCID: 75B61A20354FD5A3704-8020
    Address 5F: Information Electr. (J794) Labels:* None
    Part No SW: 8V1 035 035 B HW: 8V1 035 035
    Component: MU-P-LND-EU 054 1106
    Serial number: A698I0H2530761
    Coding: 017353010000000031111102000A00102F0027A701700000DE
    Shop #: WSC 00046 123 12345
    ASAM Dataset: EV_MUHig6C3Gen2HBAS 001115
    ROD: EV_MUHig6C3Gen2HBAS_VW37.rod
    VCID: 313EEE3081A7B983ECC-8064
    Data medium:
    Subsystem 1 - Part No SW: V03 959 801 FD HW: -----------
    Component: ECE 2017/2018 --- 0161
    Serial number: --------------------
    Display unit 1 for multimedia system:
    Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
    Component: DU High H49 0014
    Serial number: AUZ8Z9H1Y05D3Y
    Multimedia Operating Unit:
    Subsystem 3 - Part No SW: 8V0 919 614 BE HW: 8V0 919 614 BE
    Component: ControlUnit_B H50 0103
    Serial number: ALJAL124051600010009
    Compact Disc Database:
    Subsystem 4 - Part No SW: V03 959 800 EG HW: -----------
    Component: Gracenote2 --- 1016
    3 Faults Found:
    3073 - Cellular Antenna
    B1053 13 [009] - Open Circuit
    [GSM/UMTS aerial - open circuit]
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 214
    Mileage: 35250 km
    Date: 2020.05.16
    Time: 14:49:14
    Voltage terminal 30: 14.3 V
    3084 - GSM antenna 2
    B1533 13 [009] - Open Circuit
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 214
    Mileage: 35250 km
    Date: 2020.05.16
    Time: 14:49:14
    Voltage terminal 30: 14.2 V
    7195 - Function Restricted due to Missing Message(s)
    U1111 00 [009] - -
    [Brake assist system (0x1B) - function restriction due to communication error - BapErr_retry not successful]
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 214
    Mileage: 35250 km
    Date: 2020.05.16
    Time: 14:49:15
    BAP-BAP_Function_ID: 02
    Address 6C: Back-up Cam. (J772) Labels:| 5Q0-980-556.clb
    Part No SW: 5Q0 980 556 B HW: 5Q0 980 556 B
    Component: RVC Compact H12 0231
    Coding: 02730101A2002001400040
    Shop #: WSC 06385 790 00016
    ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 006009
    ROD: EV_CamSysRVRVCPANAMQBAB.rod
    VCID: 392ED61059D771C354C-806C
    Address BB: Door Rear Drv (J388) Labels:* None
    Part No SW: 5Q0 959 595 E HW: 5Q0 959 595 B
    Component: TSG HFS 020 0041
    Serial number: 040915BI40481A
    Coding: 005F90205C01040000001002
    ASAM Dataset: EV_DCURearDriveMAXKLO 006003
    ROD: EV_DCURearDriveMAXCONT.rod
    VCID: 45D6AAE0252F0523204-8010
    Address BC: Door Rear Pass (J389) Labels:* None
    Part No SW: 5Q0 959 595 A HW: 5Q0 959 595
    Component: TSG HBFS 010 0006
    Serial number: 27041304081175
    Coding: 004F90204001040000001002
    ASAM Dataset: EV_DCURearPasseMAXKLO 006003
    ROD: EV_DCURearPasseMAXCONT.rod
    VCID: 41DEBEF0310729031CC-8014
    End----------(Elapsed Time: 01:46, VBatt start/end: 12.4V/12.4V)-----------
    Address 19,3Q0 907 530 L,channel IDE01996-ENG118288-Installation list: specified installations-Node_0x6C,adapted from,Not coded ,to,coded ,
    Address 19,3Q0 907 530 L,channel IDE01996-ENG118288-Installation list: specified installations-Node_0x6C,adapted from,coded ,to,Not coded ,
  28. DJAlix
    6,293
    4,806
    Have you tried clearing the errors then checking to see if they come back?
  29. ME CODING
    57
    yes they cleared away. i copied code to code from the thread on here. only error i get back is 37 - navigation error. but i believe we don't have this?
  30. ME CODING
    57
    i notice when i go to back up camera coding i don't see the options in byte 1 and 2. only when i go onto the yellow options
  31. DJAlix
    6,293
    4,806
    This would go a lot easier if you could detail what you have done so far in order to try and complete your retrofit. So far you seem to have cleared all the reversing camera related errors so it would seem that your physical retrofit is good. It would be good if you could detail what coding you have now completed, not everything that you have done, just whats been completed so I / we can get an handle on the current situation. If you have errors relating to things other than your camera retrofit then we can look at those after.
  32. ME CODING
    57
    So far i have done all coding as given from the thread at the start.
    Central 09 - add back up camera module
    Park assist - add/tick reverse camera
    Mmi 5f - adaptations. VPS activate and vps comfort databus.
    (I have checked park assist and is off)
  33. Avatar
    snack-media
    Advertisement
  34. DJAlix
    6,293
    4,806
    19 > Installation List > add 6C
    10 / 76 > Long Coding > Add Reversing Camera (if you have a 10 / 76 module)
    5F > Long Coding > Byte 19 > make sure reversing camera low is not ticked
    5F > Adaptations > VPS > Active
    5F > Adaptations > VPS Message Bus > Comfort or Infotainment (PFL) or Terminal 15 (FL)
    The above assumes your 6C is coded correctly.
    T-1000 likes this.
  35. ME CODING
    57
    @DJAlix I DONE IT :). THANK YOU FOR ALL YOUR HELP AS ALWAYS
  36. DJAlix
    6,293
    4,806
    More than welcome but for information purposes, incase someone else has trouble, could you detail what you did in order to resolve your issue?
  37. ME CODING
    57
    I had to use VCP for pram. After coding it accepted and worked. So am guessing it maybe from saloon and did not like it? Also can we get wide angle on these?
  38. DJAlix
    6,293
    4,806
    Camera should have worked regardless of which "A3" parameter set was loaded, maybe not correctly but should have worked as I have seen and tested this myself. My guess is that it had completely different parameters, maybe from a TT or something.
    Widescreen is not possible. This is not controlled via the camera its by design of the MIB2. Camera is full screen on MIB1.
  39. ME CODING
    57
    Yes didnt think that! it could be from TT. Was stated it was from an rs3 but they all write that on selling states now lol.
    Getting a basic setting error now..calibration time. Need them big checked sheets and ODIS for this?
  40. DJAlix
    6,293
    4,806
    Correct
  41. 1Rockape
    1Rockape Registered User
    86
    15
    @djalex is the calibration setting a service you offer ? Thanks
    Sent from my SM-G950F using Tapatalk
  42. DJAlix
    6,293
    4,806
    yes but to be honest with you, after testing with a couple of forum members vehicles and my own, there was no difference between A3 calibrated and un-calibrated camera function / operation.
  43. 1Rockape
    86
    15
    Yes mine is working fine but my ocd doesn't like the basic setting malfunction ! Just wondered what sort if price it would be
