Hi All,
I am new to the forum so apologies if this is not the correct area to post this. I have a 2012 8P that has recently stopped allowing me to lock the car with the remote. I can unlock the car with the remote but will not lock. Also the boot will not open, with the remote or the button on the tailgate. When i did an ECU Scan with Carista, it under the Body/Convenience system it said ECU Not Present.
I am also getting fault codes 03396 supply voltage terminal 30 for central-locking
00927 terminal 30 (Right).
I have checked all the fuses and they seem fine.
Can anyone offer me any advice on the location or how to fix this issue?
To add to this when the car is switched on (ignition or started) the central locking works with the buttons on the drivers door.
The car can’t be locked using the remote;
When using key in the driver’s door, only that door locks; and
The bootlid can’t be opened with the remote or manually, it remains permanently locked.
Any help would be much appreciated.
