Audi A3 8P 2.0TDI Fault Codes?
ddcboyle Jul 8, 2018
  1. ddcboyle
    ddcboyle New Member
    Hey,
    I just bought the above car on 7/7/18 (yesterday) and all seemed fine with the car. Drove it down the motorway (at speed) and the ESP warning light came on. It hasnt affected the performance or went into limp mode. Restarted car and fault code goes away, it pops up every so often during a drive.
    I ran VCDS on it, and got hit with numerous faults. So far ive checked on most and seem to be sensors here and there that I will replace.
    The four main ones im focusing on are: ESP light (why it keeps coming on), Rear right speed sensor , Rear right door module no signal (even though all electronics work), radiator fan 2.
    As for radiator fan 2 and the rear right door module no signal? Any ideas?
    Ive posted the VCDS codes below
    Code:
    Sunday,08,July,2018,21:19:19:24676
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
    VCDS Version: 18.2.1.2 (x64)
    Data version: 20180518 DS287.1
    www.Ross-Tech.com
    VIN: WAUZZZ8P18A055188   License Plate:
    Chassis Type: 8P (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 62 72
    VIN: WAUZZZ8P18A055188   Mileage: 151630km-94218miles
    01-Engine -- Status: Malfunction 0010
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000
    42-Door Elect, Driver -- Status: Malfunction 0010
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: Malfunction 0010
    56-Radio -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: Sporadic communication error 1000
    Address 01: Engine        Labels: 03G-906-016-BKD.clb
       Part No SW: 03G 906 021 LG    HW: 03G 906 021 AN
       Component: R4 2,0L EDC  000SG  9828
       Revision: --H07---    Serial number: AUX7Z0G7FND0RX
       Coding: 0000072
       Shop #: WSC 06314 000 00000
       VCID: 6FEDB0F07EFD683CCE-803A
    [B]1 Fault Found:
    006481 - Radiator Fan 2 (V177)
                   P1951 - 000 - Movement Restricted / Jammed - Intermittent
                 Freeze Frame:
                        Fault Status: 00100000
                        Fault Priority: 3
                        Fault Frequency: 16
                        Reset counter: 255
                        Mileage: 151516 km
                        Time Indication: 0
                        Date: 2018.06.01
                        Time: 15:54:21
                 Freeze Frame:
                        RPM: 1890 /min
                        Speed: 83.0 km/h
                        Load: 23.1 %
                        Voltage: 14.21 V
                        Bin. Bits: 00000000
                        Temperature: 91.8°C
                        Duty Cycle: 49.1 %[/B]
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
       Part No SW: 1K0 907 379 AC    HW: 1K0 907 379 AC
       Component: ESP FRONT MK60      0101
       Revision: 00H11001
       Coding: 0023170
       VCID: 73E5BC8012D54CDC2A-8026
    No fault code found.
    Address 08: Auto HVAC        Labels: 8P0-820-043.lbl
       Part No SW: 8P0 820 043 AG    HW: 8P0 820 043 AG
       Component: KlimavollautomatH19 0420
       Revision: 176957      Serial number: 8P0820043AG
       VCID: 71E9B68868C97ECCD8-8024
    2 Faults Found:
    01592 - Air Quality Sensor (G238)
                007 - Short to Ground
                 Freeze Frame:
                        Fault Status: 01100111
                        Fault Priority: 3
                        Fault Frequency: 77
                        Reset counter: 205
                        Mileage: 89845 km
                        Time Indication: 0
                        Date: 2014.11.12
                        Time: 12:47:58
                 Freeze Frame:
                        Temperature: -50.0°C
    [B]01334 - Door Control Module; Rear Right (J389)
                004 - No Signal/Communication - Intermittent
                 Freeze Frame:
                        Fault Status: 00100100
                        Fault Priority: 3
                        Fault Frequency: 14
                        Reset counter: 248
                        Mileage: 151225 km
                        Time Indication: 0
                        Date: 2018.05.25
                        Time: 10:08:43
                 Freeze Frame:
                            ON[/B]
    Address 09: Cent. Elect.        Labels:. 8P0-907-279-30-H.lbl
       Part No SW: 8P0 907 279 K    HW: 8P0 907 279 K
       Component: Bordnetz-SG     H54 2501
       Revision: 00H54000    Serial number: 00000007499093
       Coding: 01880F01B01410004F1600001600000000085E175C010000000000000000
       Shop #: WSC 06314 000 08192
       VCID: 458132580CC1826C54-8010
       Subsystem 1 - Part No: 8P2 955 119 E  Labels: 1KX-955-119.CLB
       Component: Wischer AU350   H01 0130
       Coding: 00062736
       Shop #: WSC 06314
    [B]1 Fault Found:
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 2
                        Reset counter: 248
                        Mileage: 151638 km
                        Time Indication: 0
                        Date: 2018.07.08
                        Time: 20:53:00
                 Freeze Frame:
                            ON
                        Voltage: 13.90 V
                            ON
                            ON
                            OFF
                            OFF
                            OFF[/B]
    Address 15: Airbags        Labels: 8P0-959-655-94.lbl
       Part No SW: 8P0 959 655 L    HW: 8P0 959 655 L
       Component:    Airbag 9.41  H01 4210
       Revision: 91H01421    Serial number: 003CP000JWEJ
       Coding: 0071612
       VCID: 4B9504602AA5741C82-801E
       Subsystem 1 - Serial number: 6332DRB405BB49A1Y
       Subsystem 2 - Serial number: 6342DRB405BB9329Y
       Subsystem 3 - Serial number: 63528RB402D374F9X
       Subsystem 4 - Serial number: 63628RB402D31F5BV
       Subsystem 5 - Serial number: 63747RB402A71585L
       Subsystem 6 - Serial number: 63847RB402A706FE
    Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
       Part No SW: 1K0 953 549 AH    HW: 1K0 953 549 AH
       Component: J0527           036 0070
       Coding: 0000012
       VCID: 78FF8BAC0BB32F841F-802C
    Address 17: Instruments        Labels: 8P0-920-xxx-17-MY8.clb
       Part No SW: 8P0 920 981 K    HW: 8P0 920 981 K
       Component: KOMBIINSTR. VDO H20 0640
       Revision: D0H20001    Serial number: 2247G001004651
       Coding: 0004428
       Shop #: WSC 00821 067 57207
       VCID: 408F234C13E3A74467-8014
    Address 19: CAN Gateway        Labels:. 1K0-907-530-V3.clb
       Part No SW: 1K0 907 530 L    HW: 1K0 907 951
       Component: J533__Gateway   H15 0180
       Revision:   H15       Serial number: 1400K0780984B2
       Coding: E9807F061002022103
       VCID: 306F738CA34337C497-8064
    [B]1 Fault Found:
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 3
                        Reset counter: 248
                        Mileage: 151638 km
                        Time Indication: 0
                        Date: 2018.07.08
                        Time: 20:53:58[/B]
    Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
       Revision: D0H20001    Serial number: AUX7Z0G7FND0RX
       Shop #: WSC 00000 000 00000
    Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN3.lbl
       Part No SW: 8P0 959 801 K    HW: 8P0 959 801 K
       Component: Tuer-SG         H03 0040
       Coding: 0000688
       VCID: 43852C4002F5BC5C7A-8016
    [B]1 Fault Found:
    02071 - Local Databus
                004 - No Signal/Communication[/B]
    Address 44: Steering Assist        Labels: 1Kx-909-144-G2V3.clb
       Part No: 1K2 909 144 M
       Component: EPS_ZFLS Kl.078 H08 1901
       Shop #: WSC 02069 000 90108
       VCID: 36634594412719F4CD-8062
    Address 46: Central Conv.        Labels: 8P0-959-433.lbl
       Part No: 8P0 959 433 J
       Component:    KSG          H10 0080
       Coding: 1980202002186D0985054C9FC637
       Subsystem 1 - Part No: 1K0 951 605 C
       Component: LIN BACKUP HORN H03 1301
       Subsystem 2 - Part No: 1K0 907 719 C
       Component: Neigungssensor  005 0003
       Subsystem 3 - Part No: 8P0 951 177
       Component: Innenraumueberw.H04 0020
    Address 47: Sound System        Labels: 8Px-035-382.lbl
       Part No SW: 8P4 035 382 D    HW: 8P4 035 382 D
       Component: AB2 SUBWOOFERBOXH06 0180
       Revision: 00005       Serial number: 30674703208745
       VCID: 356142985C2112ECC4-8060
    1 Fault Found:
    00422 - Rear Right DSP Midrange Speaker (R106)
                011 - Open Circuit
                 Freeze Frame:
                        Fault Status: 01101011
                        Fault Priority: 5
                        Fault Frequency: 1
                        Reset counter: 208
                        Mileage: 151638 km
                        Time Indication: 0
                        Date: 2018.07.08
                        Time: 20:53:59
                 Freeze Frame:
                        Temperature: 35.0°C
    Address 52: Door Elect, Pass.        Labels:. 1K0-959-702-MIN3.clb
       Part No SW: 8P0 959 802 K    HW: 8P0 959 802 K
       Coding: 0000688
       VCID: 44872F5C07FBBB6443-8010
    [B]1 Fault Found:
    Address 56: Radio        Labels: 8J0-035-1xx-56.clb
       Part No SW: 8P0 035 186 G    HW: 8P0 035 186 G
       Component: R Concert2+     H17 0240
       Revision: 00H17000    Serial number: AUZ1Z3G9228123
       Coding: 0010211
    Address 62: Door, Rear Left        Labels: 8P4-959-801.lbl
       Part No SW: 8P4 959 801 E    HW: 8P4 959 801 E
       Component: Tuer-SG         H04 0040
       Coding: 0000144
       Shop #: WSC 06314 000 1012544
       VCID: 4189264818E9AE4C68-8014
    Address 72: Door, Rear Right        Labels: 8P4-959-802.lbl
       Part No SW: 8P4 959 802 E    HW: 8P4 959 802 E
       Coding: 0001728
       Shop #: WSC 06314 000 1012550
       VCID: 428B29441DEFB55471-8016
    [B]2 Faults Found:
    00123 - Outside Warning Light/Door exit Light; Rear Right
                012 - Electrical Fault in Circuit[/B]
    End-------------------------(Elapsed Time: 01:42)--------------------------
  2. Avatar
    Google AdSense Advertisement
  3. ddcboyle
    ddcboyle New Member
    From a bit of research, some have said ESP light is linked to the rear right speed sensor and its just a bearing change needed. However, with it being rear right speed sensor and rear right door electronics faults? Not sure if its all linked being on same side?
  4. ch1z64
    ch1z64 C'mon you's bhoy's in Green Team Imola TFSI Owners Group Silver Supporter Team Sprint Audi S3 Manual
    3,204
    657
    It might be worth asking the Question about the ESP sensor and rear right speed sensor in the 8p section
