Audi a3 2.0 tdi dsg Esp, abs, fault lights
Wearside73
Hi guys
Had erratic gear changing on my Audi a3 for a few weeks. had it plugged in no fault codes then yesterday on the way to work the esp,abs came on.
I came to go home 8hrs later the abs stayed on when I started up then once I started moving it went out. Gears all over the place from 3 upwards feels like sport mode high Rpms etc.
It's done 100k in the service book no history of gearbox oil change it was booked in next week for a service at a audi independent specialist just hope it's nothing major
Mick
Hi guys
Mick
Is it doing a DPF regen is it? Mine will delay gear changes and raises idle to 1000 rpm in an effort to raise exhaust gas temperature to regen the DPF
If the box oil change hasn't been done get it and the filter changed as soon as you can. Once they've done that they should plug the car into VCDS and reset the gearbox too
Thanks for your reply getting it serviced next week
Had the car scanned no faults with the dsg but showing intermittent fault with right rear wheel sensor for the esp and abs fault that came up
Car serviced Mot and dsg oil change running smooth and rear wheel sensor was changed the hub had big cracking so was changed £680 lighter in the pocket
