Hi,
I have been experiencing a fault with my car recently, it started when driving home from work, I heard a loud bang, then it started kangerooing until I dropped the revs down. I then progressed to idle home, as soon as i touched the throttle it started kangerooing again. I disconnected the MAF sensor and it seemed to run smoothly but lacked power. I then bought a new MAF sensor and fitted this to find that it had made no difference. I then read about the swirl pot flaps are a commonish fault, I also found that the swirl pot actuator (vacuum) was making a strange noise, upon investigating found that it had a tear in the diaphram I bought a new one of these and fitted it, when fitting this i also cleaned my EGR valve and inlet manifold to remove any carbon deposits that had built up as the flaps where stiff to operate. Once I had done this, I tryed running it again to find I had gained nothing. I have taken it to my local garage and they have diagnosed it to be the MAF sensor. I have tryed a few MAF sensors and this is not seeming to be the problem. There are also no fault codes stored on the system. Any help would be hugely appreciated as this is becoming a large problem for me. Cheers
