Hello guys thanks for reading and help in advance .
Right so I've got the 01262 n75 static open code
So I've checked them ohms in the solonoid and I've got .029
The wires I've got is pin 1 has 0 volts and is yellow and black I've followed it all the way and i loose it in passengers footwell going behind dashboard
The other wire, pin 2 has 5.11 volts and I've followed back to the right plug on ecu
So any ideas what could be wrong ? I've still got the code and where does the yellow and black wire go? And is it meant to have 12 volts as all I keep reading seems to be different
I've checked the vacuum pipes all look okay but I've got no way of testing 100%
Thank you
Thank you
