  2. Dismiss Notice
Audi A3 09' 1.4 TFSI Trouble Starting.... Please Help (130k miles)
VAGorNothing Dec 21, 2019
  1. VAGorNothing
    VAGorNothing New Member
    25
    I've owned this car for about 2 weeks. Its had an intermittent issue where it would starts but then grind and conk out. Now it wont start at all.
    Heres the video. (Side note: the headlights would sometimes 'flicker" slightly like a fire light but no battery or engine warning lights would come on". Also I've changed to spark plugs and coil packs due to a seperate issue.
    Heres the video:
  2. Avatar
    snack-media
    Advertisement
  3. SootySport
    SootySport Well-Known Member Team Silver
    4,046
    1,080
    Cam belt or chain broke?
    I’m not familiar with 1.4’s so it’s a wild guess.
  4. John Lang
    John Lang Member
    58
    9
    Pretty sure the 1.4TFSI has a chain cam drive. Difficult to tell from the video but it doesn't sound healthy. I'd not try to start it until you have a proper diagnosis.
  5. VAGorNothing
    25
    yes it is chain driven, had the AA come out and said its the engine not getting enough fuel and the battery was weak. and the grinding noise is the flywheel being span out. he got it started by giving it alot of revs. got a new battery and fuel filter fitted (pressure in fuel system is ok), yet to test on cold start.
    AA Report:
    Vehicle struggles to start from cold, cranks starts briefly but spins out. Will start with little pressure on accelerator . Charge rate tested good 14.2 volts, battery test found battery to be weak and advised replacement. Advised fuel filter replacement if not had recently to help aid starting from cold. Advise compression checks . Vehicle starts well warm. Advise vehicle taken for further inspection .
  6. VAGorNothing
    25
    Just tried a cold start, similiar problem still persists after fuel filter and battery change.....
    think its time for an indy
  7. VAGorNothing
    25
    Video of the issue tonight. Starts fine if I rev it. No grindining noise anymore. Just cuts out
  8. John Lang
    John Lang Member
    58
    9
    That could be an immobiliser issue, try your spare key first.
  9. VAGorNothing
    25
    spare key works fine,
    had it VCDS scanned by a buddy and this is what came up.
    4 Faults Found:
    000022 - Bank 1: CMP Sensor (G40) / Engine Speed Sensor (G28)
    P0016 - 000 - Incorrect Correlation - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 0
    Fault Frequency: 32
    Reset counter: 255
    Mileage: 218290 km
    Time Indication: 0
    Date: 2019.12.22
    Time: 12:11:47
    Freeze Frame:
    RPM: 2324 /min
    Load: 65.9 %
    Speed: 52.0 km/h
    Temperature: 41.0°C
    Temperature: 10.0°C
    Absolute Pres.: 990.0 mbar
    Voltage: 14.224 V
    000768 - Random/Multiple Cylinder Misfire Detected
    P0300 - 000 - - Intermittent
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 218289 km
    Time Indication: 0
    Date: 2019.12.22
    Time: 12:07:13
    Freeze Frame:
    RPM: 793 /min
    Load: 29.4 %
    Speed: 0.0 km/h
    Temperature: 8.0°C
    Temperature: 8.0°C
    Absolute Pres.: 980.0 mbar
    Voltage: 13.970 V
    000771 - Cylinder 3
    P0303 - 000 - Misfire Detected - Intermittent
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 218289 km
    Time Indication: 0
    Date: 2019.12.22
    Time: 12:07:56
    Freeze Frame:
    RPM: 885 /min
    Load: 25.9 %
    Speed: 0.0 km/h
    Temperature: 12.0°C
    Temperature: 8.0°C
    Voltage: 14.351 V
    000772 - Cylinder 4
    P0304 - 000 - Misfire Detected - Intermittent
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 218289 km
    Time Indication: 0
    Date: 2019.12.22
    Time: 12:07:56
    Freeze Frame:
    RPM: 885 /min
    Load: 25.9 %
    Speed: 0.0 km/h
    Temperature: 12.0°C
    Temperature: 8.0°C
    Voltage: 14.351 V
  10. NHN
    31,119
    2,162
    Coilpacks, spark plugs are usual culprits, the speed sensor is an issue that needs fixing too.
    VAGorNothing likes this.
  11. VAGorNothing
    25
    hey, thanks for the reply,
    thing is, ive had the coil packs and plugs changed a month ago.
    the car starts fine when warm only when left sitting over night, i have to give it revs to get it started.
    also im experiencing a very LOW mpg. could this all be linked?
    no engine light but VCDS still shows the cam and engine speed sensor fault after the clear.
    would it just need a new cam and/or engine speed sensor? or could it be linked to a more serious isses? as it drives absolutley spot on with full power.
  12. Avatar
    snack-media
    Advertisement
  13. VAGorNothing
    25
    just had a cold start and starting moving straight away, engine light came on with eratic idles and throwing P0016 (cam crank correlation) same as VCDS scan, would replacing the two sensors fix it? the engine runs smoothly once warmed up, no sign of it being out of timing....
