L
labanauskas
Guest
Hi, everyone,
I'm facing problem with cold engine start, when cranking it feels like like not all not enough or too much fuel and and cylinders misfire or smth...
Turning off and then starting again is way better.
The problem appears after a car stood still for over the night or couple of hours. Sometimes it starts without a problem 1/2 crank hot/cold...
Here's a video:
Dropbox - VID_20150224_074954.mp4
Injectors at idle stabilization:
Glow plugs are new, oil and filters(fuel, oil) changed 5000km ago.
No fault codes
Fuel temp, engine temp sensors show correct temperatures. Crankshaft and camshaft are good.
Torsion value 0.0/0.5 .
So what can cause such a problem? Tandem pump? Air leakage? Leaking injectors? ECU engine start map?
Here's a video:
No fault codes
