Mine was supposed to arrive Friday and pushed back twice. Here's hoping it comes some time this week. But no biggie. Just typical of ups. Had the same a few times. It's like a they're waiting for a van to fill up.
I had a delivery advice for Last Friday, then during Friday a email popped up to pay the custom charges. Appears until the custom charges are paid, it was on hold in Germany.Mine was supposed to arrive Friday and pushed back twice. Here's hoping it comes some time this week. But no biggie. Just typical of ups. Had the same a few times. It's like a they're waiting for a van to fill up.
Mine was similar. Got the email on Thursday morning saying I needed to pay the fees so did it immediately and then it's taken almost a week to get from Germany to the UK. UPS could learn a thing or two from the Royal Mail I'd say!I had a delivery advice for Last Friday, then during Friday a email popped up to pay the custom charges. Appears until the custom charges are paid, it was on hold in Germany.
Whereas before, the package will arrive, then an email to pay the customs charges a few days later.
I looked and don't think that it looked identical to some that were previously listed in terms of wiring colours (but I only had a quick glance). He seemed to indicate that he was doing all of the group buy in one batch and mine works with no errors so I'd like to think yours is the same.I finally get my car today back from detailers but it's torrential rain in Glasgow today. And I've not got a garage. I should really check I've got the right loom before I start!
Thanks. I'll see how it goes. It's really wild outside.I looked and don't think that it looked identical to some that were previously listed in terms of wiring colours (but I only had a quick glance). He seemed to indicate that he was doing all of the group buy in one batch and mine works with no errors so I'd like to think yours is the same.
If you can find a parking lot or something then it only takes 15-20 minutes to install and the only tools I'd say you need are: plastic trim removers (or fingers if you can get a grip), 10 mm spanner/socket and some cable ties for keeping the unit and cables in place. One point to note is that the recommendation is to hook the earth wire on before the plugs.
Hope that helps for when you get to it.
Likewise where I'm at, I certainly wouldn't be sticking it on just now!Thanks. I'll see how it goes. It's really wild outside.
Is it me ?
Google Translate of ASR instructions:
The module can be activated and deactivated by pressing the "SET" button on the cruise control for approx. 10 seconds.
The successful activation or deactivation of the module is confirmed by switching the exhaust flaps several times.
The cruise control MUST be ENABLED for the module to be enabled and disabled.
You can always find out whether the module is activated or deactivated by double-clicking on the ESP.
If the flaps switch when you double-click the ESP button, the module is active. If the flaps don't turn on, it's disabled.
When I press the SET button, the flaps do oscillate as stated. However, the ESP button pressing twice quickly or slowly does not have any effect.
Tried on various modes, with engine running, driving and just on Accessory mode. Have I missed something.
Does sound really good and does not drone, as it did on the 8V OPF.
Thanks, will try that tonight.I was the same, I found that you have to really slow down the double click.
On the TC button for example, I wait until the message pops up on the dash saying it’s deactivated before pressing a second time. Much slower than I’d have thought you need to. Definitely count ‘one, one-thousand’ as you push the first time.
Just fitted mine.
Errors and not working. Guess I got the wrong loom.
Typical
Sent from came up with a handbrake error while I was fitting it but on the first drive it vanished and was alright, do you have errors staying up?
I've got a few. Airbag handbrake etcSent from my iPhone using Tapatalk
But when I hold down set for 10 secs I hear it doing something but I when I press set twice slowly its not doing anything.
What's the ESC button?
Thanks very much. I'd just assumed something was wrong even though it's the easiest install ever. That's my usual lol. Even using trim tools was overkill.ESC is just the traction control button. Same sort of speed as the pull on the cruise control stalk and it should work.
Gives me an excuse to open obd11!Yeah it’s genuinely easy if you know what you’re doing.
Hope the errors clear up and it’s all good because it think it definitely adds to the experience a bit.
Tried pressing the ESC slowly following Cruise SET Flap Confirmation a number of times. Can only hear the flaps during the 10 Second Set process using Cruise. ESC has no effect.My pleasure. If it’s still not working I can do a quick clip for the speed I do it.
Let us know how you get on.
Unplugged the cable to CB2, just in case to provoke power-off-on initialise, still no control using the ESC button.
Will ping a note to Daniel@ASR on what to do next, or if there is a reset sequence of CB2 to follow.
Yes Strange, as the ESC worked on initial connection. Then I tried to De-Activate using the 10Second Process. Now permanently stuck Open. Pinged an email to Daniel@ASR, Lets see if its something I am not following correctly, or may be a unit-reset sequence I need to follow, just in case I've partially bricked it.That’s strange you get the activation flap movement but not the actual valves working. That said, if it’s not under load when I do it sometimes I have to give it a little rev to see if they’re open at idle.
I had to go through the set thing for 10 seconds a number of times before it worked.
I can't be sure as I was just rushing through it but was there 3 long with you press set for 10 seconds and then next time 2 long and 1 short? Seemed like that to me but it was hard to hear and we had a helicopter do an emergency landing in the field next to me so I lost my place.
Other thing is, I parked up in supermarket and came back about 30 mins later and it was still ON. I thought it reset itself every start.. I'll need to check that again.
I thought you needed the start stop module for that. I kinda liked the idea of it resetting to avoid annoying the neighbours.That’s one thing it does seem to do is stay in whatever mode it was in when you turn the car off. I have to remember that when I turn the car off so that I don’t start it at 05.00 with the values full open during a cold start.
But this is the whole point of it…….hence why the valves stay open on next start cycle.
just cycle through to efficient mode before start up if you need quiet.
Ahh okay. I kinda like the stop/start...i even enjoyed the active cruise control today and lane assist........but as i type that i hear my bones creaking as 50 looms lolThat’s just for the stop start keeping its setting I think.
That’s fine, except sometimes I’m already in efficiency so I forget.
Odd, mine definitely started with the flaps open last time I left it. Although that was only a few minutes so I don't know if maybe after a certain amount of time it reverts? I've left them open when I parked up for work so I'll see what state they're in when I start up at the end of the day.Actually I’ve just started mine up in E as I left it in that last night and it starts up with flaps closed.
Depends on how you use the modesOdd, mine definitely started with the flaps open last time I left it. Although that was only a few minutes so I don't know if maybe after a certain amount of time it reverts? I've left them open when I parked up for work so I'll see what state they're in when I start up at the end of the day.
Just messed with itDepends on how you use the modes
Open the valves in any of the screens LH side modes (and leave it in that mode) and they will still be open on next start up and also do not close if you use the S mode by selection at the gear selector
Use any of the screens RH side RS modes and swap back to another mode and the flaps close
Stop the car in an RS mode and I assume the flaps will be closed on next start up as the car defaults to 'Auto' (I'm assuming this and stand to be corrected)
PS: Put the rear seats down (B&Q/tip etc) and either the valves or possibly the Soundaktor sound quite a bit louder
Thats not 8Y ?Just disabled it as mines finally in at the dealer for a new rack.
All I can say is this Round wheel is hideous.
I can’t see Alcantara or a dead ahead marker saving something this big and ugly
I have to admit, as soon as the car starts moving I don't even notice it anymore. Looking in and when I get into the car is the only time I really pay attention to it.Just disabled it as mines finally in at the dealer for a new rack.
Thats not 8Y ?
