Apple CarPlay not working with iPhone XS Max
Joetidman
Sadly my S5 sport back is refusing to work with my new XS Max phone on iOS12. It seems to think the phone is connected correctly, but basically I get a black screen inside the car, and can’t perform any functions.
Any ideas?
DarkyUK
Sorry, I know its no help at all but Android Auto works lovely :)
IJB1959
The MMI is not compatible with iPhone X (so I am told). You will need a software update from an Audi approved garage, or on your next service.
Joetidman
That’s interesting, I didn’t know that, I’ll contact Audi customer services and get their view
S32B
Any ideas?
That's odd, when I first got the car the screen of my phone had to be awake/showing for it to connect to the car, but now it just connects (ios bug maybe sorted out in an update!?!?), try making sure the phone is unlocked and the display is showing before connecting it to the car....maybe it's the same type of bug...worth a try!
I have the iPhone X running iOS12 and it works perfectly...no upgrade needed and mines a 67 plate.
NevMan
Well known member
Any ideas?
Working fine on my 2018 Q5 with iPhone XS. As you say, maybe you need MMI update
Tonye60
The car is probably in shock that someone has paid all that money for a phone, try it again next week. :yes::yes::yes:
Joetidman
So after a couple of restarts it started to pick up the phone and work, only to drop the connection after 10 or so seconds, the reconnect, rinse and repeat...
Maybe it’s the specific model of phone I have or just bad luck? Audi CS said that it’s so new they haven’t done all the compatibility tests yet, so perhaps an iOS patch or mmi patch needed
Very frustrating as my old iPhone 7 Plus was rock solid in the car
Joetidman
Lol, it’s only money ;)
Tbf the phone is amazing, lightning quick and beautiful screen and camera, just need the sodding thing to behave in my S5...
NevMan
Well known member
Sounds obvious but have you removed the phone from mmi and repaired, as well as removing Audi mmi from CarPlay setting on phone and re-adding?
Joetidman
Sorry what do you mean by repaired?
NevMan
Well known member
Sorry, re-pair, so go into menu and remove phone from Bluetooth, and remove Audi MMI from iPhone settings.
Then re-pair the phone to car, meaning turn on Bluetooth and pair with car, not needed for CarPlay I know but worth clearing everything as that is what I did before adding XS.
Plugging in phone to car will then kick off install of that
Joetidman
Thanks I was being dumb
NevMan
Well known member
Does Carpay work over bluetooth?? I always have mine plugged in..
No, it needs to be plugged in. I was just suggesting OP removed phone completely (incl bluetooth) and start fresh as new phone.
Incidentally BMW/Mini have the sole licence to use CarPlay without the need to plug in
SRB93
S5 B9 Coupe - Glacier White
NevMan
Well known member
I know mate. And conversely, I was confident my wife's new Mini JCW would work with Car Play, but because it doesn't have the "upgraded" touch screen with built in wireless, it doesn't :wtf:
My own fault for not researching more beforehand...lesson learned the hard way.
Joetidman
So I tried re-pairing everything from scratch and it appeared to work, although this morning I got another reconnect on the way to work. It’s annoying as it resets the satnav for some reason so you have to start that off again. Clearly some bug somewhere even though it’s not happening as often. Perhaps an apple iOS update will kick in in a few weeks to correct
NevMan
Well known member
sounds to me like a dodgy cable/connection if it is having to reconnect
IJB1959
Tried a friends iPhone X on mine and no joy at all. My iPhone 7 plus works great. Could there be a MMI software difference between 17 & 67 plates I wonder as someone reports it works on his 67 plate?
NevMan
Well known member
Does look as though 2018 MMI is fine, but as above appears to be "potentially" issue with 2017 and older.
IJB1959
Agreed, as I was told then the MMI needs an update. Not a big issue for me though so will wait until next service.
Benji315
Mine works absolutely fine and it's a 17 plate A5 S Line.
I had to allow it permission on the phone though.
chanlon1
I am having exactly the same issue
iPhone XS
2017 (MY2018) S5 Sportback.
I’m at the dealers next week so may ask them about the MMI update
Joetidman
Have you checked your cable? I had problems with a previous cable on my iPhone X. Swapped the cable and it worked fine.
I might try that. It’s worked flawlessly with my old iPhone 7 Plus all this time but it may be it
Joetidman
iPhone XS
Please do, it’s quite frustrating so would be good to know if they’re aware
Joetidman
rickparmar
Mine works wel XS Max. No issues at all
I was going to say maybe you’re having issues with the “charge gate” thing.
Have you updated your iPhone. There was a software update yesterday to fix the charging issue. 12.0.1
chanlon1
Phone has been updated to 12.0.1.
Issue with the layout of the Podcasts app has been fixed now, however, the phone still connect via CarPlay, then disconnects, then reconnects. This goes on for maybe 5-10 minutes and then seems to settle.
