  2. Dismiss Notice
Anyone with the CTS Turbo Inlet pipe have any WHP gains to share?
rcnacura Nov 28, 2016
  1. rcnacura
    rcnacura US Spec 8V
    788
    542
    93
    Was thinking about getting this instead of a full intake. Not really convinced a $500 intake, that nets about 10hp is worth the time/energy/justification.
    I've read someone where there was a 6-7whp gain... which is more in line of bang for the buck for me. Many have also stated that they felt there was more oomph in the car, but its hard to be able to tell such a slight hp advantage - I'm assuming the noise is what is the placebo. Was looking at getting the CTS Turbo Inlet pipe, along with a K&N filter, as the stock pipe looks to be quite the airflow bottle neck. Anyone with this piece have any dyno charts to share? CTS seems to not really advertise any numbers for any of their parts. TIA.
  2. Avatar
    snack-media
    Advertisement
  3. lenny151
    lenny151 Registered User
    505
    369
    I have a vwr600 intake with the cts turbo elbow cts turbo outlet pipe an cts throttle pipe I did notice a difference when I fitted them felt stronger an definitely makes more noise
    pburv, Rob2k68 and rcnacura like this.
  4. Rob2k68
    Rob2k68 Well-Known Member VCDS Map User
    7,357
    11,202
    I think the inlet pipe/elbow brings about 7hp on an S3.
    pburv and rcnacura like this.
  5. jungle650
    jungle650 Registered User
    830
    1,428
    93
    @batch had one fitted and he had his car placed on a dyno then re-dynod after several mods were placed back on the car. There is a post somewhere. From memory the CTS elbow added about 7-10bhp where as the air intake added close to zero with only marginal torque and response numbers- all though they do look better under the bonnet. Worth a purchase.
    pburv, rcnacura and Rob2k68 like this.
  6. batch
    batch Registered User
    2,498
    3,288
    This is correct. MTM Cantronic on, made just over 360hp. CTS TIP added with standard intake and Forge induction pipe took it to 375, adding the VWR R600 added nothing more, but Improved the power/torque curve and response, lowering intake temps.
  7. rcnacura
    rcnacura US Spec 8V
    788
    542
    93
    Alright, thats music to my ears. I'll go ahead and order one since its on sale at the moment. Thank you all for the information!
    pburv, batch and Rob2k68 like this.
  8. Chris E
    Chris E Registered User
    94
    151
    33
    Where have you seen this on sale? i need to order one but was tempted by the racingline one from awesomegti as it's down to £113.
    pburv and Rob2k68 like this.
  9. rcnacura
    rcnacura US Spec 8V
    788
    542
    93
    Moddedeuros.com has for $110.49 at the moment. Link in original post, however shipping might be a little crazy overseas. Bunch of black Friday sales going on here in the states. Today (cyber Monday) being the last day.
    Sent from my SM-N910V using Tapatalk
  10. Pederson
    Pederson Registered User
    221
    160
    43
    That CTS elbow looks really simple, think I'll have a look at making my own.
    pburv likes this.
  11. Rob2k68
    7,357
    11,202
    The way it interlocks to the turbo via 3 lugs and the 'O' ring seal to the turbo itself will play a large part in how successful you are - any air leak and you'll loose boost or throw a MIL on the DIS.
  12. Avatar
    snack-media
    Advertisement
  13. MikeParkin
    MikeParkin Registered User
    1,813
    1,308
    Or the EPC light :whistle2:
  14. Pederson
    221
    160
    43
    I've pinged it across to my pal to see what he says, no harm in asking so will wait and see what he says!
  15. Forbzeeee
    Forbzeeee Well-Known Member VCDS Map User
    982
    471
    $57 shipping the the UK seems a bit excessive to me... Anyone know of any other suppliers?
  16. batch
    2,498
    3,288
    Brotek - @Brodster
    Forbzeeee, pburv and Rob2k68 like this.
  17. rcnacura
    rcnacura US Spec 8V
    788
    542
    93
  18. Rob2k68
    7,357
    11,202
    Also PSI Tuning and Statller Power Developments, with Brotek they are your best bets in the UK.
    I have shipped direct from CTS previously for my other pipes (turbo outlet and throttle pipes complete the set of boost pies) , they arrived super quick in 3 days but watch out for the customs bill that arrives a week or so later !!
  19. MikeParkin
    1,813
    1,308
    I had a bit of an issue with my CTS pipe as it kicked up the EPC light and it was a boose leak (over boost). Swapped it back to original and was fine, still not sure if my car was pushing to much power or torque for the pipe as I have a de-cat.
    The issue happened @5000rpm from 3rd upwards but that where max torque is. 5th gear was the most common time it happened.
    I did hear there was a bad batch but mine was from the group buy a while ago.
  20. batch
    2,498
    3,288
    Just as a side note, my OEM one was hanging off when I came to swap the CTS pipe in! Torx bolt only screwed into the turbo housing, not in far enough to retain the pipe, which was wobbling about!
    rcnacura, MikeParkin and Rob2k68 like this.
  21. rcnacura
    rcnacura US Spec 8V
    788
    542
    93
    @MikeParkin was yours pretty loose? Was reading the early ones might of been too small, however the OEM wasn't a tight fit either. Hope this isn't the case for me.
    @batch, was the screw long enough for the CTS to be secured in? Maybe I should use loktite.
  22. MikeParkin
    1,813
    1,308
    Jeez! Were you not getting any lights up @batch ?
    The OEM pipe has a very tight and snug fit.
    I'm not sure to get another CTS or something else once I go for full torque map.
    Rob2k68 likes this.
  23. MikeParkin
    1,813
    1,308
    I just think it wasn't tight enough into the turbo but the screw was as tight as it could go @rcnacura so must of been faulty but I'd like to try another CTS to be sure.
  24. batch
    2,498
    3,288
    The screw was fine, good few turns to tighten it with the CTS fitted. Don't panic!
    My pipe wasn't! Screw wasn't even finger right and pipe wasn't fully twisted home. Friday afternoon job?!
  25. Rob2k68
    7,357
    11,202
    I bought my CTS pipe just before the group buy albeit from a different supplier (different batch?) and it's been fine nice and snug into the turbo.
    Removed it last week when fitting the GFB DV+ and checked then - no fit issues.
  26. MikeParkin
    1,813
    1,308
    Oh well, I may buy a new one in the new year or buy the turbo technics kit.
  27. SevenW
    SevenW Registered User
    175
    187
    43
    Good write up guys, informative I was going to pounce on one a couple of months ago then they dropped a few dollars a week ago, I had to get it!
    I read CTS had bad QC in a couple of batches, looking at what arrived today mine looks pretty good. Roll onto the weekend and I can bolt it on and try it out.
    zippster, MikeParkin and batch like this.
  28. batch
    2,498
    3,288
    What's this DV+ malarkey @Rob2k68 ?
  29. Rob2k68
    7,357
    11,202
    It's a diverted valve than can vary its position rather than just 'on' or 'off' like the OEM one which helps to maintain boost and improve throttle response ....
    http://www.gfb.com.au/products/blow...359-suits-vw-mk7-golf-r-and-audi-8v-s3-detail
    Now that I've gone for all CTS boost hoses and an upgraded intercooler I didn't want the DV to be the weakest link ! Seems good so far much more consistent boost between gear changes.
    pburv, batch and MikeParkin like this.
  30. MikeParkin
    1,813
    1,308
    I'm contemplating this at some point! So I take it you recommend this @Rob2k68 ?
  31. Rob2k68
    7,357
    11,202
    Yeah seems to be working well mate - nice piece of kit ;o)
    Only just fits next to the CTS inlet though .....
    pburv, MikeParkin and Chris E like this.
  32. Chris E
    94
    151
    33
    Easy enough to fit then?
  33. Avatar
    snack-media
    Advertisement
  34. Rob2k68
    7,357
    11,202
    Yes mate 3/4 hour taking it steady - just stuff loads of rags behind the turbo so you don't drop any bolts and make sure you oil the piston as per the instructions.
    pburv and Chris E like this.
  35. MikeParkin
    1,813
    1,308
    Nice. I'll see how the new year goes first @Rob2k68.
    Plenty other mods to be had Haha
  36. Rob2k68
    7,357
    11,202
    LoL I'll probably get the Revo carbon air box lid when it's released then look at getting it detailed again and then it'll need a service when it's two years old in March.
    pburv and MikeParkin like this.
  37. MikeParkin
    1,813
    1,308
    Haha it never stops.
    I'll be detailing mine in the new year my self. May have a big turbo by the end of the year but we see how it goes.
    Rob2k68, batch and pburv like this.
  38. Rob2k68
    7,357
    11,202
    Anyone about to fit a CTS Turbo Inlet/Elbow don't forget to remove the 'O' ring from your original inlet and fit it to the new one before bolting it on to your engine!
    Chris E and batch like this.
  39. zippster
    zippster Registered User
    702
    934
    93
    what is the hose piece called? i have a TIP (great bit of kit) but I'm using the OEM pipe and would like to replace it..
    Thanks in advance
    Andy..
  40. MikeParkin
    1,813
    1,308
    Rob2k68 likes this.
  41. zippster
    702
    934
    93
    thanks do you have a link to where i can get said pipe please ?
  42. batch
    2,498
    3,288
    Standby @zippster I shall find it - I got the Forge one.
    MikeParkin and zippster like this.
  43. batch
    2,498
    3,288
    Rob2k68, MikeParkin and zippster like this.
