Power/tailgate kits are available from the usual sources, was just wondering if anyone has tried it - was it difficult? does it require any coding? any guides that you found useful? (search results on this forum doesn't bring back much) thanks!
Was never an OEM option so anything available as a kit would be put together as a 3rd party offering, maybe using OEM parts from other cars like the Q2. I have done a number of vehicles like the Q2 and it’s not a major retrofit effort wise, cost is another story.Power/tailgate kits are available from the usual sources, was just wondering if anyone has tried it - was it difficult? does it require any coding? any guides that you found useful? (search results on this forum doesn't bring back much) thanks!
Is the q2 a straight fit for the a3 sportback?Was never an OEM option so anything available as a kit would be put together as a 3rd party offering, maybe using OEM parts from other cars like the Q2. I have done a number of vehicles like the Q2 and it’s not a major retrofit effort wise, cost is another story.
I would say no to be honest.Is the q2 a straight fit for the a3 sportback?
Been looking at some aliexpress kits as this is a retrofit/mod I want.
so thing like this
So aliexpress kit then or no to that as well?I would say no to be honest.
Was never an OEM option for the A3 so any kit or installation of parts is going to be a gamble.So aliexpress kit then or no to that as well?
Have you came across any good kits your customers have used? Other than aliexpress there doesn’t seem to be anyone making any.Was never an OEM option for the A3 so any kit or installation of parts is going to be a gamble.
Not for the A3 no. I have completed OEM installations on vehicles that had power tailgate as a factory option, ie Q2, Q5’s, Q7’s and an A6. The only kits I have seen used on the A3 are the “pop n lift” replacement struts which are auto open and manual close.Have you came across any good kits your customers have used? Other than aliexpress there doesn’t seem to be anyone making any.
Don’t need to install the internal release button but yes, cables need to run from front to back for button and power. You will also need to make / drill holes on your body to pass new cables through.Thanks for all the info so far, very useful. Beginning to look at the required parts and what it would actually take to retrofit into a Audi Q2. Does the driver's door boot-open button connect to the door module? or does it run cables back to the power tailgate module? i.e. it would certainly make it easier if I only need to run cables from the boot to the front fuse box through the passengers side of the car.
Thanks, great info - good to hear that it will still work without the internal release button being connected. When installed from factory, do you know where the electric boot module is normally located? would there already be a bracket or screw holes in place for it to be fitted if not originally installed?Don’t need to install the internal release button but yes, cables need to run from front to back for button and power. You will also need to make / drill holes on your body to pass new cables through.
On the C pillar. Mounting points are already there.Thanks, great info - good to hear that it will still work without the internal release button being connected. When installed from factory, do you know where the electric boot module is normally located? would there already be a bracket or screw holes in place for it to be fitted if not originally installed?
Module connects to car, it CAN and power, then struts etc to module.
Position / stand up the new struts and you will see that there is a small cable that needs to route in inside the car, this is what needs drilling. My SQ5 is the same:
You should be good to go to be honest. As long as your boot latch releases when you press and hold the boot release button on your key then it should be almost plug and play… as long as your module is pre-coded.
Hi thereManaged to find the pin diagram, the driver's door boot open/close button is now working perfectly - for those reading the thread in the future, these are the pin connections.
The button connects straight to the door module, to the light blue vertical 32 pin connector.
- pin 1 button --> pin 5 of 32 pin connector (ground)
- pin 2 button --> pin 5 of 32 pin connector (ground)
- pin 3 button --> pin 4 of 32 pin connector (illumination)
- pin 4 button --> pin 23 of 32 pin connector (signal)
Hi there
I’m planning on doing a retrofit on my A3 SLine sport back 8y. How far did you get with tracking down the parts needed. So far I have struts, a button and locking mechanism 8Y4827851
I’m puzzled by the button for the inside of the boot though as it has two buttons - surely it’s just 1 function to close it as it’s inaccessible when closed??
