hollows wife
Has anyone managed to sort the bulb error warning for the later 2010 onwards cent elec controller . the 2009 and below was easy as cold diagnostics could be turned off and led rear bulbs used .
been trying it on the newer controller which to an extent works except for if the brake lights are on for more than approx 5 seconds . then right rear brake light warning appears . so i fitted ballast resisitors . to both of the rear brake lights on the outer cluster (sportback) this only makes it worse get both left and right warning and also get open circuit error then lights turn off .
had to revert back to the old bulbs for now but i think it spoils the rear lights the led look so much clearer and respond alot quicker .
