Anyone running 20" alloys on their A6 ??
seasidestevo Jun 14, 2018
  1. seasidestevo
    seasidestevo Member
    65
    15
    hi,
    i drive a 2010 a6 le mans with the standard 19" twin spoke alloys and 255 x 35 x 19 tyres
    i've bought a set of 20" alloys - tyres are currently 245 x 45 x 20 and a lot bigger in circumference when i stand them next to my standard ones.
    What tyre sizes are you running on 20" alloys ??
    i've done a quick online check and putting 30's on will give the same circumference as standard.
    Cheers!
    Stevo
  2. Avatar
    Google AdSense Advertisement
  3. Misikee
    Misikee New Member
    25
    Hello!
    I use 20” with 245/35r20 tyres on my 2006 c6 avant. S8 wheels et46
    Az én iPhone készülékemről küldve a Tapatalk segítségével
  4. seasidestevo
    seasidestevo Member
    65
    15
    :icon thumright: thanks for the reply
    i don't want them to look lost if i put 30's on if 35 will fit under the arches
  5. Gazwould
    Gazwould Well-Known Member
    6,596
    2,698
    What on earth is this bigger is better culture all about ?
  6. seasidestevo
    seasidestevo Member
    65
    15
    i'm 6'5" tall, bigger is better ha ha
    not saying its better, i prefer the look of the bigger wheels, each to their own mate
  7. Gazwould
    6,596
    2,698
    6'5" peeps stoop because of low door ways .
    Just one up to many downsides .
    19" + low profile , not fit for purpose on Britain's broken roads .
    Roadrunner146 and daytonamart like this.
  8. seasidestevo
    seasidestevo Member
    65
    15
    Thanks for your input, not really answered my question though
  9. Mollygoogle
    Mollygoogle Member
    290
    15
    There are a couple of good sites like wheel-sizes.com and wheelfitment.eu for checking factory sizes of cars. A 2010 is shown as using 255/30. A 30 profile tyre will look fine
  10. seasidestevo
    seasidestevo Member
    65
    15
    Brilliant, thank you
  11. WesT-gefül
    WesT-gefül Well-Known Member Bronze Supporter
    764
    251
    Currently driving a courtesy A6. 255/35/20 tyres on it. But it’s a c7
  12. Avatar
  13. Mollygoogle
    Mollygoogle Member
    290
    15
    You’re welcome
  14. seasidestevo
    seasidestevo Member
    65
    15
    WesT - the ones i bought are off a later A6 Avant with 45's on but the wheel arch must be a lot bigger - i put them to the side of mine and looked massive in comparison, was hoping 35's would be ok
  15. WesT-gefül
    764
    251
    What are your OEM sizes. Give me the offset of a OEM rim and tyres and the offset for the new rim and tyres size and I’ll see how far your speedo will be out. /45 might be pushing it especially with 20” in terms of clearance in the arches.
  16. Mollygoogle
    Mollygoogle Member
    290
    15
    The rolling radius between the stock 19’s and the tyre size I’ve suggested are the same. The speedo won’t be out.
  17. seasidestevo
    seasidestevo Member
    65
    15
    wheels i've bought are e8jx20h2 et25
    i've had a check and if i put 30's on the rolling circumference is the same as my standard 19's with 35' on.
    was hoping to put 35's on the 20" - the 45's currently on deffo are too big to fit under the c6 a6 arches
    i know the speedo will be slightly out but only minimal and of no notice
  18. AFONE
    AFONE New Member
    I’m still trying to sort out why my 19in wheel is scraping the rear fender liner. I can only imagine the issues that 20s would cause.
  19. Mollygoogle
    Mollygoogle Member
    290
    15
    There is no correlation. A 20" wheel and tyre is the same size as a 19" wheel and tyre combo. The width and offset are far more relevant.
    Are you rubbing on both sides or on one? What size tyres? What suspension?
  20. AFONE
    AFONE New Member
    I’m only rubbing on the right rear wheel. Running H&R springs with 255/35/19s and 19x5x8.5 et 38 wheels. Seems that the right rear side sits slightly lower than the left. [​IMG]
  21. Mollygoogle
    Mollygoogle Member
    290
    15
    You may have the same problem as me. Look down on your rear wheels from above and see whether you think the wheel that rubs is sticking out further from the bodywork than the one that doesn't
  22. AFONE
    AFONE New Member
    Yes, the side that rubs sticks out slightly more than the other side. The shop said that it’s because the fuel tank fill pipe is on that side.
  23. Mollygoogle
    Mollygoogle Member
    290
    15
    The shop are wrong. On my car it is the opposite side that sticks out further. I have an active thread about the subject at the moment. B5NUT confirms that the rear subframe is adjustable so it can be rectified
  24. Mollygoogle
    Mollygoogle Member
    290
    15
  25. AFONE
    AFONE New Member
    Excellent info. I’ll jump onto your thread and let you know if I resolve.
    To the OP, apologies for hijacking your thread.
  26. WesT-gefül
    764
    251
    Edit: it’s the other way round. It’ll be further out.
    Can you give the OEM wheel figment so we can calculate the difference and see how far it will poke.
  27. Gazwould
    6,596
    2,698
    Other way around , ET25 is further away from the strut / more wheel arch poke .
    WesT-gefül likes this.
  28. WesT-gefül
    764
    251
    Yes you are right.
