What pads and polishes do you use ? Mine is Nardo and suspect it is very soft in comparison to normal Audi paint.
I have the flex xfe mini xfe 7-12-80 polisher and the Dual action xfe 7- 15-150 and its the orange and purple flex pads you want best try a One Step paint correction compound like the Sonax perfect finish far better and easier to use and correct than with the scholl S20 .....Thanks, that really is helpful, I have a voucher to get the Flex XCE corded, thats why I asked about the 5" backing plate and the Flex pads. A 1 step with the Schol S20 and Orange pad seems a good idea
Not much difference between either mate to be honest the Green pad is the Heavy cut pad from Flex it's a very hard pad...like in all pad ranges the difference between a polishing pad and heavy polishing pad are most of the time nominal the flex Red soft polishing pad for instance is poor and a waste of moneyThank you.
Is the purple not a heavy cut pad ? Will that not be too much for the spider webs I have ?
Yes the pad polishing surface is wider the backing plate surface ie its slightly coned shapedI assume I need the 5" pad for the 5" backing plate Jassyo ?
Excuse my ignorance, but would perfect finish be too aggressive to remove light wash swirls ? I want to remove as little clearcoat as possible if any at all .
