Wednesday,05,April,2017,10:44:00:07086
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 17.1.3.0
Data version: 20170203 DS267.2
www.Ross-Tech.com
VIN: WAUZZZ8F4******* License Plate:
Chassis Type: 8F (8T0)
Scan: 01 03 05 08 09 10 15 16 17 19 26 42 46 52 53 55 56 5F 62 72
VIN: WAUZZZ8F************ Mileage: 106550km-66207miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
26-Auto Roof -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Malfunction 0010
72-Door, Rear Right -- Status: Malfunction 0010
Address 01: Engine (J623-CAHA) Labels: 03L-906-019-CAG.clb
Part No SW: 03L 906 022 NP HW: 03L 906 019 AL
Component: R4 2.0l TDI H34 9978
Revision: 25H34---
Coding: 22194012232503080000
Shop #: WSC 53439 002 1048576
ASAM Dataset: EV_ECM20TDI03L906022NP A02012
ROD: EV_ECM20TDI03L906022NP.rod
VCID: 0005934E9B18AD41E9-8054
2 Faults Found:
4901 - Engine Mount Solenoid Valves (N144/N145)
P1588 00 [039] - Open Circuit
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 106557 km
Date: 2017.04.05
Time: 10:38:15
Engine speed: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 11 °C
Intake air temperature: 11 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 12.160 V
Unlearning counter according OBD: 40
EM Dmp st Ps 0-Bit 0: 00000000
4640 - Engine Oil Temp. Sensor (G8)
P0197 00 [039] - Signal too Low
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 106557 km
Date: 2017.04.05
Time: 10:38:17
Intake air temperature: 10 °C
Fl Sys dvol Fl Cons All Tot: 0.00 l/h
Engine oil temperature: 22.3 °C
Oil warning threshold: 31.500 mm
Control Module temperature: 13.6 °C
Oil fill level: 120.000 mm
Ambient temperature: 6.5 °C
Fuel temperature: 11.4 °C
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (J104) Labels: 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 BF HW: 8K0 907 379 BF
Component: ESP8 front H04 0030
Revision: -------- Serial number: --------------
Coding: 160504
Shop #: WSC 02391 823 56573
VCID: 7EF9EDB6E9ECDBB19B-802A
No fault code found.
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 CP HW: 8K0 907 064 CP
Component: BCM2 2.0 H05 0435
Revision: 00002001
Coding: 033300
Shop #: WSC 02399 823 56573
VCID: 0005934E9318AD41E9-8054
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H60 0072
Serial number: 0811000023921017
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H37 0042
Serial number: 2311000031755008
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8T2 820 043 AG HW: 8T2 820 043 AG
Component: KLIMA 3 ZONEN H08 0180
Revision: D1000000 Serial number: 01120320111037
Coding: 34370000
VCID: 77F7F892C6D6EAF9D8-8022
1 Fault Found:
00898 - Control Circuit A/C compressor
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 6
Fault Frequency: 16
Reset counter: 207
Mileage: 104859 km
Time Indication: 0
Date: 2017.02.04
Time: 13:09:15
Freeze Frame:
Current: 0.600 A
Current: 0.000 A
Voltage: 13.60 V
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
Component: BCM1 1.0 H30 0392
Revision: 10030001 Serial number: 00000000978631
Coding: 260050914034AF000009000300005D5D411D038806010141000000
VCID: 3C7D27BEBF7009A1F5-8068
Subsystem 1 - Part No SW: 8F2 955 119 HW: 8K2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 230211 H06 0021
Serial number: SWF11020235106
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 11313691
Coding: 02562A
Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
Component: E1 - LDS H03 0031
Serial number: 00000000001902110631
1 Fault Found:
01232 - A/C Compressor Regulator Valve (N280)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 2
Fault Frequency: 15
Reset counter: 197
Mileage: 104261 km
Time Indication: 0
Date: 2017.01.22
Time: 13:45:00
Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
Part No SW: 8K0 919 475 T HW: 8P0 919 475 M
Component: PARKHILFE 4K H01 0080
Revision: 11001001 Serial number: 36891106348599
Coding: 100001
VCID: 4A917166E5A4A71177-801E
Address 15: Airbags (J234) Labels: 8F0-959-655.clb
Part No SW: 8F0 959 655 C HW: 8F0 959 655 C
Component: AirbagVW-AU10 H11 0430
Serial number: 003JND702EUP
Coding: 30413635353130303030554A305238463053
Shop #: WSC 02135 785 00200
ASAM Dataset: EV_AirbaAU10SMEAU485 001004
ROD: EV_AirbaAU10SMEAU485.rod
VCID: 38753BAE8348258111-806C
Crash sensor for side airbag: driver side:
Serial number: 6334MSME5C740F0CS
Crash sensor for side airbag: front passenger side:
Serial number: 6344MSME5C633314B
Crash sensor for side airbag: rear: driver side:
Serial number: 6352QSME081D3568L
Crash sensor for side airbag: rear: passenger side:
Serial number: 6362QSME06000A543
Crash sensor for front airbag: driver side:
Serial number: 63732SME1F074C421
Crash sensor for front airbag: front passenger side:
Serial number: 63832SME1F07357E9
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H17 0014
Revision: -------- Serial number: 90372KC60000T
Coding: 000016
VCID: 3D7B2ABAA46A00A9C2-8068
Component: E221 - MFL H02 0010
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8T0 920 983 B HW: 8T0 920 983 B
Component: KOMBIINSTR. H41 0258
Revision: 00000000 Serial number: EHY20M63C
Coding: 2F05180002002600010000
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 AD HW: 8T0 907 468 K
Component: GW-BEM 4CAN-M H09 0117
Revision: EC000056 Serial number: 5600E112170385
Coding: 00CF07
VCID: 030F9C42820EB659F4-8056
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0140
Serial number: 00000000005650678839
Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Component: J532_DCDCStab H17 0042
Serial number: 11062000554011200181
2 Faults Found:
03041 - Energy Management Active
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 28
Reset counter: 234
Mileage: 104364 km
Time Indication: 0
Date: 2017.01.25
Time: 07:54:00
Freeze Frame:
Bin. Bits: 00000
Voltage: 12.60 V
Count: 17
02256 - Quiescent Current
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 7
Fault Frequency: 28
Reset counter: 234
Mileage: 104364 km
Time Indication: 0
Date: 2017.01.25
Time: 07:54:00
Address 26: Auto Roof (J256) Labels: 8F0-959-255.clb
Part No SW: 8F0 959 255 HW: 8F0 959 255
Component: VSG-AUDI-B8 H11 0190
Coding: 010000
ASAM Dataset: EV_ElectRoofContr 001008
ROD: EV_ElectRoofContr.rod
VCID: 71E3C68AA0B2B4C916-8024
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8T0 959 793 M HW: 8T0 959 793 D
Component: TSG FA H08 1501
Coding: 011042724009330C03
VCID: 53AF6C0232EEE6D904-8006
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0145159121
Coding: 011F06A200B904608220033680000000
Subsystem 1 - Part No: 8P7 951 177
Component: DWA-Sensor H03 0050
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
1 Fault Found:
01518 - Bulb for Back-Up Lights; Left (M16)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 229
Mileage: 106343 km
Time Indication: 0
Date: 2017.03.26
Time: 17:57:20
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8T0 959 792 M HW: 8T0 959 792 D
Component: TSG BF H08 1501
Coding: 011042324009330C03
VCID: 52A169060DF4EFD10F-8006
1 Fault Found:
02124 - Exterior Door Handle Switch
Freeze Frame:
Fault Priority: 3
Fault Frequency: 33
Reset counter: 213
Mileage: 104320 km
Time Indication: 0
Date: 2017.01.24
Time: 19:30:46
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 10000000747447
Shop #: WSC 00000 000 00000
VCID: 346D0F9E9720C1E13D-8060
Address 55: Headlight Range Labels: 8K0-907-357.clb
Part No: 8K5 907 357 B
Component: Dynamische LWR H02 0010
Revision: 00000001 Serial number:
Coding: 0000001
Shop #: WSC 02145 785 00200
VCID: 39733EAA70423C89EE-806C
Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4G0 035 056 HW: 4G0 035 056
Component: Radio U STD H52 0051
Revision: AB001007 Serial number: 469C90B7689590
Coding: 010003020100000101
VCID: 5EB98D36492C3BB1BB-800A
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 8T2 035 666 H HW: 8T2 035 666 E
Component: H-BN-EU H51 0146
Revision: -------- Serial number: 475C00B7565078
Coding: 010101030006C1ED01000F1E000000010101
VCID: 4085534ED3986D41A9-8014
Subsystem 1 - Part No: 8R0 060 884 N
Component: EUR 2011 1205
Subsystem 2 - Part No SW: 8R0 919 604 HW: 8R0 919 604
Component: DU7 High H41 0104
Serial number: A130LD0BS084508
Subsystem 3 - Part No SW: 8T0 919 609 F HW: 8T0 919 609 F
Component: E0380 Bedient H08 0100
Serial number: 00000000771420
Subsystem 4 - Part No: 8R0 060 961 A
Component: CD-Database 2712
1 Fault Found:
03276 - Please Check Software Version Management
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 197
Mileage: 106557 km
Time Indication: 0
Date: 2017.04.05
Time: 10:29:46
Freeze Frame:
Voltage: 11.70 V
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8T0 959 795 L HW: 8T0 959 795 C
Component: TSG HL H07 1501
Coding: 010002324009370C03
VCID: 54AD6F1E37E0E1E11D-8000
1 Fault Found:
03531 - Belt Assistant
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 3
Fault Frequency: 11
Reset counter: 236
Mileage: 104242 km
Time Indication: 0
Date: 2017.01.21
Time: 22:25:55
Address 72: Door, Rear Right (J389) Labels: 8K0-959-794.clb
Component: TSG HR H07 1501
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 81
Reset counter: 237
Mileage: 104278 km
Time Indication: 0
Date: 2017.01.23
Time: 19:07:38
End-------------------------(Elapsed Time: 03:51)--------------------------
www.Ross-Tech.com
Revision: 25H34---
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 106557 km
Date: 2017.04.05
Time: 10:38:15
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 106557 km
Date: 2017.04.05
Time: 10:38:17
Coding: 160504
Revision: 00002001
Coding: 033300
Coding: 34370000
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 16
Reset counter: 207
Mileage: 104859 km
Time Indication: 0
Date: 2017.02.04
Time: 13:09:15
Freeze Frame:
Current: 0.600 A
Current: 0.000 A
Voltage: 13.60 V
Coding: 00FD11
Coding: 02562A
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 15
Reset counter: 197
Mileage: 104261 km
Time Indication: 0
Date: 2017.01.22
Time: 13:45:00
Coding: 100001
Coding: 000016
Coding: 00CF07
2 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 28
Reset counter: 234
Mileage: 104364 km
Time Indication: 0
Date: 2017.01.25
Time: 07:54:00
Freeze Frame:
Bin. Bits: 00000
Voltage: 12.60 V
Count: 17
Freeze Frame:
Fault Priority: 7
Fault Frequency: 28
Reset counter: 234
Mileage: 104364 km
Time Indication: 0
Date: 2017.01.25
Time: 07:54:00
Coding: 010000
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 229
Mileage: 106343 km
Time Indication: 0
Date: 2017.03.26
Time: 17:57:20
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 33
Reset counter: 213
Mileage: 104320 km
Time Indication: 0
Date: 2017.01.24
Time: 19:30:46
Coding: 0000001
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 197
Mileage: 106557 km
Time Indication: 0
Date: 2017.04.05
Time: 10:29:46
Freeze Frame:
Voltage: 11.70 V
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 11
Reset counter: 236
Mileage: 104242 km
Time Indication: 0
Date: 2017.01.21
Time: 22:25:55
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 81
Reset counter: 237
Mileage: 104278 km
Time Indication: 0
Date: 2017.01.23
Time: 19:07:38
