Anyone have a spare used brake pad with sensor?
Buffwesty Jul 10, 2018
  1. Buffwesty
    Buffwesty Member Team Mauritius Team V6 Audi A4 Audi Cabriolet Owner Group S-line owners group
    100
    Strange request I know...
    Just replaced the fronts on my partners TT, but did not get ones with the wear sensor.
    Now the warning light always shows up, obviously....
    So I am looking for one pad with sensor on so I can reconnect it and tie it away to stop the light.
    Many thanks.
    Ben.
  2. Avatar
    Google AdSense Advertisement
  3. Tj 0785
    Tj 0785 Well-Known Member Silver Supporter VCDS Map User Bronze Supporter Audi S3
    2,588
    678
    Can you just cut the one off the old pads?
  4. Buffwesty
    100
    Threw it away before realising....
  5. RobinJI
    RobinJI Active Member
    188
    31
    Not sure if it's the same on Audi's but on other cars I've worked on it's worked fine to just link the two terminals of connector together. I can't imagine Audi would have bothered making the system any more complicated.
    andrew_wright likes this.
  6. Buffwesty
    100
    So just cut the wire and twist the two together?
    I'm not that electrically minded....
    Thanks.
  7. Tj 0785
    2,588
    678
    Id get a bit of wire and put it in the terminals and tape it up till next time the pads need doing and loop it that way if you cut it off you will have to replace it or try a local scrap yard or a breakers on ebay
  8. Stuart B
    Stuart B Well-Known Member
    3,421
    734
    Just use a paper clip and some insulation tape.
    Tj 0785 likes this.
