Anyone got moisture in their xenon units?
azibux1
Hi all
Simple as above. Sprayed the front of the car today with a hose (didn't check lights beforehand) and when done drying (I washed the front properly before drying don't worry) I spotted moisture in the bottom half (quarter maybe?) of both front headlights
Anyone else got this?
Will keep an eye on it but wondered if it was normal behaviour in this weather? Only about 7 months old
HulkRS3
Kyalami RS3 Saloon
Shouldn't be. Check the seal on the back of the headlight is seated properly as that could be causing the let in of moisture.
Gazjs
Dosent sound correct :(
The lights still intact? No cracks etc?
azibux1
You may have just solved it. I'll check it out Sunday but when I got the car I fitted some LED front indicators from trups on here. But I'm fairly sure the cover was a simple twist cover that went fairly solidly into position so as far as I know, I shut it properly
Shouldn't be cracked as far as I know / can tell
AudiNutta
Moderator
Staff member
Moderator
Yes it's common there, we have had 2x A3 S Lines with xenons and quite frequently through cold / wet weather the bottom corner / quarter will mist.
I've seen an Audi technician bulletin for it, any condensation in the headlight you will more than likely be fobbed off. I have a crazy amount of water in my rear light, full of droplets! I took it to Audi and got fobbed off saying it's normal, but the useless service advisor couldn't find another one like it to show me!! Went to a different centre, a helpful one (Bridgend) and they have booked it in straight away for Tuesday, saying it isn't right! I know who I'm letting service my car in the future, shame that the supplying dealer have let me down again.
MKC
I believe this is normal I have it on mine. It also says this in the owners manual that moister is to be expected in the headlight, I'm unsure which page however
DeanoC
Well-Known Member
They are normally vented and it is perfectly normal and will dissappear as you drive. On mine there is a little vent pipe that goes from the back of each pipe to in front of the radiator. You will probably have something similar
