Anyone else just 'not bonding' with their new RS3?
IanL-S3
My biggest annoyance with the car is the USB charging points.
Can't put my phone (pixel 6 Pro)on the charging pad and plug it in. And wireless charging doesn't charge my phone.. And so it sits in the cupholder plugged in with a cable running across the middle of the car.. But then when you put anything in that area you can't get it out as the cable is in the way. And I've actually bent one connector slightly by accident. It's just waiting to be broken. With USB A things were more sturdy.
I think my solution will be to get a cigarette lighter charger..
Then I'll fully bond lol
RSt3ve
Well-Known Member
Full agree, wireless charging or not, the size and layout of the arm rest storage is poor and the usbc area is awkward to use.
I miss the 8v arm rest storage. All wires tidied away out of sight or wireless, which actually charged fairly well on the s3.
Being in the 8y is like going back to the 2000s with cables strewn everywhere.
Snake Pliskin
Well-Known Member
Supporter
it is a terrible design flaw isn’t it.
Visible cables / can’t leave your phone as it will be on show … how hard would it have been to have at least included a compartment / lid ?
Amirh87
I just put my phone screen side down in the wireless charging cubby.
Eventually I’ll just cover the wireless charging pad with something aesthetically pleasing.
All that pad does is make my phone hot
8YARWY
Chasing the trolls.......
Yeah it did that to my iPhone a few weeks back.
IanL-S3
Agreed but doesn't help when you need to charge your phone.
Edit: just catching up on the other threads. Really feel for guys that have been and are still waiting. Puts things in perspective.
Real Thing
After just over 3 weeks with the New Car decided I Prefer my R Might be an Age thing now as after nearly 3 Years with My Golf I feel I just don't want the change of all the different technology as well as just seem happier with the R So will be putting an advert with photo's together over the next week. Unless there is anyone who has cancelled or doesn't want a long wait I have a SB Vorsprung Edition in Kemora Grey Registered 20/10/22 with less than 200 miles would like an Enthusiast to benefit from my sale rather than a Trader Cashing in so only looking for £60K if any member is interested
RS3
I wrote out to stay in it but read back and saw the delays and your thoughts and saw a picture of the Golf which looks smart so now I won’t suggest staying in it lol, if the spark has gone do what you feel is right.
Can’t disagree with you as the buying process and Audi UK really soured the whole purchase for me as well.
IanL-S3
This is really stupid feature.
I like most of us will have the AC set on Auto (why that needs a separate button?) But if you put on the window demister then turn them off... The fans remain on full rather than going back to auto..
It's bizarre that the logic for that has been missed in this day and age. Even weirder that it has to be programmed (I would have thought it was reused code from the past 20 odd years) and was missed!
rngDeadeye
Active Member
Oh, that explains why every time I get in Mrs Deadeye's S3 the AC is not on auto. ***!
kayemill
It's a weird one this as sometimes the fans go back down and other times, they stay up full.
Mike.46
Well-Known Member
Yes I picked up on that fan thing as well, my car will also 'steam up' for a short spell after a the car has sat in the drive for 30 minutes when re started, almost as if the air con evaporator is still wet or a heater drain is blocked
Prodigy
Speaking of which......is it just me and my car but is anyone else struggling to demist their front windscreen in the morning (now that the colder mornings are here again)??
This alone in the mornings is making me "not bond" with the car...especially when you're in a rush/kids school run/appointment.....
Had an 8P RS3 for 10 years before this and never had an issue demisting that in cold mornings (within a reasonable time frame before being able to safely drive off).
Snake Pliskin
Well-Known Member
Supporter
had this with ALL my audis.
RS03???
The only car it did not happen was on Ford's with heated front windscreen. Ended up using Anti-Fog from Ra1n-X , works quite well.
Prodigy
This stuff??:
Will give it a go as it's so frustrating waiting for it to demist.
RS03???
This stuff??:
Yes, The glass surface inside has to be super clean. Apply the product as instructed very sparingly with a microfibre towel and let it fry for 3-5 minutes and buff. After application for the first few mornings 3 or 4, will see light fogging, wipe lightly with microfibre cloth to buff the misting away. Then it should be good.
RS3ree
M3 Convert
Member
Bizarrely, I'm actually having a bigger challenge with the outside of the windscreen misting up on cold mornings. I have to run the wipers for the first few minutes otherwise it mists within a few seconds. Eventually it's resolved when the fan heater kicks in. I was planning to try both inside and outside with the RainX this weekend. Agreed with what RS03 said - my wife's old Focus never had this problem! So much for progress...
Mike.46
Well-Known Member
IanL-S3
Another small annoyance.
Can't easily lock the car after starting the car. Handy for the freezing weather at the moment.
On my old X5 I pull the key from the fob and lock it manually. On the RS3 because the key hole in the handle is covered it's not so easy to access and even then I'm not sure it would work.
I wonder if there's a setting to allow the car to be locked from the fob while the engine is running.
8YARWY
Not on the 8Y.
Shame as I had it enabled on the 8V.
Mike.46
Well-Known Member
You can do that with the Pandora Storm plus (If you activate it) you can even do it without even leaving your house, or from anywhere in the World (very usefull that one :) )
Snake Pliskin
Well-Known Member
Supporter
Lol having it in the garage saves a lot of time.
Same here … but useful in the day when the cars been outside in this weather. The RS3 8y is my worst Audi so far at getting the heater up to temp and demisting the cabin.
8YARWY
To be fair mines been ok the past few days even in these temps.
itsbigyellow
Active Member
It is literally the worst car ever that I have owned during the winter. My 1982 Mk1 Astra SR even did better at warming up and demisting. This morning I used the X5, defrosted and up to a decent cabin temperature in 10 minutes in a very damp -3. The 8Y, 20 minutes on the drive for the defrost, still demisting as I am going down the road
Mike.46
Well-Known Member
Must admit the Golf R EA888 engine used to be up to 90c by the time I got to the main road (nearly 2 mile) the RS3 engine hasnt even registered on it's temperature gauge by then (I know it's oil temp) but it's not blowing warm air at me either
itsbigyellow
Active Member
My '98 Landy Defender is never the first word in comfort or performance. I love it to death, but it still deals with demisting better than my £60k+ 'RS'
8YARWY
The EA888 has the manifold in the head design though so it heats up a lot quicker.
Terminator x
This thread is so depressing, someone pls post some good stuff in my "good stuff" one instead!
TX.
IanL-S3
TX.
I kinda post here for fun...... Because of the title...... Ironically maybe....
Still love the car... And will never be sold....
IanL-S3
TX.
Snake Pliskin
Well-Known Member
Supporter
TX.
Sorry mate - that thread’s dormant :)
Something good … ok … erm ….
Although the heating system takes an age to warm up and clear the windscreen, the seat heaters get up to temp in no time, they get roasting hot very quickly ironically.
